Cummins 6.7 mpg
Old 05-19-2008, 11:03 PM
megruda's Avatar
megruda
megruda is offline
Default Cummins 6.7 mpg
I'm looking at a 2500 quad cab with the 6.7l cummins, but would like to get some real world reports on fuel economy. I think I want the 3.73 rear end. New to the forum and any help on this issue would be greatly appreciated.
Old 05-20-2008, 12:27 AM
agargano98's Avatar
agargano98
agargano98 is offline
Default RE: Cummins 6.7 mpg
you can expect 13 - 17 avg depending on your driving habits. once you get 20,000 - 25,000 miles on it you will start seeing an increase
Old 05-20-2008, 12:30 AM
megruda's Avatar
megruda
megruda is offline
Anyworse if it's 4wd?
Old 05-20-2008, 12:53 AM
sabersix's Avatar
sabersix
sabersix is offline
Typical for me is 15/17 city/hwy.
Old 05-20-2008, 09:12 PM
24ssm's Avatar
24ssm
24ssm is offline
i just bought one like 3 to 4 weeks ago and i got like 13 to 14 on the hwy and 15 to 16 city but i just put a intake and exhaust on it and now im getting 18 to 20 in city and 16 to 17 on the hwy
Old 05-20-2008, 09:45 PM
mopar1973man's Avatar
mopar1973man
mopar1973man is offline
ORIGINAL: 24ssm
Even in my 2002 I do much better in the city as long as you keep a light foot.. With mixed driving around here I can pull a good 21-23 MPG now... The trick is to keep your pyrometer below 600*F and boost below 5 PSI and 20+ MPG's will happen...
BiggBlu601's Avatar
BiggBlu601
BiggBlu601 is offline
averageing about 14-15 on hwy. Not quite sure about the city cause i dont drive to much inside the city.
Old 05-20-2008, 09:50 PM
firemedic740's Avatar
firemedic740
firemedic740 is offline
24 thats impressive! How do you get less mileage on the highway? 20 in the city? I just topped off I put 231 miles on the trip and added 13.1 gallons of fuel so 231/13.1=17.6 mpg. Funny thing is the overhead says 16.1. I just put on the H&S dpf delete and have had no regens- thank god! I have been mostly highway by the way about 70% hwy.
Old 05-20-2008, 09:56 PM
Az2500Cummins08's Avatar
Az2500Cummins08
Az2500Cummins08 is offline
24ssm I think you have your city/highway MPG backwards, unless you are listening to the Lie-O-Meter. I have 6,942 miles on my 6.7, and I get about 17 highway, and 13-15 city depending on how many times my engine goes into regen, driving habits and all that crap. I have MBRP cool duals, and it did nothing for performance. The only way you will see any improvement with an exhaust mod is to get rid of the Cat and DPF all together, only if you ware willing to sacrifice your warranty and like the color amber on your dash. I still have the stock intake, but I took out that huge plug in the stock pipe. I didnt gain any noticable power of fuel efficiency increase, but I can hear the turbo alot more now. I have a 2 1/2 inch lift and 35 inch tires,from which I gained a MPG from, and 200 RPM less at 65 MPH. I lost a couple MPG in the city though. I have the 6 speed manual. I am about to go in for my first official oil change. Gonna get an oil analysis as well. I will let yall know what I find. Oil change is not due for another 3,000 miles or so, seeing that they changed my oil at 3400 miles due to that oil leak I had.
Old 05-20-2008, 10:02 PM
mopar1973man
123,907 - 123,558 = 349 Miles
349 Miles / 14.893 Gallons = 23.43 MPG
The wind drag on these truck is impressive... But its really surprising to reduce the speed and watch the MPG climb rapidily. Here is a simple write up I did in regards to MPGs...
http://mopar.mopar1973man.com/2002-d...-mpgs/mpgs.htm
Here is my fuel logs...
http://mopar.mopar1973man.com/2002-dodge/2002-dodge.htm
Quick Reply: Cummins 6.7 mpg
