Even though the Edge is a stand alone module, it still leaves a few tell tale signs that it's there.
1 - It occassionally sets a soft code for Invalid SKM Key. This is a pretty common one on stand alone modules.
2 - The biggest give away is the load % on the DBR or StarScan. When I have my Edge running, part of the fooling it does is tell the ECM that engine is under less load than it really is. According to ECM, my truck has never seen more than 60% load or throttle.
3 - There needs to be a spot drilled and tapped for the EGT probe. Can't really hide that.
Figured that lol. . . Thanks well i am going to take the edge off and have it flashed tonight and see where we stand after that. Thanks for all your input guys, it been a big help.
I will let you know what happens.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
2005 Dodge Ram 2500 QuadCab SB - CTD - Auto - 3.73 - 6" Procomp Lift - 325/60R20 KMC Wheels - Edge with Juice - 5" Dynomax Exhaust - Hi-flow Air filter
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Ok so i took off the edge w/attitude and took it into the dealer to have it flashed with the latest software. Got that done and when i left i dealer the truck ran GREAT, I was sure i solved the problem drove great the whole weekend.
Then i jumped into it today to come to work, sure enough black smoke hazing out while crusing and i noticed a pretty substantial loss of power!
Here's the plan now though, I have a buddy that works for Elite Customs in ogden and he said he's good friends with a couple guys at Edge, and i guess that have a machine over there that will give a detailed readout of what my engine is doing. So i have to throw the edge back on and take it over to them to see if its a engine management issue.
This is turning into a joke!
Anyone have any other thoughts or input? Its always appreciated!
__________________
Ok, I have a few thoughts for you. 1st, if your trying ot get back to stock conditions do that, leave all mods alone until you are sure it is acting right. Second, now that you are sure you have stock tuning start troubleshooting with simple stuff first. Black smoke and loss of power indicate one of 2 things, too much fuel or too little air. The '05 trucks came with an charge air cooler that had plastic ends on it and they are known to leak. A boost leak could cause your issues. After confirming that the CAC doesn't leak I would go through the entire intake system and look for leaks there. If you don't find leaks in the intake, then injectors is the next place to go. Good luck and keep us posted.
Thanks for the thoughts. . . Just help fill me in a little more here. I will look into the plastic connectors (i've been meaning to get to that anyways) but my edge is still telling me i am getting ample boost (6-11 on the freeway and 35-38 at WOT). Now my question is how does it make that determination? Does it take it off of throttle position and where the boost should be at? Or does it read it off of a actual sensor? and if so which sensor? . . . . I have also been thinking and i wonder if maybe i dont have a shot MAP sensor to. Something else to look into?
And anyone know a good place to buy metal replacement for the plastic ends on the CAC?
__________________
I am not sure where the Edge gets it boost numbers, it may hook into the factory MAP/IAT sensor. If it does you should be able to follow the wiring harness from the MAP/IAT sensor to the Edge box. The MAP/IAT sensor is located on the drivers side bolted to the intake next to the valve cover about 3/4 of the way back.
The plastic ends are part of the CAC and the whole cooler would need to be replaced I believe. The CAC is just like a radiator it has aluminum heat exchangers, but on '05 trucks they went with plastic end tanks and they had trouble with them. In '06 they went back to an all aluminum design.
Ok well i had some extra time tonight so i pulled off my K&N and decided to do a leak check on the CAC hoses. Sure enough, it was leaking in two spots right off of the turbocharger outlet.
So i patched that guy up real quick and i figured while i was at it that i would check the MAP sensor. So i pulled it out, whipped open my Haynes manual and THEN found out that they dont give the terminal names or what the resistance is suppose to be.
Does anyone know off the top of there heads how I can test this guy or what resistances the termainals should be? I know there like $110 for this itty bitty sensor (which blows) or i wouldn't even bother going through the hassle of testing it.
Thanks guys
__________________
