Help with 1959 Dodge Pickup
Ijust inherited a 1959 Dodge Pickup from my grandfather. He drove it 2 weeks before he died discovered it had a fuel problem, cannot control what comes out of the carb, suspect fuel pump. Any ideas help me plz.</P>
Also would like to continue OEM,plan to rebuild. Any ideas plz help.</P>
Thank you.</P>
RE: Help with 1959 Dodge Pickup
Sounds like a stuck float or needle valve. take your fuel line off,and remove the needle valve assmblely(thats what your fuel line hook to on the carb)should be a 9/16's blow it out good and spray it with carb cleaner.that should stop your flooding problem.
