Power Steering Pump
Jack up the front, both tires off the ground. Top off the power steering fluid. Engine off, turn the steering wheel lock to lock 3 or 4 times. Recheck fluid. Start the engine, turn steering lock to lock a few times. Turn off engine. Check fluid, if its frothy, let it sit for 30 minutes or so, then top of the fluid, start it up, and crank it lock to lock a few more times. Keep doing that till the fluid no longer gets frothy.
I have a pretty dismal view of the aftermarket power steering pumps. I went through three of them, before I got one that actually worked, and it still whines...... New pump, new rack, new pressure line......
The following users liked this post:
cooler (07-06-2020)
Thank you! I will give that a try. From what I have read, however, that typically can occurs if there is a break in a seal or PS pressure line where the pump will draw air into the system. Thoughts? Also do you know if there is a drain or bleed valve on the pump that comes with this Daytona? Thank you.
No drain or bleed valve I am aware of. And the only place there should be suction, is where the pump is drawing from the reservoir. Not sure how the setup is on yours, haven't seen a Daytona in years around here..... but, if you have a significant enough leak, that the pump can draw air though, then it would likely drip fluid when the engine WASN'T running as well...... I would think......
When you replace a pump, or line, there IS going to be air in the system, it can be a real pain to get it all purged out. Patience is the key.
Trending Topics
