DTC for the Powertrain 1.4 turbo - DodgeForum.com
Dodge Dart The Dodge Dart forum is the place for all Dart 2013+ Owners Discussion
Old 06-22-2012, 10:52 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Default DTC for the Powertrain 1.4 turbo
P0016-crankshaft/camshaft timing misalignment
p0031-o2 sensor 1/1 heater circuit low
p0032-o2 sensor 1/1 heater circuit high
p0033-turbocharger surge valve control circuit open
p0034-turbocharger surge valve control circuit low
p0035-turbocharger surge valve control circuit high
p0037-o2 sensor 1/2 heater circuit low
p0038-o2 sensor 1/2 heater circuit high
p0054-o2 sensor 1/2 heater resistance
p0069-manifold pressure/barometric pressure correlation
p006c-map-turbocharger inlet pressure correlation
p006d-barometric pressure - inlet air pressure correlation
p0071-ambient air temperature sensor performance
p0072-ambient air temperature sensor circuit low
p0073-ambient air temperature sensor circuit high
p0105-manifold absolute pressure sensor / barometric pressure sensor circuit
p0106-manifold absolute pressure sensor performance
p0107-manifold absolute pressure sensor circuit low
p0108-manifold absolute pressure sensor circuit high
p0111-intake air temperature sensor rationality
p0112-intake air temperature sensor circuit low
p0113-intake air temperature sensor circuit high
p0114-intake air temperature sensor intermittent
p0116-engine coolant temperature sensor circuit performance
p0117-engine coolant temperature sensor circuit low
p0118-engine coolant temperature sensor circuit high
p0119-engine coolant temperature sensor circuit intermittent
p0122-throttle position sensor 1 circuit low
p0123-throttle position sensor 1 circuit high
p0128-thermostat rationality
p012b-turbo pressure sensor performance
p0130-o2 sensor 1/1 circuit
p0131-o2 sensor 1/1 circuit low
p0132-o2 sensor 1/1 circuit high
p0133-o2 sensor 1/1 slow response
p0135-o2 sensor 1/1 heater performance
p0137-o2 sensor 1/2 circuit low
p0138-o2 sensor 1/2 circuit high
p0139-o2 sensor 1/2 slow response
p0140-o2 sensor 1/2 no activity detected
p0141-o2 sensor 1/2 heater performance
p0171-fuel system 1/1 lean
p0172-fuel system 1/1 rich
p0197-engine oil temperature sensor circuit low
p0198-engine oil temperature sensor circuit high
p0201-fuel injector 1 circuit open
p0202-fuel injector 2 circuit open
p0203-fuel injector 3 circuit open
p0204-fuel injector 4 circuit open
p0219-engine overspeed
p0222-throttle position sensor 2 circuit low
p0223-throttle position sensor 2 circuit high
p0234-turbocharger overboost condition
p0237-turbo boost pressure sensor circuit low
p0238-turbo boost pressure sensor circuit high
p0243-turbocharger wastegate control circuit
p0245-turbocharger wastegate control circuit low
p0246-turbocharger wastegate control circuit high
p0261-injector 1 control circuit low
p0262-injector 1 control circuit high
p0264-injector 2 control circuit low
p0265-injector 2 control circuit high
p0267-injector 3 control circuit low
p0268-injector 3 control circuit high
p0270-injector 4 control circuit low
p0271-injector 4 control circuit high
p0298-engine oil temperature too high
p0299-turbocharger underboost condition
p0300-multiple cylinder misfire
p0301-cylinder 1 misfire
p0302-cylinder 2 misfire
p0303-cylinder 3 misfire
p0304-cylinder 4 misfire
p0315-no crank sensor learned
p0324-knock control system
p0325-knock sensor 1 circuit
p0326-knock sensor 1 circuit performance
p0327-knock sensor 1 circuit low
p0328-knock sensor 1 circuit high
p0335-crankshaft position sensor circuit
p0339-crankshaft position sensor intermittent
p0340-camshaft position sensor circuit
p0342-camshaft position sensor circuit low
p0343-camshaft position sensor circuit high
p0351-ignition coil 1 primary circuit
p0352-ignition coil 2 primary circuit
p0353-ignition coil 3 primary circuit
p0354-ignition coil 4 primary circuit
p0420-catalyst efficiency (bank 1)
p0440-general evap system failure
p0441-evap purge system performance
p0444-evap purge solenoid circuit open
p0451-fuel tank pressure sensor performance
p0452-evap pressure switch stuck closed
p0455-evap purge system large leak
p0456-evap purge system small leak
p0457-loose fuel cap
p0458-evap purge solenoid low
p0459-evap purge soleniod circuit high
p0461-fuel level sensor 1 performance
p0462-fuel level sensor 1 circuit low
p0463-fuel level sensor 1 circuit high
p0480-cooling fan 1 control circuit
p0481-cooling fan 2 control circuit
p0483-fan performance
p0484-cooling fan over current
p04ab-purge control valve circuit open
p04ac-purge control valve circuit low
p04ad- purge control valve circuit high
p0500-no vehicle speed sensor signal
p0501-vehicle speed sensor 1 performance
p0506-idle speed performance lower than excepted
p0507-idle speed performance higher than excepted
p050b-cold start ignition timing performance
p0513-invalid skim key
p0520-engine oil pressure sensor circuit
p0532-a/c pressure sensor circuit low
p0533-a/c pressure sensor circuit high
p0562-battery voltage low
p0563-battery voltage high
p0564-speed control switch 1
p0571-brake switch 1 performance
p0572-brake switch 1 stuck on
p0573-brake switch 1 stuck off
p05a4-active grille shutter "a" control circuit high
p05a5- grille shutter "a" control circuit low
p0601-internal memory checksum invalid
p0604-internal control module ram error
p0605-internal control module rom
p0606-internal ecm processor
p0607-ecu internal performance
p060b-etc a/d ground performance
p060c-internal control module main processor performance
p0615-starter control circuit open
p0616-starter control circuit low
p0617-starter control circuit high
p061a-internal control module torque performance
p0625-generator field control circuit low
p0626-generator field control circuit high
p0627-fuel pump relay circuit
p0628-fuel pump control circuit low
p0629-fuel pump control circuit high
p062f-internal control module eeprom error
p0633-skim secret key not stored in pcm
p0641-sensor reference voltage 1 circuit
p0645-a/c clutch relay circuit
p0646-a/c control circuit low
p0647-a/c clutch relay control circuit high
p0651-sensor reference voltage 2 circuit
p0658-actuator supply voltage "a" circuit low
p0659-actuator supply voltage "a" circuit high
p0685-asd/main control circuit
p0686-asd/main control circuit low
p0687-asd/main control circuit high
p0691-cooling fan 1 control circuit low
p0692-cooling fan 1 control circuit high
p0693-cooling fan 2 control circuit low
p0694-cooling fan 2 control circuit high
p0697-sensor reference voltage 3 circuit
p0703-brake switch 2 performance
p0704-clutch switch input circuit
p0831-clutch pedal switch 1 circuit low
p0832-clutch pedal switch 1 circuit high
p083f-clutch pedal switch "a"/"b" correlation
p0850-park/neutral switch performance
p101a-cylinder 1 oil supply solenoid valve return control circuit
p101b-cylinder 2 oil supply solenoid valve return control circuit
p101c-cylinder 3 oil supply solenoid valve return control circuit
p101d-cylinder 4 oil supply solenoid valve return control circuit
p1021-cylinder 1 oil supply solenoid valve component damage
p1022-cylinder 2 oil supply solenoid valve component damage
p1023–cylinder 3 oil supply solenoid valve component damage
p1024-cylinder 4 oil supply solenoid valve component damage
p1025-cylinder 1 oil supply solenoid valve under voltage
p1026-cylinder 1 oil supply solenoid valve over voltage
p1027-cylinder 2 oil supply solenoid valve under voltage
p1028–cylinder 2 oil supply solenoid valve over voltage
p1029-cylinder 3 oil supply solenoid valve under voltage
p102a-cylinder 3 oil supply solenoid valve over voltage
p102b-cylinder 4 oil supply solenoid valve under voltage
p102c-cylinder 4 oil supply solenoid valve over voltage
p1031-cylinder 1 oil supply solenoid valve driver voltage implausible
p1032-cylinder 2 oil supply solenoid valve driver voltage implausible
p1033-cylinder 3 oil supply solenoid valve driver voltage implausible
p1034-cylinder 4 oil supply solenoid valve driver voltage implausible
p1035-cylinder 1 oil supply solenoid valve open circuit
p1036-cylinder 1 oil supply solenoid valve driver short to battery
p1037-cylinder 1 oil supply solenoid valve driver short to ground
p1038-cylinder 2 oil supply solenoid valve driver open circuit
p1039-cylinder 2 oil supply solenoid valve driver short to battery
p103a-cylinder 2 oil supply solenoid valve driver short to ground
p103b-cylinder 3 oil supply solenoid valve driver open circuit
p103c-cylinder 3 oil supply solenoid valve driver short to battery
p103d-cylinder 3 oil supply solenoid valve driver short to ground
p103e-cylinder 4 oil supply solenoid valve driver open circuit
p103f-cylinder 4 oil supply solenoid valve driver short to battery
p1040-cylinder 4 oil supply solenoid valve short to ground
p1041-implausible data from cylinder 1 oil supply solenoid valve received
p1042-implausible data from cylinder 2 oil supply solenoid valve received
p1043-implausible data from cylinder 3 oil supply solenoid valve received
p1044-implausible data from cylinder 4 oil supply solenoid valve received
p1045-cylinder 1 oil supply solenoid valve voltage out of range
p1046-cylinder 1 oil supply solenoid valve overcurrent
p1047-cylinder 2 oil supply solenoid valve voltage out of range
p1048-cylinder 2 oil supply solenoid valve overcurrent
p1049-cylinder 3 oil supply solenoid valve voltage out of range
p104a-cylinder 3 oil supply solenoid valve overcurrent
p104b-cylinder 4 oil supply solenoid valve voltage out of range
p104c-cylinder 4 oil supply solenoid valve overcurrent
p1061-cylinder 1 oil supply solenoid valve stuck
p1062-cylinder 2 oil supply solenoid valve stuck
p1063-cylinder 3 oil supply solenoid valve stuck
p1064-cylinder 4 oil supply solenoid valve stuck
p1065-cylinder 1 oil supply solenoid valve switch on time out of range
p1066-cylinder 1 oil supply solenoid valve switch off time out of range
p1067-cylinder 2 oil supply solenoid valve switch on time out of range
p1068-cylinder 2 oil supply solenoid valve switch off time out of range
p1069-cylinder 3 oil supply solenoid valve switch on time out of range
p106a-cylinder 3 oil supply solenoid valve switch off time out of range
p106b-cylinder 4 oil supply solenoid valve switch on time out of range
p106c-cylinder 4 oil supply solenoid valve switch on time out of range
p1115-general temperature rationality
p1128-closed loop fueling not achieved - bank 1
p1185-general pressure sensor correlation
p1212-engine oil temperature high - rpm limited
p1239-engine oil temperature too low
p1302-transmission self-learning signal not received
p1303-implausible transmission self-learning signal received
p1456-fuel tank pressure sensor circuit low
p1457-fuel tank pressure sensor circuit high
p1523-vcm high pressure oil absent
p1524-oil pressure out of range - camshaft advance/retard disabled
p1572-brake pedal stuck on
p1573-brake pedal stuck off
p1593-speed control switch 1/2 stuck
p1607-pcm internal shutdown timer rationality too slow
p16a0-etc motor error position
p16a1-etc self learning (battery)
p16a2-etc motor self-learning (limp home position)
p16a3-etc motor self-learning (mechanical throttle closure)
p16a4-etc motor self-learning (spring closure)
p16a5-etc motor self learning (spring opening)
p16aa-cruise control system - vehicle speed too high
p16ab-cruise control system - vehicle speed too low
p1c57-reductant control module shutdown - crash event detected
p1cea-boost side evap purge system performance
p1d6d-ags circuit over temperature
p1d73-ags performance
p1d7f-etc self-learning failure
p1d80-internal control module eeprom error
p1e09-closed loop fueling not achieved - bank 1 - downstream
p2096-downstream fuel trim system 1 lean
p2097-downstream fuel trim system 1 rich
p2100-electronic throttle control motor circuit
p2101-electronic throttle control motor performance
p2102-electronic throttle control motor circuit low
p2103-electronic throttle control motor circuit high
p2115-accelerator pedal position sensor 1 minimum stop performance
p2116-accelerator pedal position sensor 2 minimum stop performance
p2122-accelerator pedal position sensor 1 circuit low
p2123-accelerator pedal position sensor 1 circuit high
p2127-accelerator pedal position sensor 2 circuit low
p2128-accelerator pedal position sensor 2 circuit high
p2135-throttle position sensor 1/2 correlation
p2138-accelerator pedal position sensor 1/2 correlation
p2166-accelerator pedal position sensor 1 maximum stop performance
p2167-accelerator pedal position sensor 2 maximum stop performance
p2172-high airflow/vacuum leak detected (instantaneous accumulation)
p2173–throttle actuator control system - high air flow detected
p2175-throttle actuator control system - low air flow detected
p2226-barometric pressure sensor
p2227-barometeric pressure sensor rationality
p2228-barometric pressure circuit low
p2229-barometric pressure circuit high
p2237-o2 sensor 1/1 pump cell current circuit open
p2238-o2 sensor 1/1 pump cell current circuit low
p2239-o2 sensor 1/1 pump cell current circuit high
p2243-o2 sensor 1/1 reference voltage circuit open
p2244-o2 sensor reference voltage performance - bank 1 sensor 1
p2245-o2 sensor 1/1, 2/1 reference voltage circuit low
p2246-o2 sensor 1/1 reference voltage circuit high
p2261-turbocharger bypass valve - mechanical
p2262-turbocharger boost pressure not detected - mechanical
p2271-o2 sensor 1/2 signal stuck rich
p2299-brake pedal position/accelerator pedal position incompatible
p2301-ignition coil 1 circuit high
p2304-ignition coil 2 circuit high
p2307-ignition coil 3 circuit high
p2310-ignition coil 4 circuit high
p2600-electric coolant pump control circuit open
p2602-electric coolant pump control circuit low
p2603-electric coolant pump control circuit high
p2610-pcm internal shutdown timer rationality too fast
p2a00-o2 sensor 1/1 circuit performance
u0001-high speed can communication bus
u0002-high speed can communication bus performance
u0101-lost communication with tcm
u0103-lost communication with electric gear shift module
u0121-lost communication with anti-lock brake system (abs) control module
u0131-lost communication with power steering control module
u0140-lost communication with body control module
u0151-lost communication with occupant restraint controller (orc)
u0155-lost communication with cluster/ccn
u0212-lost communication with scm
u0402-invalid data received from tcm
u0405-invalid data received from cruise control module
u0415-invalid data received from anti-lock brake system (abs) control module
u0418-invalid data received from brake system control module
u0420-invalid data received from power steering control module
u0422-invalid data received from body control module
u0423-implausible data received from cluster/ccn
u0426-invalid data received from vehicle immobilizer control module
u0427-invalid data received from vehicle security control module
u0429-implausible data received from scm
u1120-lost wheel distance message
u110c-lost fuel level message
u110e-lost ambient temperature message
u11b9-lost communication with rf hub
u11e9-lost communication with ags
u1403-implausible fuel level signal received
u1412-implausible vehicle speed signal received
u1417-implausible left wheel distance signal received
u1418-implausible right wheel distance signal received
Old 06-24-2012, 07:27 PM
master tech
Electronic Shift Module
P0607-29-ECU INTERNAL PERFORMANCE-SIGNAL INVALID
P0607-42-ECU INTERNAL PERFORMANCE-GENERAL MEMORY FAILURE
P0607-44-ECU INTERNAL PERFORMANCE-DATA MEMORY FAILURE
P0607-45-ECU INTERNAL PERFORMANCE-PROGRAM MEMORY FAILURE
P0607-47-ECU INTERNAL PERFORMANCE-WATCHDOG / SAFETY FAILURE
P0607-48-ECU INTERNAL PERFORMANCE-SUPERVISION SOFTWARE FAILURE
P0607-62-ECU INTERNAL PERFORMANCE-SIGNAL COMPARE FAILURE
P0826-01-UP/DOWN SHIFT SWITCH-GENERAL ELECTRICAL FAILURE
P1C86-1D-PRNDL DISPLAY-CIRCUIT CURRENT OUT OF RANGE
P1C86-82-PRNDL DISPLAY-ALIVE / SEQUENCE COUNTER INCORRECT / NOT UPDATED
P1C86-83-PRNDL DISPLAY-VALUE OF SIGNAL PROTECTION CALCULATION INCORRECT
P1C86-92-PRNDL DISPLAY-PERFORMANCE OR INCORRECT OPERATION
U0002-00-CAN C BUS OFF PERFORMANCE
U0100-00-LOST COMMUNICATION WITH ECM/PCM
U0101-00-LOST COMMUNICATION WITH TCM
U0140-00-LOST COMMUNICATION WITH BODY CONTROL MODULE
Old 06-26-2012, 12:53 AM
master tech
Diagnosis and Testing Electronic Power Steering (EPS)
C0051-04 STEERING WHEEL POSITION SENSOR - SYSTEM INTERNAL FAILURES
C0051-2F STEERING WHEEL POSITION SENSOR - SIGNAL ERRATIC
C0051-31 STEERING WHEEL POSITION SENSOR - NO SIGNAL
C0051-54 STEERING WHEEL POSITION SENSOR - MISSING CALIBRATION
C1592-01 ELECTRONIC POWER STEERING MOTOR CIRCUIT - GENERAL ELECTRICAL FAILURE
C1592-16 ELECTRONIC POWER STEERING MOTOR CIRCUIT - CIRCUIT VOLTAGE BELOW THRESHOLD
C1592–29 ELECTRIC POWER STEERING MOTOR CIRCUIT — SIGNAL INVALID
C1592-4B ELECTRONIC POWER STEERING MOTOR CIRCUIT - OVER TEMPERATURE
C1592-74 ELECTRONIC POWER STEERING MOTOR CIRCUIT - ACTUATOR SLIPPING
C1592-98 ELECTRONIC POWER STEERING MOTOR CIRCUIT - COMPONENT OR SYSTEM OVER TEMPERATURE
C15C1-00 EPS MECHANICAL PERFORMANCE
C15CA-00 BRAKE SYSTEM MODULE - EVENT INFORMATION
C2100-16 BATTERY VOLTAGE LOW - CIRCUIT VOLTAGE BELOW THRESHOLD
C2101-17 BATTERY VOLTAGE HIGH - CIRCUIT VOLTAGE ABOVE THRESHOLD
C2129-13 BATTERY VOLTAGE - CIRCUIT OPEN
C2202-00 ORIGINAL VIN MISMATCH/MISSING
C2217-00 ELECTRIC POWER STEERING MODULE INTERNAL
C221C-00 ECU FLASH REQUIRED
C221F-00 ECU NOT INTIALIZED
U0001-87-CAN-C BUS MISSING MESSAGE
U0002-00 CAN C BUS OFF PERFORMANCE
U0121-00-LOST COMMUNICATION WITH ANTI-LOCK BRAKE SYSTEM (ABS) CONTROL MODULE
U0140-00-LOST COMMUNICATION WITH BODY CONTROL MODULE (BCM)
U0401-86-IMPLAUSIBLE DATA RECEIVED FROM ECM/PCM - SIGNAL INVALID
U0415-00 IMPAUSIBLE DATA RECEIVED FROM ABS
U0415-86 IMPAUSIBLE DATA RECEIVED FROM ABS - SIGNAL INVALID
U0422-00 IMPAUSIBLE DATA RECEIVED FROM BODY CONTROL MODULE
Old 09-22-2012, 03:16 AM
SumAmerican's Avatar
SumAmerican
SumAmerican is offline
and this is why we love ya master tech
Related Topics
Thread
Forum
Replies
Last Post
DerekShiekhi
Brand News, Concepts & Rumors
5
10-29-2015 06:08 PM
2 Dodge Vans
K-Cars
4
10-15-2015 10:42 AM
t480
2nd Gen Neon
1
10-13-2015 01:12 PM
1985imperial
2nd Gen Dakota
4
10-01-2015 10:11 PM
DieselNeck23
3
09-22-2015 09:19 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
