View Full Version : Dodge Caravan
- Block Heater Cord Location
- 2004 dodge caravan
- Undetermined Oil Leak
- 5W-30 safe for engine asking for 5W-20?
- New/used 06 - what service to do?
- Dodge Caravan Oil Change Interval
- 08 Caravan no oil on dipstick
- Body Control Module Issues ?????
- Need to know official name of part for salvage yard search
- 2012 Grand Caravan Recall - REPROGRAM POWERTRAIN CONTROL MODULE
- Check Engine Code P1404 for 2008 Dodge Grand Caravan
- Side Door Won't Lock
- Intermittent grinding noise
- Remote not working on a 2013
- new steering wheel controls
- Intermittent airbag light - 2006 GC
- 2008 DVD Install into my van
- 2002 dodge caravan misfiring and other issues
- Need help finding part - mode door actuator
- Grand Caravan Pre-Purchase Inspection
- Heat block plug 2012 G/C CVP
- 2005 Grand Caravan SXT Lights not all working on auto climate control
- ignition Key wont start
- 2005 Grand Caravan 3.8L Hose help
- 08 Dodge Grand Caravan A/C Compressor and Radiator Fan not working
- Hard start issues 2000 Grand Caravan
- DVD/VES System quit working...
- 2003 Dodge Grand Caravan fuel gauge readout inaccurate
- Can a bent knuckle cause brake locking? - need expert advice on this one
- Dodge Grand Caravan Shift Indicator Lights Up All Gears
- New caravan R/T
- New caravan R/T
- Oil change for 2002 Dodge Grand 3.8
- how to remove the liftgate inner panel?
- Add Screen to 2010 Dodge Grand Caravan
- How to test fuel injector electrical without noid light
- 2010 Grand Caravan Problems
- HVAC blower issue...
- Rough shifting transmission
- Radio harness
- 2008 Grand Caravan sliding door lock
- Dodge 2003 Grand Caravan 3.3 Making Engine Noise
- speed sensor location
- 2008 caravan heater blower problem
- Changing a Tail Light
- 00 Caravan electrical problem
- 2010 Grand Caravan P1128 - Error code
- Replace belt tensioner pulley only
- 1997 Dodge Grand Caravan Only Reverses Wow...
- 1996 dodge caravan 3.3 v6
- Turns off
- Intermittent starter problems on my 96 GC 3.3l
- 2001 Dodge Caravan 3.3L
- 05 Chrysler T&C cooling system issue
- Seeking help from ABS expert - wheel locking and other symptoms
- Adding Power Rear Vent Windows- 2012 Caravan
- 2006 Dodge Caravan issue where at night the headlights work, but the tail lights wont
- 1999 dodge grand caravan transmission problem
- Dodge caravan 07 , need help pls
- Strange error msgs from 2009 Grand Caravan ...
- Good deal?
- Dodge Caravan 2005 Front turn signal...
- Cruise control steering wheel backlit?
- buying 2012- potential problems?
- tranny or axle problem?
- 1999 Caravan won't start
- 1997 Plymouth Grand Voyager with Issues
- My Trans Relearn After a S-Pack Change, 2002
- 2000 caravan
- 2013 Dodge Grand Caravan
- How Much Front Motor Mount Flex Is OK?
- Engine Code PO456 and remote starting....
- Clunking noise
- headlight adjustment 2009
- 2000 3.3l Major Compression Issues
- wheel cylinder rear driver side, bolt size
- Strut Mount -- Orientation Problem -- Is this Right?
- Grand Caravan sliding door won't close. Help!
- Bent sway bar? '99 caravan
- Running on only 4 cylinders
- Engine Light 2006 Grand Caravan 3.8
- New here hoping to get suggestions
- New here AND have some hitch questions.
- 2002 awd Humming noise and vibrations in padel
- 2005 caravan has trouble starting
- 5th Gen 08+ 2011 Caravan - Need an additional Tether Anchor for 3rd Row
- 96 GC, loss of brake pedal pressure?
- 2010 caravan BadKey message
- 97 Dodge G-Caravan ES AWD NLA parts?
- 99 Grand Caravan Left tail light out
- Seating options on the Dodge mini van 2013
- Front Suspension Noise
- Help after replacing fuel pump in 2006
- 02 dodge caravan 3.3 help,
- '06 GC SXT -- Deer strike = TCM issues??
- 02 Grand Caravan 3.8L salvage rebuild project
- Heater works after moving
- 2002 grand caravan ES RIM options
- trans leak
- Like most tranny problem
- Where is the O2 sensor (Bank 1 sensor 2) on a 2008 3.3L V6 Grand Caravan?
- 2000 Grand Caravan Starting Issues
- 2002 Caravan problems
- 2010 4.0l loss of electrical power
- 2012 Caravan Issues
- 2002 caravan sport 3.3l transmission slipping.
- rear wiper works when it wants to
- Van Will Not Start
- Help - Won't Start
- Cold Weather = Bad Wheel Sensors?
- Did My Solenoid Pack Today
- Remote Start ????
- 02 GCS With 125K, What Would U Do?
- No heat or AC
- Wiring to fuel pump is bad near entry to body cavity
- Traction Control
- 06 Caravan - door linkage
- PURGE SOLENOID 2005 Grand Caravan
- 98 GC - No rear left turn signal?
- Tire Life
- Bored? Want To Read Up On The 3.3 & 3.8L?
- 2000 GC Hard Start
- 2002 GCS 3.3 Injector Harness Inspection
- 2002 GCS Idle In Drive Vibration Question
- pulsating brakes
- Satellite Radio via OEM Head-Unit Possible in MoparH
- help on a/c temp control lighting
- 09 Grand Caravan spare tire storage
- 2010 dodge caravan - twisted wiper arm?
- 00 grand caravan transmission problems help!!
- 2007 Town & Country Power Liftgate Quit Working
- U Connect
- 2003 caravan 3.3 flex fuel running bad
- ball joints
- 1994 Dodge Caravan front calipers locking
- Harsh 3-2 DownShift Occasionally. 2002 GCS
- Auto Heat won't work unless first in manual mode
- 2006 key won't go into ignition
- Hid connector problem
- Dodge Caravan shifting problems.
- Engine won't go over 2500rpm after repair
- Broken water pump bolt???????
- Hello , need help 1993 dodge caravan, plymouth voyager transmission vibration
- Merry Christmas
- Solenoid Pack Leak - It's Baaaaaack!
- 06 Grand rear heat dont work
- 03 Grand Caravan Water Temp Fluctuates
- Transfer of Remainder of Factory Warranty
- 00 3.3 thermostat gasket
- 2007 Town & Country P1607
- Please help! Converted 2000 Caravan wont start..
- Driver Slide door won't open...
- Idling and Check Engine Light
- Has Anyone Swap a 3.8 into a 3.3 2002 GC?
- 1996 Plymouth Grand Voyager 3.3L No Start after rebuild
- Used 96 GC 3.3 to jump start another car...dead now
- Fuse box clicking - HELP!
- 2010 grand caravan Noise when shifiting in gears
- Teardown of 02 Caravan PDC No Accessories Working
- Traction Control
- pinout ecu dodge caravan 2.4L 1998
- 1997 Grand Voyager 3.3 V6: no heat, losing coolant, no drip — arrgh!
- signal fuse keeps blowing -
- My 1994 Caravan with a 3.8L engine is surging/idle roll issue
- 2012 Grand Caravan Crew vibration between 95 km / h and 105 km / h
- 2006 Caravan heater problem
- 06 Caravan power door locks
- Transmission?
- Please Help!!!
- Crank Sensor broke off!!!
- 2005 Dodge Caravan heater issues
- 2002 Dodge Grand Caravan. 3.3 Liter Automatic Trans
- IV Generation Caravan Manual Transmission?
- Dash Displays E CodE E 400.1 2002 GC Sport
- 2008 Grand Caravan--Dash Electrical Problems--HELP?
- HELP Removing Driver side air vent
- 1998 Grand Caravan will crank but wont start
- 2011 Caravan Broken into. Not one but twice.
- need help with trans variable force solenoid
- Alternator / ECM issue
- 2012 Grand Caravan possible transmission issues?
- Looking to find out why you are loosing so much oil?? Just ask Dodge
- Fixed from being attempted stolen and not starting.
- towing with a 2005 GC SXT
- Remote starter recomandation or not
- 99 Caravan stutters, backfire
- 2008 Dodge Grand Caravan Blower Motor
- Ice and power sliding doors
- Idler pulley bolt thread direction?
- Camshaft help
- Solenoid Pack? 2001 DGC
- new blower motor resistor smells!
- 2009 Grand Caravan alternative headrest??
- Weak Headlights
- Infinity System and Body Computer Help Please
- turns on few seconds then shuts off...
- 2011 Grand caravan Headlight Question HELP!!!!
- 2004 Caravan parking brake connector
- 2007 Dodge Grand Caravan 3.3 Spark plug torque
- Power seat
- Have only one key for my van
- 02 Caravan Back Side Doors Locked
- drivers side power window problem
- 2000 Grand Caravan - Cradle Lowering to remove driver side control arm
- 2002 Caravan -- TIRE SIZE -- Alternative Sizes?
- '97 Dodge Grand Caravan AWD ES parts
- 2011 GC a lemon....
- 4.0 v6
- '94 Grand Caravan drive axle
- Any Drilled and/or Slotted Rotor Successes?
- 3-speed 31TE transmission needed
- 09 gc dash
- Lost keys. Options?
- Can we add auto on/off headlights on GC SXT?
- Strut Spring Compressor
- 2006 Dodge Grand Caravan Stock Radio/CD Player MP3 Question
- Helping finding part number
- Head gasket
- 2002 GC Crank Pully Not Spinning True?
- 2001 Caravan Turn Signal Problem
- Do I need a new PCM?
- transmission torque converter not engaging
- What tires do you guys run on your van for the snowy months?
- Popping noise at idle from front drivers wheel well?
- 2011 Grand Caravan front rotors - warp
- 2002 Caravan -- Steering Issue + A Squeal
- cold start problem 99 Caravan
- 2006 Caravan Winshield Washer Fuse
- XZZ Option
- 2005 Caravan Head Gasket Question
- 02 GC Sport Wiring Harness Inspection
- Bumper Droops At Sides -- Bad NUTS or Bad CAR FRAME ?!?
- 2001 doodge grand caravan pins that hold the driver side window to the regulator
- Your opinion - is the mechanics estimate OK?
- 2005-2012 OEM Premium console group buy
- pcm nightmare! !
- Please help!!! 2001 caravan fuse box - miss washer fuse prongs
- Will it fit ? Transmission question
- '00 caravan trans mismatch
- 2001 Serpentine Belt without A/C?
- Parking Brake Auto Adjuster Tension Reset?
- I want to convert my '97 Caravan to V8, and RWD
- Pins that hold the door gLass to the Regulator
- 02 GC Tranny Pan Leaking @ Front Edge?
- Used 2012 Grand Caravan
- 2010 caravan rear brakes
