2003 dodge cummins , no power
Old 05-09-2010, 09:11 PM
purplewooblet's Avatar
purplewooblet
purplewooblet is offline
Default 2003 dodge cummins , no power
i have a 2003 dodge 4 wheel drive , automatic, cummins, at 2100 rpm that is all the faster it will rev going down the road, free rev it goes right up , real slow on take off , up winds up there, no real mods , new injectors, kn filter, it just has no guts going down the road enpty , help thanks , does throw a 336 code , but maybe once a week , changed the crank sensor , no change, thanks
Old 05-10-2010, 10:34 AM
MOPWR2U's Avatar
MOPWR2U
MOPWR2U is offline
You must have bought my old truck. I had a 2003 Cummins that had NO power. It struggled to tow anything, and got 6 mpg while towing. Took it to the dealer three times in a year with complaints of "no power". The dealer never could find out what was wrong with it, so I traded it in on a Duramax after a year. Good luck with your truck.
Old 05-10-2010, 09:41 PM
pizzo's Avatar
pizzo
pizzo is offline
Wiring did you check the wiring for the crank POS that wiring harness gets screwed up sometimes... that is my
Old 05-12-2010, 11:22 PM
purplewooblet
Default will a shorted injector throw a 336 code, 2003 cummins
2003 cummins , will a shorted or bad injector throw a 336 code, it misses when it throws this code, thanks
Old 05-14-2010, 12:11 PM
vin's Avatar
vin
vin is offline
I had similiar issues with my 03 HO. I had it to the dealer and they couldn't fix it( injectors,lift pump,ecm,fca were replaced). I talked with a Cat diesel engineer who told me to remove and clean all my ground connections. Not just the battery grounds, all the grounds. I sanded or wire brushed them. I found a braided ground attached to the back of the head it was nasty. After the cleaning my truck ran great. Try it and hopefully it'll work for you too.
Quick Reply: 2003 dodge cummins , no power
