Quote:
Originally Posted by Urqell1950
Hello.
Hey Mr. U,
Quote:
Thanks for the help, then i try to replace the shoes and hopefully that's it. Feared the worst as the brake works on the drive shaft but hope only the shoes are the problem
U
If the vehicle was drivable AFTER the test drive, then it is doubtful that the guy who drove it with the brake on did much more than either wear or burn up the shoes.
I'm not familiar with this Parking Brake set-up, or its location in the drive line. BUT it most certainly is in place AFTER the Transmission. So what was done would have put some amount of stress on the Fluid Drive, and whatever gears were involved.
IF the Brake is located BEFORE the Front U-Joint (which it seems to me would be the way it would be, as to have it AFTER the Front U-Joint would mean that it would have to ride up and down with the Drive Shaft), then there would have been no stress on U-Joints or Differential Ring and Pinon Gears.
If the problem is that the Brake will just not hold, then most likely it is just the Shoes have been burnt up.
You might try adjusting the unit BEFORE you replace anything. It MAY be that the shoes are just worn from their unfortunate experience and if they can be adjusted to make up for the wear (which is what an adjustment is for) then THAT may solve your problem. The guy who drove it with the Brake on just put many years of wear on it in a short period of time.
Good luck.
JC
