Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Whats the most you towed with you Dakota
Old 04-14-2013, 04:42 PM
Dakota~N~Camaro's Avatar
Dakota~N~Camaro
Dakota~N~Camaro is offline
Default Whats the most you towed with you Dakota
So whats the most you ever pulled, and how often do you do it.
I got the 4.7 auto 4x4 I pull a 2,300LB tandem axle flat bed with a 3000LB tractor or 3400LB Camaro
Don't use a W/D hitch but fixin to buy one, have a brake controller
Also pull a 18' Stingray Bowrider, and a 500LB 4x8 with a 700LB GT or 450LB Recon
Old 04-14-2013, 11:57 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
I usually tow my 5,000lb travel trailer around about 3-4 times a year. There are the other few times I tow some projects home or to other friends houses.
These pictures were before my SAS.
1950 Desoto
Attached Thumbnails Whats the most you towed with you Dakota-crazy4x4rt-68656-albums-1993-dakota-5-9-4x4-105-picture-towing-my-23ft-trailer-9910.jpg   Whats the most you towed with you Dakota-crazy4x4rt-68656-albums-1993-dakota-5-9-4x4-105-picture-towing-my-23ft-trailer-9909.jpg   Whats the most you towed with you Dakota-3-crazy4x4rt-68656-albums-1950-desoto-custom-408-picture-1950-desoto-getting-towed-home-after-ge.jpg
Old 04-16-2013, 04:46 PM
Dakota~N~Camaro
Originally Posted by Crazy4x4RT
I usually tow my 5,000lb travel trailer around about 3-4 times a year. There are the other few times I tow some projects home to other friends houses.
Nice T.T. , I love the older "classic" RV's they just seem so much more quaint and relaxing that modern rigs
I see you are not running a W.D. hitch, susprising to have no squat, you running air bags or helpers?? Also running a brake controller??
Old 04-16-2013, 06:21 PM
Crazy4x4RT's Avatar
Crazy4x4RT
On the rear I have leaf springs from a Ram 2500, that is more then enough to keep the rear from sagging. LOL
Yes I got an electronic brake controller, I'm not sure what brand but something simple that does the job. I can't imagine towing a trailer that large without electronic brakes. It is 25ft long.
Here is a few more pictures, it took me a while to dig these out.
Here is a project I towed to my cousins. I like to label this photo as taking out the trash, LOL. JK
Before the travel trailer we had a pop up, it was a large pop up too. I hated that thing so much.
Old 04-16-2013, 07:16 PM
Dakota~N~Camaro
Are 2500 springs direct bolt on??
Old 04-16-2013, 07:29 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Kinda is a direct bolt on. First of all Ram 2500 came with 2.5in and 3in wide springs. Ours are 2.5in so only the 2.5in wide leaf springs will work. You will need to replace the lower springs of your spring pack with the ones out of the Ram.
Here is a quick picture of my setup, this was before the SAS.
Attached Thumbnails Whats the most you towed with you Dakota-1-crazy4x4rt-68656-albums-1993-dakota-5-9-4x4-105-picture-93-dakota-rear-axle-and-soa-springs-ra.jpg
Old 05-12-2013, 12:42 AM
rx7_dude2003's Avatar
rx7_dude2003
rx7_dude2003 is offline
2wd rear axle
Old 05-14-2013, 10:01 PM
Dakotaracehauler's Avatar
Dakotaracehauler
Dakotaracehauler is offline
99' 3.9l Dakota, I tow a 1984 Celica on an open trailer, maybe 4200-4500lbs add about 200-300lbs of tools and parts in the bed aswell, I am at the maximum allowed I think although it handles it great, just a little underpowered on hills. I do it about 15 times a year.
Old 06-05-2013, 08:49 PM
vantage08's Avatar
vantage08
vantage08 is offline
Wow! they tow more than I thought! I'll post pics of my 06 4.7 with the trailer soon.
Old 06-05-2013, 08:54 PM
Deadsquiggles's Avatar
Deadsquiggles
Deadsquiggles is offline
I have a 2005 Dakota with the 4.7 and 3.55s and I've towed about 4000lbs of broken tile in a trailer that weighed 1500 pounds, plus a toolbox in the bed with about 300 lbs in that so probably around 6000 pounds in total and it did just fine. A little sluggish but handled it very well.
Quick Reply: Whats the most you towed with you Dakota
