you dont have a 3speed, 3.0 daytonas w.automatic only came with an od trans. your trans is in limp in and stuck in 2nd gear. you'll need to have it scanned buy a place besides autozone and the key flash code retreival system will not work! that only gives engine codes you could do a 5speed conversion but it's a lot of work. you need to find a rare 543 trans, clutch pedals, shifter, cables, change pcm and redo all the wiring in the engine compartment.
