DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > Dodge Cummins Diesel
Dodge Cummins Diesel Discuss all generations of Cummins Diesel powered Ram's within Dodge Diesel Forum.
Thread Tools Search this Thread
Old 07-20-2006, 10:19 AM
kingdog kingdog is offline
Default RE: Jacob's Exhaust Brake
Josh
I have the PAC BRAKE ( exhaust ) on my 02 4X4 6-speed, I only use my Dodge for towing and even then not that heavy maybe 8000lbs average. I find that my Pac works just as promised, the higher the engine rpm the more braking power, I drive/tow alot through Ontario so no real big hills and mountins , well non here at all. I use mine when slowing, or to maintain speed limits when going down hill, I do feel and notice a huge differance when using it. There is a down side to it though ( IMO ) I am not using the service brakes enough and as a result have had some service brake isuues, IE all new brakes all around including rottors and rear calipers, shop said from lack of use, so I now try and only the PAC when on bigger hills and never when I am not towing as I can amost come to a complete stop with it while down shifting to lights ect ...
If I lived where you do and had the size of a trailer I pulled, no question I would have the brake .
Ralph
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
07 3500 Laramie Dually,5.9 CTD Auto LB QC, Cat delete, Duals, Pac-Brake, Intake, O/H gauges, Tranny, Boost, EGT, PIAA 580'S,Grill gaurd,Air Bags,Bump stops, Edge Juice,Titan fuel tank JUST FOR PULLING
2002 2500 6 spd HO 4X4 GONE BUT NOT FORGO
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-20-2006, 10:47 AM
Drew Drew is offline
Send a message via ICQ to Drew Send a message via AIM to Drew Send a message via Yahoo to Drew
well ralph, with the way you re-engineered the butterfly valve I would say that you are running a risk of causeing damage since the back pressure can be VERY high in your case.
granted you are getting better performance out of the brake, but you are also risking your engine by doing so since the exhaust has to be pushed through such a smal hole. I would go back to the origional design on the valve. the hole is designed in such a way that it will not let what you are talking about happen.
__________________
4/28/07 392hp 716tq on the stock clutch
10/20/07 425hp 798 still on the stock clutch
BIG THANKS to David and the guy's at James O'neal Dodge.
YOU GUY'S ROC
Old 07-20-2006, 11:28 AM
CowboyBob CowboyBob is offline
I've got the PAC-Brake on my 01 CTD and would not get rid of it for anything. I tow a 32ft horse trailer and don't know what life would be like with out it.
__________________
01 2500 CTD 6 Speed, Exhaust Brake, 90 Gallon Aux Tank, Hypertech Stage 3, Dual Lift Pumps. Running B20 24/7.
96 Ram 1500 318 Magnum, Bone Stock.
Old 07-21-2006, 05:12 AM
Ralph78 Ralph78 is offline
Drew,
I have checked with an ATS Tech. Rep. (He gave me a lot of good data "Off the Record", because he is told to follow the standard recommendation from PacBrake). I also checked with several local Diesel experts that are fam. with PacBrake and have quite a lot of exp. with the older model I have. I have the very early model PacBrake, it has a very small cylinder. Apparently the cylinder size was increased substantially because the small cyclinder on the old PacBrake would not build much back pressure. I had a test run today with a device attached that would give the pressure the PacBrake generates. backing off from 2600 RPM in various gears, the maximum back pressure generated was 21 PSI. By blocking the EGR valve with a thin metal plate, (designed for the job), the maximum pressure was 25 PSI. and the slowing effect was improved, BUT now my check engine light stays on, the code is "EGR Failure".
I drove a 97 3500 12 Valve with the late style PacBrake and there was a considerble improvement over my PacBrake. (He does not have heavy exhaust valve springs, and tows over the GrapeVine to the Port of Los Angeles, from Bakersfield 3 times a week with a 9,000 trailer for the past two years, about 80,000 miles on his truck after putting the PacBrake on when he upgraded his transmission and TQ. His total milage is 370,000 Orig. Engine, 4th trans TQ, so he upgraded to heavy duty units, not ATS, 80,000 miles back, but I forgot the brand name, the TQ was someones "Triple Disk". So at this point I don't plan to upgrade the exhaust valve springs. When and If I replace my old style PacBrake with a new one to get a better slowing effect, I will consider replacing the exhaust valve springs.
I am still open to any info on my PacBrake/Valve Spring Question, so if anyone else out there has experience with the older style PacBrake on a 12 Valve Second Gen. CTD truck, please let me know what your experiences were. I will go for the heavy springs if really required.
Thanks for all the comments and help.
Ralph
__________________
1998 12 V 3500 Laramie SLT Quad Cab Dually RWD
Banks Intake & Exhaust, #10 Fuel Plate
ATS Stage 5 Trans. & 5 Star Tq Convt
Commander TC Lockup Controller, PacBrake
Gear Vender Overdrive
65 Gal TransferFlo AUX Tank&Tool Box
Sprayin Bed liner
Old 07-23-2009, 08:15 PM
rph44 rph44 is offline
Angry Dodge Jacob Brake
Quote:
Originally Posted by Josh View Post
I was curious if anyone had an engine brake from Jacob's on their diesels and how they like them and if they are worth the price. I got $1,600.00 installed the last time I called the dealer.
Josh
I have a Dodge Jacobs Exhaust brake that was installed before I picked it up. I am stranded in Colorado with a broken defective bracket which cracked. To get a new bracket I have to purchase the compete kit for $1600.00. I would suggest the B & D exhaust brake their vacuum pump is not installed on the serpentine belt like the Dodge it has a electric vacuum pump. Good Luck.
__________________
Robert P. Hillaker
Old 07-23-2009, 10:49 PM
Grr287 Grr287 is offline
Vehicle: 2005 Ram 5.9L CTD 4WD, QC, SB
i want an exhaust brake like what is on my brother's 06 powerstroke. they help save the brakes...and i like hearing the exhaust/engine cut in and out.
__________________
If it don't make money, it don't make sense.
Old 07-26-2009, 02:04 PM
purplhrt91's Avatar
purplhrt91 purplhrt91 is offline
2009 Dodge Ram 3500
Vehicle: 09 RAm 3500 Laramie
I got an 09 3500 Laramie that came with a Engine Brake installed.
I pull a 38 foot 5th wheel Montana, and I really love having it. It helps slow me down going down steep hills, let alone the fact that it will save on brake wear.
__________________
Freedom wasn't FREE.....SOMEONE earned it for you!!!
[center]
Old 07-29-2009, 12:36 AM
gtxpooch gtxpooch is offline
[quote=Josh;277663] Sorry, can't find delete button.
Old 07-29-2009, 12:40 AM
I live in Colorado and have a 32 ft fifth wheel travel trailer that I tow to go camping and looking to add a small trailer behind that. I have a lot of experience with them on the big trucks ie semi's and they work well, I know that they stopped putting them in for a while but never heard why. When I bought my 04.5 last year in sept. they weren't putting them on at that time do to a problem but I never heard for what.
Mine will hold my truck/trailer(10K) at 60 mph coming down Eisenhower Tunnel and Vail Pass no problem. It does help with the brakes too.
__________________
06 CTD Auto/3.73's, Edge/Attitude,Cummins Jake Brake,High Idle,
99 Neon Sport
69 Gtx 440 HP2 N96 #matching
68 Sport Satellite #matching
Tags
2005, 2008, 2500, brake, cummins, dodge, dually, engine, exhaust, jacob, jacobs, jake, laramie, ram, semi, sounds
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
