Quote:
Originally Posted by charon187
great!!!! keep us posted!!!
Hey Mr. C187,
A netizen on another forum wrote:
Quote:
Originally Posted by B-300
Hoses screwed into the wheel cylinder (sealed with a copper washer), with a hex flange on the chassis end that has an inverted flare connection is exactly what the A-100 and early B-series vans with drum brakes use.
And I responded with:
Hey Mr. B-300,
Yes.
Got a NEW Wheel Cylinder for Lorrie's Right Front Wheel, and it came with the Copper Washer. Got a supply of those same Copper Washers at that time.
So... possibly an A-100 and/or an early B-Series Van w/ Drum Brakes Flexible Brake Hose would work. The end opposite the Wheel Cylinder that goes through the Hex Flange is a LONNNG threaded section.
Did a CAREFUL inspection of the EXISTING Front Flexible Brake Hoses yesterday evening. Cleaned them off the oxidized rubber on the surface, and under the soot-like covering, the rubber is solid, no cracks, and the Hoses are flexible, solid, and quite substantial.
Am thinking that all they need is a careful cleaning of the Wheel Cylinder end fitting, and reinstalling them when the Wheel Cylinders and NEW Copper Washers go back on.
Then before driving Lorrie, doing a test by applying a LOT of Brake Pedal... Actually make a concerted effort to "pop" the brake lines. If they don't give out, I'd feel pretty safe in just leaving them on.
Whaddaya think?
Also, in messing with this, notice that the Steel Tubing in the system has a coil of wire around the Steel Tubing. What's up with THAT, I wonder? Ms. American 3.14159 (the 1964 Ford Galaxie 500 Police Interceptor) doesn't have anything like that on her Brake Lines.
So here's the PLAN:
Going to hone the Left Front Wheel Cylinder, and install the Rebuild Kit. Then reassemble both front Brake Assemblies.
Going to then put Lorrie's Rear Axle up on Jack Stands, remove the Wheels/Tires, remove the Rear Brake assemblies, remove the Wheel Cylinders and Flush the Rear Brake System with Brakleen and Compressed Air.
Will inspect the Rear Wheel Cylinders, and if they'll come apart, they'll get honed and new Cups, Spring and Boots will be installed the same as Lorrie's Left Front Wheel. If they are "frozen", as was Lorrie's Right Front Wheel Cylinder, they'll get replaced with NEW Units.
Will clean and repaint the Back Plates, Drums, and Brake Assembly Components, and reassemble the Brake Assemblies.
Then comes installation of the NEW Master Cylinder, and the hooking up of the Front and Rear System Connections. Reinstall the Brake Pedal Push Rod, Add Dot3 Brake Fluid, and Bleed the entire system. Then try to "pop" the Flexible Brake Hoses.
BTW, Lorrie is going to NEED the Boot that goes on the Keeper that holds the Master Cylinder Cylinder in place, and through which goes the Brake Pedal Push Rod. Do you have any idea where THAT item can be had? If not, it's Google Search time again.
The Brake Light Switch, along with the Pedal Back Travel Limiter also has to go in place.
As soon as all this is done, It'll be time go get Lorrie's Engine back up and running. But that's another Saga.
Anyway, thanks for the info about the A-100 and B-Series Brake Lines. If Lorries Hoses pop, then those will possibly be what will replace them.
Will keep you updated as events occur.
JC
