- How to make my air filter get cold air?
- Cruise Overdrive Issue
- Rims
- I put full synthetic 0w-20 in my 04 150k 3.7 Dakota. Here's what happened..
- Farmer Chic paint job.
- Air intake opinions
- Looking for a 46RE for a 2003 Dak R/T
- Transmission swap
- New project
- R/T RPM vs MPH
- 01 Dakota - High Beams
- The Pits as in Pitman Arm
- 2001 Dakota SLT 3.9L throwing 8 codes
- "PCV elbow." Does this style crankcase vent have a valve?
- Weird 3.9 intermittent rough running
- Remote start?
- Anyone need a Silver Canopy? Canopy Swap?
- What to with rusted out bump stop brackets?
- 5.9L Quad Cab ?
- Paint job
- Cargo lights on 2004 Dakota SXT
- 2000 Dakota 3.9 Cranks but not starting
- Ruptured coolant line
- Dash cap removal -
- Where does this hose go!
- Fuel pump bad
- 2003 dakota transmission governor solenoid
- 97 5.2 misfires in 3&4
- 04 dodge Dakota
- Replacing Clutch Fluid
- Body panel VIN tags?
- Tuning the 3.9L in a 2002
- 01 dakota swap
- Need help
- Bump Stop
- New kid on the forum
- 2000 5.9 automatic Dakota
- Upper Control Arm Mounts
- blower motor resistor
- Spring shackle right rear # 52019880
- Miss fire #7 cylinder
- Bang as clutch engages
- Gas Mileage
- 5.9L Magnum Specifications and Details
- OBD2 reader
- Electrical plug
- Best Transmission for 3.7L V6
- a little taste testing this morning
- Uneven control arm height?
- 2002 dodge dakota sxt 3.9L bogging down problems
- 02 Dakota 4x4 SXT Rebuild and warning
- Engine Roar in 2004 Dakota V8
- My 2nd Gen Project Trucks
- Neat info on your truck
- Stuck transfer case?
- 2WD upper control arms same as 4WD?
- Fuel Tank connections 2 or 3 on 1999 dakota sport
- Brake drums from Oreilly’s
- parking brake cable hardware
- Speed sensor
- Cam Crank sensor wiring harness connectors.
- Went shopping today...
- Shock Absorber Replacement - 2004 Dakota
- Front right brake sticks after 10-15 mins
- Rapid Deceleration
- 2002 Dakota Sport O2 Sensor Issues
- How Large is your fuel tank??
- Stupid question
- Figured I would show off my 01 Dak blow through stereo a bit.
- 00 to 03 emc and tmc
- T.O.N Number?
- 2000 dakota rear brake bleeder screw P/N
- 1998 Dodge Dakota crank, so start, cuts spark and fuel
- water pump specs
- Parts Replacement...Newbie
- insulated tube
- 01 dodge dakota 4.7l engine R&R qurstions.
- Convert from spindle to hub
- 2095 dodge Dakota 4x4 key wont turn and ABS is now on.
- How many miles on your Dakota?
- Need Wheel
- Wierd transmission problems
- I need to lower a 2002 Dodge Dakota that has been lifted
- upper control arm bumpers
- Truck wanders with bigger tires
- Comments on these gen 2 dakota wheels
- What tires and shocks are you guys running?
- Steering wheel pops out of sync after alignment
- No brake lights 04 dakota
- 99 fuel inlet update
- Help! 97'Dakota Low beams out But High Beams work
- tilt wheel
- power window/door lock/mirror bezel retaining clips
- Recently acquired 2 dakotas...
- Any pics of stock 2WD with 31-inch tires?
- 08+ intake manifold
- A/C removal
- Anyone use or heard of this engine rebulder? rebuiltengines4less
- HELP Body Lift Kit Clarification
- Replaced timing chain, know for certain TDC, no start
- QC rubber isolated counter weight at rear behind bumper?
- Busted valve cover bolt
- Bed Swap
- Dome lights
- What have I got here
- 3.9L Horror Stories?
- Old Mopar Man
- Introduction
- Looking for opinion on potential 2003 Dakota
- Is this a good deal
- Rear axle from a 1992-1993 dodge Dakota fit a 1989 dodge dakota
- Good bye and Thank you.
- 333,333 on January 11, 2018
- 1999 Dodge Dakota 5.2 Slt auto
- what are some common problems
- 331,000-plus Miles; Tell Me What I've Won, Johnny!
- Is This Worth Buying?
- Dodge Dakota PCM, ECM, ECU, TCM - Plug and Play - Well Below Dealer Pricing
- Dealership Fail Story... Stay Loyal or Not?
- Helpful forum
- Tire defect...
- I'm baaaccckkk!
- Dakota Amarok
- What tires are you running?
- New to the Dak
- Anyone move up to a Ram and hate it?
- Just Bought a Dakota
- 1998 Dakota Headlight Switch Green & Red w green wires getting really hot to the touc
- New Member
- 2nd gen Dakota fender flares
- 4x4 lift for 2cnd/3rd gen!?
- Shopping for a Dodge Dakota!! Any tips?
- Accident....
- Towing Package on '01 DD 4WD w/5-speed Manual Trans??
- rear seat lay down
- reliability issue?
- Oil Pan Removal 04 Dakota 3.7L 4WD
- LED Headlights
- 2000 Durango
- For 2wd's looking for lift
- Atlantic blue with black camper shell? Pic request
- your opinion on 5.2 headers brand
- Muddy Monday: Meet the Chemical Reaction Dakota
- Muddy Monday: Dakota Raising Hell
- 2001 Dakota used purchase
- plastic lower bumper painting
- dodge respray before during and after
- Muddy Monday: 2g Dakota slings the slop
- Hello from Argentina!
- 2001 dodge dakota 4 door with the 4.7
- Let's see your lowered Dakota!
- Check out this monster Dakota mud truck
- Radio
- if anyone was looking for a used sct tuner
- Good prices on closeout parts at RockAuto
- Cue the song...
- 1-ton Dakota??
- looking at buying...what to lookout for.
- Noticed a custom hood & spoiler on NJ CL
- 15 years with my Dakota as of today
- Opinions on mods for a 2001 Dodge Dakota
- Muddy Monday: Monster Dakota.
- Need info on 1998 Dodge Dakota SLT ECM Rebuilders
- Superchips 3950 91 tune question
- Converting radio/tape to radio/cd.
- '97 Dakota modifications
- Muffler vs. Cat-back
- Why can't the factory look this clean?
- 04 dakota 4 x 4 gas tank
- Build sheet back, explain.
- New 98 Dakota for me
- New to the forums and new to Dodges
- Why we have belt tensioners
- Muddy Monday: 2g Dakota "Relentless" Monster Truck
- looking at a 2000 Dakota for sale
- Head light cleaning tip
- Upgrades!?
- New Cosmetics :)
- leaving your truck in gear while parked.
- Muddy Monday: 2g Dakota tearing up the corn field
- Muddy Monday: 2g Dakota Monster Truck Gettin Dirty
- Truckin Fast Wednesday: Dakota Crushes Mustang
- 98 Dodge Dakota Stalls/Jerky after warm up...
- Truckin Fast Wednesday: 2g Dakota Shows a Mustang how to Drift
- 2000 dakota lift
- Muddy Monday: 2g Dakota gets into deep water
- Truckin Fast Wednesday: SinCityR/T Dakota in Action
- 2nd Gen vs Ram gas mileage comparison
- Truckin Fast Wednesday Turbo Dakota Races a Built Neon SRT4
- Polished headlights....
- Good deals on closeout parts for Dakota's at Rock Auto
- any AT Tires fit 2001 R/T extended cab?
- That orange thing in my signature
- Tow Mirrors on Dakota?
- take bed off for maintenance
- Truckin Fast Wednesday: Turbo Dakota Beats Blown Tundra
- 2004 Dodge Dakota 4x4 Radiator drain plug..
- Truckin Fast Wednesday: 2g Dakota RT Playing in the Snow
- Tire Shredding Tuesday: 2g Dakota murders its tires
- New and wanting help.
- Power steering hose.
- Looking for FSM's
- Took My Dakota to the strip for the first time.
- magnum motor rocker arms ?
- New Daily Driver...
- leave of absence
- Used 4.7 headers
- Jeep recovery vehicle
- Dak on 'roids
- post your problem here lets get it Recalled an fix for free
- Old Dakota Owner - But New Here
- I like having a part-time spool and I cannot lie,
- Time travel is possible!!
- center console
- Goals and Objectives
- 1500 leaf spring and coil spring swap to dakota slt
- possible newbie from the Ram side
- Newbie,saying hi..
- Looking at buying a dakota. NEED HELP
- Yanked a huge semi out of the snow today with my Dakota...
- ac/heater control vacuum line location
- Our career thread made the front page!
- 2016 Chevy Colorado
- p1391
- Leaving the dodge world
- Just Wanna Say Hi!!!
- 2001 dakota po355 issue
- Georgia get together
- Ethanol foe or Friend?
- Opinions on what my truck is worth.
- been fun. moved on to 2007 duramax.
- Tire noise
- Was there ever a 99 r/t superbee model??
- Performance Parts for a 99' dakota rt
- Got a new muffler!
- Spinning tires?
- Dodge Dealers Cant Ship Parts?
- "Builds" sub forum
- What does everyone do career wise
- Happy Birthday to my truck
- New Upper Control Arms - Where??
- Traded in my 2004 Dakota
- Classic Cars?
- Bovine 1, Dakota 0
- I might bid yall a farewell
- WTB looking for some used parts... 2000
- She is gone.
- 97 cold air intake
