View Full Version : Dodge Caravan
- 06 Ambient air temp sensor
- '05 T&C Fluid Leak
- Refrigerators in Caravans
- fuse problems
- Caravan Shift solenoid depression syndrome
- Caravan traction control on icy highway
- Help with Alternator
- Evap System Leak Troubleshooting
- 2011 GC Crew, interior lights flicker
- Heater goes cold on idle, hot on acceleration
- Can someone here recognize this "strange nut"?
- 2001 dodge caravan se radio powers on no sound
- 1997 3.0 GC Water Pump Issues
- window switch buzzes
- Hub nut help
- 2.4 grenades at 42k, rebuild suggestions
- Ride Quality, Tires, Shocks, & Struts
- 2008 dodge caravan check engine light
- 2005 Caravan SE tire size?
- Key Programming
- 41TE service manual
- My 1999 Dodge Grand Caravan heater fan isn't working
- '01 GC EGR system layout
- 2006 parking lights won't turn off
- Another engine swap question.
- Lifter noise while turning a corner
- 2008 Carvan Oil Leak
- 96 Grand Caravan, starts, then dies
- cranks but won't fire
- Cylinder heads
- Random overheating on 2000 3.3L
- calliper piston stuck rear
- Buying a used Caravan
- Peatmoss1
- '07 Caravan front end grinding sound
- 2011 caravan climate control button removal
- P0420 after replacing Cat and both O2
- Anti freeze smell, 2005 grand Caravan
- cannot program keyless entry key fob.
- Service Manual
- A670 (31TH) Transmission Help
- 2004 Caravan SXT NOT STARTING NEED HELP!!!
- Expert needed for trans swap info!
- Overheating issues!!! Help please :)
- Grand Caravan ABS questions.
- Engine Ticking while cold
- radio wiring diagram and removal for a 2010
- squeak
- 2005 Dodge Caravan stuck in REVERSE, I need HELP!!! ASAP...
- 2006 GC Weird Issue
- 2010 GC Winter Tires - TPMS
- EGR gaskets
- 1986 wiring diagram
- Door Mechanism (Dodge Caravan 2001)
- Brakes
- '98 Caravan 3.0 / Doing Repair...what else to replace?
- 08 GC SE Tailgate and gas hatch issues
- Master Cylinder Filler tube seal apears to be leaking
- Window Switch Not Working
- Please help me remove my alternator.
- Engine wont start after sensor replacement
- Differential diagnosis help (mounts vs. damper)
- Broken Part on Slider: Help Identify the part
- How Do I Remove/Replace T&C RF Seat Belt?
- Transmission repair information
- lights start flickering, gauges go crazy, van shuts down.
- Removing "Fuel Filler" Swing-Open Cover
- jor
- ABS Question 07 SXT
- Drivers Side Control Arm Noise Fix?
- 1994 caravan 3.3L Loss of power
- Front Blower Motor Replacement
- Frozen doors
- BODY RUST - Quick Advice on Beautifying This....
- Can I run Bosch +4 in my 08 3.3 Grand Caravan SE
- how to replace rear wiper arm 2008 grand caravan
- headlights 2012 models
- transmission codes
- 2007 dodge caravan SXT
- Climage control bulbs for 2006 Dodge Grand Caravan SXT 3.8 V6
- Pcm?
- Park Brake Actuating Lever -- Installed Correctly?
- wipers,radio,heater cutting in/out?
- Difficulty in swapping out power sliding door?
- heater fan motor
- Pcm?
- 2011 SEMA "Man Van" wheel question.
- Lack of power in a 2006 Grand Caravan
- Fog lights?
- a/c does not work
- Serpentine Belt will not fit after replacing power steering pump and pulley.
- Grand Caravan Swivel 'n Go 2008
- Bleeder Screw Removal
- 04 caravan fuel dash light
- Loud throttle whine after long highway trips...
- '08 & up OEM Style 16" CHROME Wheel Covers
- abs hydraulic circuit malfunction
- 2009 Dodge Grand Caravan - tailgate unlatched message and interior lights
- Adding Sirius XM to 2005 Grand Caravan
- Merry Christmas
- Front end noise (clunk) when cold temps outside
- no heat in caravan
- 1999 Caravan Sport Front Brake Noise?
- Rear Brake 2006 Caravan - retracting caliper
- 8 in. hose on pwr steering cooler keeps blowing off
- Check engine light
- new member with questions about my dodge caravan
- 1994 AWD GC 3.3 no spark at plugs long post
- 2008 SXT 3.8L Banging Noise?!
- Engine Control Module
- Doesn't feel like 215hp
- Hoist Problem -- Need Advice
- 2011 Dodge Caravan Tire Pressure Monitoring Light
- Windshield wiper fluid dispensing intermittently
- antfreez, qts required? how much mix?
- Fog Lights
- 98 caravan Won't start, relay going crazy
- 2001 Grand Caravan drivers side slidding door power door lock not working
- 2003 3.3L Were is Radiator fan Relay & PCM?
- What type of transmission do I have.
- transmission issue
- Dent -- How to Fix
- What is the stock exhaust size?
- A newbie with a question about 2011 Grand Caravan 3rd row seating??
- 1998 Caravan Brake Problem
- 2005 Caravan driver door electronics issue
- Remote Control Starter
- 2012 Dash problems
- Which plug wires are best??
- 2001 Dodge Grand Caravan---Heater Issue
- A-604 Transmission - Lockup Question
- Replace coolant, is the ok procedure?
- Multifunction Turn Signal Switch -- Remove Wire Connector
- DRB III Scan Tool Useful??
- 97' GC 3.3L Vibrations driving me CRAZY!
- 10 caravan codes and transmission
- Coolant leak,please, where is it going?
- 2000 Dodge Caravan - DTC Code Display?
- 2009 Dodge Grand Caravan Shifter Button
- Help! 2000 Dodge Grand Caravan
- spots on garage floor - 2011 GC RT
- 1999 Plymouth(Dodge) Grand Voyager remove control arm
- a 670 atsg book pdf
- Dodge Grand Caravan Dash Cluster completely out!
- 2000 Dodge Caravan -- Brakes Question
- No spark after engine swap.
- 2012 gc sxt hitch
- Problem with install heater core, 06
- 1996 Caravan gauges don't work / needles vibrate
- 4th Gen 01-07 03 grand caravan 3.3l fuel injection cleaning
- possibly the end of my 2011 grand caravan...
- Transmission
- transmission lagging??
- 2012 grand caravan sxt usb / radio
- 2008 Grand Caravan rear blower location
- 2000 Grand Caravan 3.3 Thermostat
- '96 grand caravan ignition coil getting no power
- 2008 chrysler town and country
- 1996 Caravan transmission issues
- Right or left-handed threads?
- EGR valve remove; best method
- 2000 Caravan - Airbag Light & No Horn -- Sol'n?
- 2000 Dodge Caravan SERVICE MANUAL
- Christmas gift to me.
- airbag light 2006 caravan
- Does New Evaporator Core Come With Expansion Valve?
- How to replace dash bulbs for heater/radio
- Windshield Washer Not Spraying
- Need Help on 2002 Caravan
- 2012 alarm
- 94 Grand Caravan AWD 3.3 flexplate /timing notches
- Alternator amp. size to buy?
- '06 caravan intermittent heat
- '00 Caravan - Service Manual & Obtaining DTC
- How to Pinch Off Rear Heater for Evaporator Replacement
- 2002 Dodge Grand Caravan Electrical Problems
- What's eveyone getting for mileage with their 11's?
- Radiator Change Question 2003 GC
- Engine dies
- 96 Fuel Filter Replacement
- Rough to start and no heat + engine overheat
- 1999 Dodge Caravan 197k whirring noise
- Oil Pan Gasket Replacement on 2004 3.3
- 2000 Caravan Running ruff,stalling
- A must have tool....
- Anyone replaced a water pump??
- Two days of brakes running HOT
- 2003 Caravan shuts itself off
- Frustrated, need help
- how to remove pulley from alternator
- Car and truck of the month
- I need a switched location for my electric fan
- Need to scan codes in San Diego area
- Won't shift out of first. P0750
- How to reposition engine? 95 caravan 3.0
- Rear hatch struts
- Hard to turn steering wheel
- help me !!!!!!08 caravan going crazy
- 2010/2011 Dodge Grand Caravan rear wheel wall marks
- 5th Gen 08+ TPMS - True or B*** S***
- HELP rear heat hoses and tubes?
- Remove pulleys while in van??
- Trans solenoid pack question
- a/c blow air through lines but not rear?
- need to know where to get ingition coil plug
- Tambourine sound at ~1800 RPM
- 2011 Dodge Caravan Oil Change at 5500 Km
- Antifreeze leak from A/C evaporator drain
- Leaky Injector
- 97 grand caravan rear shock absorber replacement
- lower control arm pivot control arm bushing question
- engine mount bracket bolts on a 3.3l v6
- 3 rd new axel in 1 year
- 2008 Caravan rear VES issue
- Inner Tie Rod end replacement...basic steps!
- High Pitch Beep on ENGINE START?
- 2003 Grand caravan speedometer
- urgent 3spd autobox 1988 caravan
- 2000 Dodge Caravan Windshield Wiper Issues
- Happy Thanksgiving
- P0443 code and rough idle
- 2008 grand caravan ves issues and rear end noise
- Air Bag Disconnect
- 12v power outlet
- downstream Oxygen Sensor 3.8L
- 2004 Grand Caravan cylinder 5 missfire
- 1999 dodge caravan wiper motor
- 2011 Dodge Grand Caravan In accident what to look for
- Replaced strut bearings 02 GC, how-to
- Rear Gate won't lock!!
- Belt Tensioner
- EGR/Alt removal on 06 GC
- abs light
- caravan steering problems
- P0204/Bad PCM?? Please help!
- Trailer Tow Grp for 2012 Grand Caravan?
- no heat in front
- 2012 Grand Caravan door panel removal???
- Need some help with Trans stuck on Limp mode please
- Towing with 95 AWD Grad Caravan?
- Steering Wheel Not Straight
- 2000 Grand Caravan 3.8 intermittent turn signals
- 2004 Caravan Anni. Edition - Exterior lights don't blink
- 2006 Grand Caravan, 3.8, 96k - NO power, won't rev.
- New member here
- A/C Questions...
- overhead console questions.
- ignition problem
- Fuel pump problems?
- Unruly Windshield Wipers
