RE: DIY tracbar install
I'd say you would have to lay under the front and watch the bar while someone turns the wheel lock to lock... that would put some pressure on the axle to move and you could look at the ends to see if there is any loosness in it. if there is (and you have a stock height truck), i'd get the urethane bushings to replace the stock ones with.
__________________
http://www.dodgeforum.com/m_1037052/tm.htm
http://s41.photobucket.com/albums/e266/sdoherma/
