DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > Dodge Cummins Diesel
Thread Tools Search this Thread
  #51
Old 09-01-2008, 09:35 PM
theviper90210 theviper90210 is offline
Mayfair - what is that wire you used for the lights, and whats the color, and what bundle is it in? Thanks
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #52
Old 09-03-2008, 06:29 PM
Mayfair's Avatar
Mayfair Mayfair is offline
I THINK it was pink and it's in that bundle under the steering wheel. Just use a test light. You'll find it. Make sure you have your lights turned on, and then once the test light lights up, push the lights off. If the test light goes out, you're good to go.
__________________
1998.5 Ram Cummins 24 valve turbo diesel
  #53
Old 09-03-2008, 09:57 PM
thanks man!
  #54
Old 09-10-2008, 02:24 PM
pakee001 pakee001 is offline
How do I get the photos to show? I can only see the text in Mayfairs message.
__________________
1997 12v CTD
Ext Cab, LWB
2000 Durango
4.7 L
  #55
Old 09-11-2008, 02:46 AM
Mayfair's Avatar
Really?
The pics are showing up on my end.
Can anyone else see them?
__________________
  #56
Old 09-11-2008, 12:23 PM
I can see all of the pics. lookin good
  #57
Old 09-12-2008, 10:04 PM
dirtydodge02 dirtydodge02 is offline
Vehicle: 2005 Ram 3500 QCLB
That looks like you put a whole lot of work into it. Good job man. How much was the pillar? Thinking about getting one for my Edge...
  #58
Old 10-12-2008, 02:40 AM
tr4petty tr4petty is offline
Why did you mount the pyro probe post-turbo? Most people mount them in the manifold pre-turbo don't they?
  #59
Old 10-29-2008, 12:13 AM
thehedonist thehedonist is offline
Vehicle: 1998 Dodge Ram 2500, 24v Diesel
I just got done installing an Auto Meter fuel pressure gauge and have some installation info that I think may be of help. I have a 98.5, 2500. The sender was an easy install. I installed it into the same hole in the fuel filter canister as seen in this post. I ran the wires through the same hole in the firewall, but was able to pull that flap partially out, run the wires through and reinstall the plug without doing any cutting. As for the rest of the wiring, I thought this was a bit more difficult and had trouble finding which wires to splice into. I first had to remove the dash and the cover below the steering wheel. I then removed the 3 screws on the headlight switch and pulled that out from the dash. I also removed the pillar. To install the light, I ran the positive wire through a hole on the left of the dash and behind where the headlight switch goes. There is a tan wire that goes into the back of the headlight switch. This is the one you want to splice into. This not only turns the light on when you turn the headlights on, but it allows you to dim the light as well. The negative wire I ran to a ground on the solid piece of metal below the steering wheel. The positive wire for the gauge itself I ran down below the steering wheel and behind the stereo to the cigarette lighter's positive wire. This wire can be accessed by removing the cup holder. The ground wire I ran to the same place as the ground for the gauge light. The cig lighter is a good place to run your positive because the gauge will shut off when the ignition is in the off position. I hope this helps anyone who started off as dumb as I did.
  #60
Old 07-09-2009, 04:49 PM
kalama kalama is offline
thanks for the write up been searching for this for some time on cumminsforum.com and could not find any write ups.... this helps alot... only thing is i read that it is not good to install the fuel senser on top the fuel filter housing due to vibrations and will damage the senser fairly quick... is this true?????
Tags
2004, autometer, bolt, boost, boss, cirkit, cummins, dodge, gauges, harness, installed, installing, pictures, ram, tap, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
