Replacing Pinion and Carrier Bearings
I've done some searching and found that when replacing the gears the pinion spacing needs to be checked and redone for proper gear alignment. I am only replacing the bearings on both the pinion gear and the center carrier in the rear end. Does anybody know if I will need to do all the same steps or will reusing the current shims give me the proper alignment?
Thanks in advance!
Thanks in advance!
