DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > Dodge Cummins Diesel
Thread Tools Search this Thread
  #21
Old 04-12-2007, 08:44 PM
cumminalong cumminalong is offline
Default RE: Rear Diff Service - Lots of Pics!
The pump is seperate, like I said about $7.
The oil is just Sta-Lube, GL-5+,gear oil. I get it at NAPA. It's about $20 a gal.
For the front and rear, it ran me about $48, with the pump.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #22
Old 04-12-2007, 09:06 PM
Drew Drew is offline
Send a message via ICQ to Drew Send a message via AIM to Drew Send a message via Yahoo to Drew
on a side note that Rich didnt mention. . .the AAM axels on the 3rd gens do not require any friction modifier since the LSD does not use clutches, instead it uses a series of worm gears which can be seen in the 4th pic.
you 2nd gen guys with the Dana LSD axels still need to have RTV and some friction modifier handy when servicing your axels.
__________________
4/28/07 392hp 716tq on the stock clutch
10/20/07 425hp 798 still on the stock clutch
BIG THANKS to David and the guy's at James O'neal Dodge.
YOU GUY'S ROC
  #23
Old 04-12-2007, 09:36 PM
Mayfair's Avatar
Mayfair Mayfair is offline
Man ... now you've got me wondering what the heck I put in there. It was just 75-90, but I don't remember if there was any mention of "friction modifier" or not.
I hope I didn't eff it up ....
__________________
1998.5 Ram Cummins 24 valve turbo diesel
  #24
Old 04-12-2007, 10:19 PM
Quote:
ORIGINAL: Drew
Drew..................,
You don't give me enough credit brotha!
[IMG]local://upfiles/39492/CA5F2C72EE964D9F99C3DB2FFC068B89.jpg[/IMG]
  #25
Old 04-15-2007, 04:46 AM
JT824Megacab JT824Megacab is offline
Send a message via AIM to JT824Megacab
The service manual for the 06' say to use 75W 90 synthetic for the rear. Do you have an 06'? If so why did you select the gear oil that is pictured?
Quote:
ORIGINAL: cumminalong
More.....
[IMG]local://upfiles/39492/0BF1208987844C0C92B060851E68ED24.jpg[/IMG]
[IMG]local://upfiles/39492/B57B9DDF3174447DA1ABE2710171C75C.jpg[/IMG]
[IMG]local://upfiles/39492/E7ED3A4488054A55A6455BBB0E8B55E4.jpg[/IMG]
[IMG]local://upfiles/39492/1C9105840E0E4308BE47DA2B26BEB4F6.jpg[/IMG]
__________________
06' Megacab 2500 4x4, Auto, BFG A/T-315/70/17, Line-X, Train Horns, back-up camera, JakeBrake, Oasis Differential Cover with Ram Logo, Pace Edwards Jack Rabbit Retractable Bed Cover, Clearance Lights
I guess I'm all-in
  #26
Old 04-15-2007, 11:56 AM
Right, it does say 75W90 Synthetic....absolutely correct.
Depending on how I'm using it, I use different fluids. If I KNEW I was gonna tow heavy, I would have actually gone with 75W-140 for the added viscosity. But, because my truck is gonna be sitting for A WHILE (like for about2 years here, pretty soon) I went with the dino oil.
Here is my reasoning. After SEVERAL 6 month - 1 year deployments recently (go figure), I have found (just my personal experience, take it for what it's worth) that with synthetics, it seems that after the truck has been sitting for a while, the fluid levels all seemed lower, especially engine oil. Also, the inital start up seemed a little harsher. Again, just my personal observation.
The only use my truck will be getting in a few more weeks is the wife driving it to work every once in a while to keep everything in order. It's a good 30 mile, back road, no stop and go drive to work, so it's perfect to keep everything lubed up and get it up at full operating temp.
And.....................I'm cheap. And to me, I don't buy into the synthetics unless I plan on doing HARD use or extended drains. I have yet (knock of wood) ever experienced a failure of a part that was the result of using synthetic or dino oil, if the vehicle was maintained at proper intervals and the fluid levels were kept in th normal range.
  #27
Old 04-15-2007, 12:25 PM
Watermelon Watermelon is offline
Are you fixin to go overseas to the big desert? Iraq? Dang it man, your truck is gonna miss you!!
__________________
2006 3500 4x4 6spd flatbed Quad
  #28
Old 04-15-2007, 01:18 PM
Quote:
ORIGINAL: Watermelon
No, actually I'll be in South America this time.
This actually should be a decent trip. The only thing that sucks is that I sure as hell ain't taking the truck with me. I could see that getting stolen in a heartbeat and making it's way into the drug trade.
I'll be taking my little Ford Focus instead.
I may have to have Drew come down from ATL, just to make sure that my truck isn't living too easy!
  #29
Old 10-10-2007, 06:10 PM
chouseal chouseal is offline
Thanks for the how-to... this will help a bunch. Stuff like this always seems harder than it really is.
Anyone have an opinion on whether it's better to drain while the oil is hot? I'm thinking perhaps hot oil would flow easier and therefore flush crap out of any crevices...
__________________
1996 CTD 2500 4x4 long bed, manual trans, BHAF, TST #11 fuel plate, pyro/boost gauges, straight pipe, 260k mi
2005 Grand Caravan SXT, 100k mi
  #30
Old 10-10-2007, 06:46 PM
Mayfair's Avatar
Hot oil usually DOES flow a little easier. Is this for your 96? Are you outting a new diff cover on like a mag-tec?
__________________
Tags
03, amsoil, diff, differential, dodge, durango, front, imglocalupfiles394926732deb9169f424c9b5818032dc05e 2fjpgimg, imglocalupfiles39492e76bbb5b277b43e28ee621592ce76e 54jpgimg, nitro, nv4500hd, ram, rear, service
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
