DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Daytona
Thread Tools Search this Thread
Old 10-26-2009, 04:26 PM
scarletfire scarletfire is offline
Exclamation New short block 2.5L ignition trouble
Okay, first off, this is for a 94 Shadow. It had a 2.2L in it that blew out the oil pan seal and then locked up #3 rod. I picked up a 2.5L short block from a friend that had just been rebuilt. Did the swap, everything went smooth. I go to start the car. All it does is turn over and over. I went through all the usual steps and discovered there was no injector pulse.First thing I did was test the wires from the comp. to the injector. They both had continuity and ohm'd just fine. I also have the req. fuel pressure. Just to fill in any questionable gaps. I am on a VERY tight budget, so I threw the cheapest thing at it first, the ASD relay. No luck. Okay, so next my friend had an extra HAL effects (pick-up coil) lying around. No dice. Next, I finally broke down and replaced the computer thinking that HAD to be the problem. Still, no luck. What are the odds that my friend sent a bad pick-up coil? I honestly find it hard to believe he would keep a bad one lying around. I am at a loss. Any help would be appreciated. And, by the way, of course the engine ran before the swap. And the battery is in great shape.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-26-2009, 10:58 PM
92dak5.24x4 92dak5.24x4 is offline
do you have spark? do you have a turbo motor? did you verify the distributor is turning?
Old 11-02-2009, 05:11 PM
sorry for the delay. things have been hectic. Yes I have spark, and the engine will run if i force feed fuel. I am getting 60psi of fuel to the injector. I am just not getting a 12v pulse to fire the injector.
Old 11-02-2009, 05:28 PM
circumventor circumventor is offline
Quote:
i seen the wrong dist used wher a n/a dis was used and it dont have the sync winbdow to trigger the injectors
Old 11-02-2009, 06:11 PM
yeah this is same distributor i used in the last block. the only thing that has changed is the rotating assembly. Really has me baffled.
Old 11-02-2009, 08:32 PM
Sounds like you missed hooking something up or maybe the HEP is bad.
Old 11-06-2009, 03:07 PM
FFEMTC FFEMTC is offline
The HEP can't be bad if he has spark.
Check fault codes: http://www.allpar.com/fix/codes/index.html
Old 11-06-2009, 08:30 PM
He never answered my question about if it was a turbo or not. If it was a turbo, darn right it could have spark with a bad HEP on the other pickup for injector sync.
Tags
no injector pulse
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
