- 89 2.5l restore or sell?
- Stubborn Zerk Fittings
- pcm problem
- First Generation 4X4 shock Replacement
- Tire Noise or 5-speed Noise?
- Really weird problems intermittent miss gets real bad once it warms up
- Front shocks on 93 Dakota wd
- General Parts Availability, 1990 3.9
- ECM programing
- Coolant Recovery-Constatly Needing Refill
- 1990 Dakota fuel tank
- Steele Rubber Products Universal fit outer belt line mouldings.
- Rims and a Seat...1988
- '95 Dakota Sport lower control arm
- 2003 2004 durango wheels on 1 st generation
- Part numbers for 4X4 Universal Joints (1996)
- Project truck for inspiration
- 1996 dakota sport 3.9
- Need Chrysler paint code for lower body color charcoal grey metallic
- Fixing deer accident damage...I guess
- Front Lift/Levelling Spacers
- Car Crashed into Me and Insurance Co. probably will total my '91 Dakota - advice?
- Ignition switch wiring
- New crankshaft?
- Drive shaft
- OEM Wheel Project
- Chrome Valve Covers
- Radiator Drain Plug (plastic)!
- The 88 has presented a new joke for me and I'm not laughing
- Iso Sealed beam headlight buckets
- Is Your 1st Gen Dakota Rusting Anywhere?
- 95’ Dakota 3.9 to 360 swap question
- Anyone have a parts 1st gen Dak with good rear wheel arches?
- truck tries to crank in gear??
- 1st gen kota fenders
- Finally - headlights rewired
- RalphP has passed away
- 88 Dakota fuel tank swap.
- i screwed up.
- Anyone know where I can find some 14" 1st gen rims
- 96 Dakota 2wd V6 to V8 swap
- Think I found my color scheme
- 1996 Dakota Battery wrong connection
- Code not found in FSM
- Dakota Body Side Moudling
- 1989 Dakota Sport convertible Part Needed!
- 94 Dodge Dakota
- steering column removal?
- 89 RMT535D1 transmission??
- y-pipe/front pipe swap 1994 to 1992
- Multiple state car haul
- Help me identify this colour, please
- Plenum gasket
- Pressing torsion bar out of lower control arm
- Headlight and Cluster switch
- funny little switch
- Zerk fittings here? yes or no?
- Headlamp plug-in Melted
- New to me 1989 Dakota Sport Convertible
- Headlamp bucket adjuster cable removal?
- Ground loop
- Rag and matches
- RE : 1989 Shelby Convertible Dakota swap
- 1st gen VIN decoder
- New to me 1989 Dakota Sport Convertible, new member.
- Manually turn crank.
- fuel injector
- 1992 3.9 2wd wiring
- Solid axle conversion
- 87 Dakota alternator question
- 1995 Dakota heater problem
- gen 1 Beltlines search
- Problems with Rock Auto
- No ac in florida, send help
- Got Lucky at the JY I hope
- Automatic Trans vs Stick
- 1996 First Generation Metric or SAE fasteners?
- Found This On Driver Floorboard
- Extended cab rear floor extender
- fuse or relay
- Ball Joints
- Tailgate anti-theft lock
- overheated
- Transmission Position Sensor
- 1991 Dakota Driver side door, window lift motor
- brake light and abs light on dash stays on.
- Wipers Turn On Automatically
- Jumper cables got crossed during a jumpstart
- 1994 dodge dakota 5.2 vacuum line doesn't look right
- Not trying to piss anybody off. crank no start, Need help
- Beach Driving Maintenance
- Crank no start 92 318. Extensive effort, no results.
- New headliner
- How much are you paying for truck insurance?
- 96 Dakota Bumper
- Clicking sound
- Which Octane/Which Engine?
- Looking for a 4WD,V8/Club Cab
- Drone footage of my Dakota in the Rockies
- Air diverter valve vacuum line disconnected
- Front end groaning noise
- Where can I get a Factory Service Manual?
- Suggestions for winter
- Lil Red Express
- Factory rear sway bar on 1990 Dakota?
- Positive camber
- My '94 suspension is wonky
- Brake lights AND turn signals don’t work. Coincidence?
- 1990 heater core replacment
- 1994 dakota waterpump
- New 16" Rims
- weird idle after having it on uneven ground
- '91 standard trans stick won't stay in reverse
- No power to auto shutdown relay
- Looking for reviews on air bag helper kits.
- Could i swap a 2.5 liter for a v6?
- wheel bearings
- 89 Dakota rear axle
- Am I/ is this crazy?
- Found a truck with even less aftermarket support than a first gen Dak!
- 88 3.9 - Can you identify this air filter
- bucket seat console Cross fitment
- 1992 Dakota front springs
- Starting problems
- wiper bushings
- I am looking for a 89 Dakota Convertibles boot. let me where I can find one
- Got lucky at the Junk Yard
- Tranny Question
- Upper control arm
- Where is the fog light switch
- Made a bed mount spare tire carrier.
- Any northern US owners block radiator?
- Anything to the Infinity sound system?
- backglass problems
- PS cooler or not PS cooler - what decides?
- What should my voltage be at the low beam headlight?
- Anyone have a Shelby?
- block drain size for tank heater nipple
- Possible misfire?
- Dodge dakota over heat
- Engine overheat
- Dakota Thunder Road
- May Buy a Scanner Tool - Which one?
- Is there any interest in a first gen Dakota front diff drop bracket
- Hey you
- Fuel Gauge
- Spark Plug Wires
- 3.9 Intake leaking oil
- checking PCM
- Transfer case question
- 1995 dodge dakota won't stay in overdrive
- How do I remove the heater/AC control panel to replace the bulb behind the controls?
- Weather Stripping--What Kind?
- 93 Dakota / Durango parts swap
- 95 Dakota BCM HELP!
- 1st gen roll pan
- DIY RE Rebuild Tips and Tricks
- Transmission cooler delete
- 92 dak auto tranny slow to go in gear.
- best location for adding manual temp gauge
- Finally back!
- dakota truck
- 1996 dodge dakota sport 2.5 fuel regulator
- Stuck in 4hi. Wont engage 2hi or. 4lo
- 94 Dakota transmission
- 96 Dakota 4x4 3.9l. Front Suspension Question. Help!!
- 91-96 Dodge Dakota obsolete parts
- Need Manual 1996 Dodge Dakota SLT 2wd 3.9L V6 magnum
- Swap a 94 318 into a 91 v6 DAK?
- 1994 Dakota blower motor replacement
- 92+ Headers on Premag Engine
- 1988 DAKOTA 3.9 v6 Push Button Heater Control
- 1988 Dakota Ram 50 Need push button climate control panel
- Some cabin water leak issues
- Should I install this sunroof?
- Anyone build an extended cab long bed Dakota?
- Engine coolant temp switch broken off
- 2nd Gen wheels on my 1st
- 88 3.9 V6 Resto
- New Steering Wheels Suggestions
- Distributer gear. / oil pump gear
- Speaker Question
- Front Suspension Rebuild
- inner tie rod replacement
- Drive train.
- Transmission. Interchangeable? Identification
- over heating
- 96 Dodge Dakota 3.9v6
- Weatherstripping
- Dodge Dakota PCM, ECM, ECU, TCM - Plug and Play - Well Below Dealer Pricing
- Tire Tools
- Shelby Dakota Cheap Spotted.
- Posting up pictures
- Scored Factory Manual Set for my Dakota
- Manual rear window guide clip replacement
- Hack your truck
- Turbo 96 sport
- 93 Dakota 318 transmission auto swap
- Will they fit and how
- 92 Dakota built sheet.
- New to Me Dakota
- SnowMan451 - Red Dragon
- 1994 dakota lift
- manual
- Dodge Dakota LoneStar
- 95 dakota glove box removal
- V8 318 5.2L gas mileage
- 1st gen Dakota or Ranger? What do I need to know?
- Need Easy Fuel Line Repair
- dash and cup holder bezel
- 95 dak fiberglass body parts
- My first 1st Gen Dak.. Some questions
- Got a new 1993 Dakota LE 4X4 5.2L, have some questions
- 360 head questions
- Fusible link
- nightmare '93 5.2 auto/2wd
- Engine Color
- OBD connector Location?
- Tail light fuse repeated blow
- Lift on a Dakota
- Help with wiring a remote starter button
- Replace vacuum hoses
- front valance with fog light cutouts for 1990
- ever lower a Dakota?
- ASD fuse (Auto shut down) issue 96 Dakota
- Tire size Question
- code reader
- 1988 Dakota Box Swap
- What is your preferred muffler?
- New Guy looking at opinions on 1989 Dodge Dakota's value
- towing question
- owners manual
- running issues
- Overhead console
- VIN Number decoder/specifications
- 96 In Shape
- Muddy Monday: 1g Dakota Monster Mud Truck
- Leaving a old friend behind
- 1992 dodge Dakota service codes
- Muddy Monday: 1g Dakota Stops in Deep Water and Keeps on Truckin
- vacuum leak??
- np242j transfer case?
- getting ready for my SAS
- 90 dakota 3.9v6
- A little update...
- 89 dakota 4x4 v8 swap
- Trimming fenders on a 89'
- 87 Dakota "On The Road again" Kind of
- Truckin Fast Wednesday: Turbo Jeep Beats 2g Dakota
- pcm codes
