DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > Dodge Cummins Diesel
Thread Tools Search this Thread
  #21
Old 08-05-2007, 12:28 PM
sunchaser5.9 sunchaser5.9 is offline
Default RE: not another bypass filter install
Drew / Mayfair. Where can I get the info on the fuel filter setup??????
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #22
Old 12-12-2007, 02:11 PM
chouseal chouseal is offline
Drew/Steve... I've got 242k on mine. I'm presently running AMSOIL 15W-40, but for the majority of it's life it's had dino oil or synthetic blend. Do you think it's worth the time and expense to add a bypass filtration system? If it'll help me see 500k or beyond, it's worth it to me. I'm just wondering if it's a moot point, given the mileage already on this engine. She runs beautifully, though.
__________________
1996 CTD 2500 4x4 long bed, manual trans, BHAF, TST #11 fuel plate, pyro/boost gauges, straight pipe, 260k mi
2005 Grand Caravan SXT, 100k mi
  #23
Old 12-12-2007, 02:15 PM
Drew Drew is offline
Send a message via ICQ to Drew Send a message via AIM to Drew Send a message via Yahoo to Drew
the bypass filters main use is to help extend the life of the oil by filtering to a smaller particle size. it wont necessarily extend the life of the engine.
__________________
4/28/07 392hp 716tq on the stock clutch
10/20/07 425hp 798 still on the stock clutch
BIG THANKS to David and the guy's at James O'neal Dodge.
YOU GUY'S ROC
  #24
Old 12-12-2007, 02:22 PM
Makes sense. I take it from your previous comments that the return line to the top of the engine provides the added benefit of getting oil circulating up in the valve region quicker on cold startup, too?
Sounds like it would still be a good investment then.
__________________
  #25
Old 12-12-2007, 02:32 PM
that it does. . .you have fresh oil being dumped directly onto the head and valves as soon as the engine starts.
I do have a tick, and I know I need to lash my valves, however after just a few seconds that tick lessens from the oil.
__________________
YOU GUY'S ROC
  #26
Old 12-12-2007, 09:07 PM
CowboyBob CowboyBob is offline
Drew, how often do you change the filters? Both the bypass and the regular engine oil filter.
__________________
01 2500 CTD 6 Speed, Exhaust Brake, 90 Gallon Aux Tank, Hypertech Stage 3, Dual Lift Pumps. Running B20 24/7.
96 Ram 1500 318 Magnum, Bone Stock.
  #27
Old 12-12-2007, 10:23 PM
the bypass is usualy changed every other filter change.
__________________
YOU GUY'S ROC
  #28
Old 12-14-2007, 05:50 PM
How often are you changing your regular oil filter???
__________________
  #29
Old 12-14-2007, 06:38 PM
Mayfair's Avatar
Mayfair Mayfair is offline
I still like that toilet paper bypass filter. I thought that was pretty cool, and obviously the least expensive to replace.
__________________
1998.5 Ram Cummins 24 valve turbo diesel
  #30
Old 12-14-2007, 11:07 PM
steve05ram360 steve05ram360 is offline
Site Moderator
Dodge Forum Moderator
Vehicle: 2005 Ram CTD 4x4, 2000 audi TTQ
changing mine this weekend for the 1st time. still flowing good, about 40k miles on it. Amsoil claims 60~70 IIRC...
To the poster who is considering one at 200k miles... I'd do it. some of the research I did indicated that the particles greater than the 2 micron were a contributor to the wear in a motor... take those out with the bypass and you should slow down the wear from that point forward. I did oil analysis and it did not go as long as advertised... was ok at 7k but not at 15k so I flushed the motor with dino oil and did another analysis after 2500 on the dino (mobil delvac) and it was all good. approaching 5k on the oil that is in there and this weekend, all the filters (oil & gas) get swapped out.
__________________
http://www.dodgeforum.com/m_1037052/tm.htm
http://s41.photobucket.com/albums/e266/sdoherma/
Tags
08, bracket, bypass, cummins, dodge, drill, exhaust, filter, head, install, micron, spinon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
