DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > Dodge Cummins Diesel
Thread Tools Search this Thread
Old 08-31-2009, 12:43 PM
99 Ram 2500 99 Ram 2500 is offline
Default 99 RAM Diesel Help?
99 Dodge 2500 Cummins diesel just died going down road. I pulled over and started truck. The check engine light is on and idles fine but has no power and starts to miss when I accelerate. Can go five miles per hour max? what is wrong with my truck?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-31-2009, 01:30 PM
lghtngblt02's Avatar
lghtngblt02 lghtngblt02 is offline
DF Site Moderator
Dodge Forum Moderator
2007 Dodge Dakota
Vehicle: 2007 Dodge Dakota 4x4 Laramie
Send a message via AIM to lghtngblt02 Send a message via Yahoo to lghtngblt02
Quote:
Welcome to DF 99 Ram! Almost sounds turbo related! The Diesel Section may be able to give you better help! So I'll move this over there for ya. Good LUCK! Thanks for joining!
__________________
Silver Truck Club Member #57
Old 09-01-2009, 01:32 AM
pizzo's Avatar
pizzo pizzo is offline
Vehicle: Dodge Ram 3500
thanks lghtngblt02 for moving this
Ok
First lets start with fuel filter glogged?
maybe not getting fuel.
Is it black smoking when you mash the pedal with out a load on engine?
You can look into the turbo that is the easiest thing first by taking off the hoses going to the turbo stick your hand in the hole. the impeller shouldn't wabble
and should spin freely if sqeeks or stops right away or dont spin at all, blades missing or anything that don't look right the turbo is bad.
If that is ok check your fuel pressure? if your fuel pressure is ok then get it scanned and give us that code that its reading. That would be a big help.
Old 09-01-2009, 09:10 PM
BrianSudokhoi02 BrianSudokhoi02 is offline
Vehicle: 07 2500 CTD
Get your codes read first, before you try driving that truck any farther. Your symptoms are similar to your injector pump failing. That year truck is notorious for having the lift pump fail then the injector pump goes shortly after. If you get at P0216 code when you read them, its almost a guarantee that both your pumps are out.
__________________
07 Ram 2500 Quad Cab w/Cummins 5.9
Automatic Transmission, Husky rear mats and mud flaps, Nasta stainless nerf bars, Bushwacker bed rail caps, lorado tonneau cover
Old 09-02-2009, 02:17 AM
Hahns5.2's Avatar
Hahns5.2 Hahns5.2 is offline
Vehicle: 95 Dakota Sport CC
Sounds like the classic lift pump failure followed by VP44 failure.
__________________
95 Dakota Sport CC, 5.2, 5-Speed, 4x4, M1, Mopar PCM, HS 1.7 RR's, Aero Turbine 3030, 50mm TB, 31x10.50s on 15x8 Ultra 50 Series, 3.55s, No-Slip Locker, Lakewood Traction Bars.
88 Bronco II, 4.0 swap, 5 speed, 34x10.50 LTBs, 4.56s, Locked front/rear.
Old 09-02-2009, 07:53 PM
racer9 racer9 is offline
Vehicle: '81 Ram, '96 Ram
Try the Key method. Key on(don't start)-off-on-off-on, read codes in odometer window.
__________________
'96 Ram Cummins, turned up and smokin'. 4X4, auto, Dunrite TC & VB, Intelligent Engineering billet input, Schwitzer S300g, 4" downpipe to 5" stacks, homemade #100 plate, governor springs shimmed, homemade flatbed, Isspro gauges, bhaf.
'81 D150, 225 4spd O/D Just for fun. Soon to be 4BTA Cummins.
Old 09-04-2009, 12:31 AM
pizzo's Avatar
sounds like a pump is gone but why would it IDLE fine? you would think that if the pump is gone its gone
you will have to read the Codes. and see why the check engine light is on.
Old 10-08-2009, 10:07 PM
Sumosride Sumosride is offline
I also have a 99 Dodge 2500 with 24v cummings. I filled it up last Friday and when I went to leave, it idled fine, ran fine upto 1000 rpm and then using a term from a gas driver "it acted like it was running on 4 cyl.. I pulled a utility trailor home with a Kabota tractor, frontend loader, and brush hog and had all the torque to do so. However, I had to stay under 100 rpm.. I have replaced fuel filter and ended up changing the transfer pump before I could get everything bled out. I still have the same problem. Today I ran the codes and got the following.
P0251-Injector Pump Fuel Metering Control A Malfunction
P1688-Internal Fuel Injection Pump Controller Failure
P0252-Injection Pump Fuel Metering Control A Range/Performance
Sorry for the book. I'm new to the sight but I need help also. Which way should I go next.
Old 10-08-2009, 10:40 PM
Coal Train's Avatar
Coal Train Coal Train is offline
Vehicle: 2006 Twin Turbo CTD, 742 HP/ 1456 TQ
99, that for sure sounds like an IP. More than likely you're gonna find a dead lift pump and that in turn took out your IP.
Sumosride, yours sounds like the VP's computer took a dump, not necessarilly the pump itself. Check the connectors and wiring going to the pump.
__________________
That thing gotta Hemi?...... I guess ya better bring two of 'em then!
Old 10-09-2009, 08:06 PM
Default Any more help left.
After reading the codes yesterday, I cheched electrical connections around everything relating to the fuel system under the hood and found nothing. I also bled injectors. I did get some air out of all six injectors and was also able to verify that all were busting off. When the engine goes above 1000 rpm. it sounds just like I have left multiple injectors bleeding. I also noticed some thing else new today. I started and stoped the truck several times without the batteries being able to be fully charged. When I did allow it to run for some time, the engine began to cut out the same way at idle as the alternator cycled in and out charging the system. Can anyone give me a clear direction to go short of taking to a shop.
Tags
01, 2500, 59, 99, codes, cummins, dies, diesel, dodge, lift, p0216, pump, ram, read, symptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
