View Full Version : Dodge Caravan
- Issue with lights and climate control panel after dead battery
- AT slips forward in reverse
- 4 caravan camshaft sensor
- '99 Grand Air Bag
- Engine Cracked in 2010 Grand Caravan SE
- 2003 Caravan only starts with Starting Fluid
- '01 3.8L thumps and shudders upshifting to 2nd & 3rd
- 2009 Grand Caravan front rotors
- 2000 caravan mil wont turn on
- ac Clutch
- Front Hub/Bearing Assembly Replacement
- 1998 Dodge Grand Caravan Sport engine knock
- Have made a few Mods to my 2010.
- loss of acceleration 2006 Caravan
- new to df
- 2011 Dodge Grand Caravan Crew - Six-Speed Automatic Transmission!
- Dodge Grand Caravan sometime turn but won't start and shut off when driving
- Blinker and hazards not working
- why have cold level on tranny dispstick?
- '95 w/ 3.0 won't start
- 1999 Dodge grand caravan CODE P0304
- 2005 caravan wont start (misfired)
- Automatic sliding doors
- no air comes out of front vents on 03 grand caravan
- 2010 Grand Caravan Transmission wouldn't shift
- 2010 Grand Caravan Exhaust Resonating ?
- '03 Engine replacement
- How Much Oil in 2011 Caravan?
- new dodge caravan owner
- Smoking engine
- My maintenance thread
- 08 Grand Caravan Brake question
- Caravan 06 - Loud Squeal Noise - 69,000Km
- Caravan Owner Manuals!
- 2003 caravan not starting.! Why?
- transmission fluid/filter change
- Wiring help
- 2002 Grand Caravan Transmission Problems
- Oil Cooler O-Ring Size
- 01 grand caravan sport; no power to ac compressor
- 2002 Grand Caravan stalls
- 96 Caravan Speedomoter freaking out!!
- 97 dodge grand caravan power steering rack boot replacement
- New Guy with some electrical issues with a 2002 grand caravan sport
- 96 3.8L Grand Caravan Just Stopped idling
- jercking
- wet driver floor board 1996 DGC
- Is it possible to put Generation IV engine on Generation III?
- 96 GCV, AC problem
- power sliding door ? 2008 GC SXT
- Official DodgeForum.com decals...
- TRANSMISSION PROBLEMS - Date/Location of Manufacture Survey!
- RE: previous posts on issue with clunk noise sound!
- Is an HID headlight kit safe to install on a 2000 Caravan?
- excessive brake dust from rear 2011 caravan
- 2000 Gr Caravan 3.3L with 4-speed Transmission
- 2011 Dodge Grand Caravan Crew - Glove Compartment Light!
- 2000 Dodge Caravan - Maybe a Transmission control unit problem
- 2003 caravan sport help needed
- Looking to install a roofrack!!!
- New 2011 Sirius Sounds "Tinny"
- Questions on the 2010 w/3.3
- Where is "cylinder block drain plug(s)" for coolant?
- Proud new owner of a 2007 DGC SXT!!!
- Caravan BCM problem
- 1995 dodge grand caravan se
- 94 4cyl head torque?
- Electric/manual mirror parts interchangable?
- Tires size
- UConnect and USB Questions!
- AUTO123 - 2011 Dodge Grand Caravan Crew Review!
- About a trailer hitch and tranny cooler
- Another iPod Problem
- Vacuum prob on 95 Voyager
- Body Control Module (BCM) -- Where is it? [PHOTO]
- Super Bad Misfire & Engine Stalling 2004 Grand Caravan?
- 2005 key programing
- Tire size question
- '96 caravan tranny whines slips no limp mode
- Why would '05 75k mi. Caravan losing oil (3.8, 6 cyl)
- 2000 Caravan 3.0L cranks but won't start
- P1787
- 2008 GC SXT - need DVD options
- Leak Detection Pump (LDP) - Is this it?
- Fuel Pump Connector - Testing Question
- Need help 1999 3.3l plymouth vol. Neutral safety switch
- Hey guys new here having problems with 2000 Caravan
- full synthetic oil after using regular: OK?
- Hissing noise from dash 03 Grand Caravan
- idiot light panel
- Power seat problem
- broken spark plug
- 4.0 Possibly Seized
- 99 Caravan, Problem With Radiator Fan
- Chrysler had the gaul to say this
- 2007 Caravan Surging
- owner review
- after a complete stop when i put on the gas my 2000 dodge caravan jumps.
- tires?
- Toyota Sienna vs. Dodge Grand Caravan
- Subscribe to NHTSA's Recall Notification E-mail System!
- Significant Power Steering Fluid Leak
- 05 Caravan
- 2000 caravan no gauges or signal to dlc
- Brake caliper-to-inside wheel clearance. Dangerously close?!?
- '03 Caravan with 3.3 Overheating
- Dodge Grand Caravan 2004 cruise control does not set
- How to remove front dome light? 96 Caravan
- How to activate the VTSS system?
- 2010 dodge caravan rear brake job
- Caravan TCU code reader
- M.A.P. sensor ?
- Need charging system help on 97 T&C
- Removed - Already posted!
- 2005 Caravan Parking Brake
- 99 caravan transmission codes
- 99 Caravan no Reverse
- 2003 Caravan Ignition switch and door chime problem
- Fuel Gauge Not Reading Correctly -- ALWAYS on (E)
- 2011 Dodge Grand Cavaran Service Manuals
- 94 2.5l overheat and water leak exhaust?!?!
- 2008 TC entertaiment system not working
- 2001 Caravan Question...
- m12 cl10.9 bolts in rear of frame
- 93 3.3 caravan no codes poor idle stalls when applying throttle
- 2011 Dodge Grand Cavaran - Key/Menu Frozen!
- dodge caravan ignition control recall
- DIY replacement of catalytic converter? ('02 Grand Caravan)
- Slide door power lock issue
- 2006 Grand Caravan trailer wiring harness
- Troubleshooting P0171 and P0740
- WOW 2011 On fire and burnt.
- It's 110 degrees outside and my A/C just quit! Help!!
- A/C causes Van to sputter
- weird noise after starting, help my mom out
- About to replace the strut bushings. Some questions before getting started
- A/C causing issues..Need HELP
- A/C Ambient temperature in 1994 van?
- Loud poping noise from engine compartment
- stuck in 2nd gear - again
- Spare tire winch
- 00gcv hesitates and cuts out while driving
- No fuel gage, no speedometer, no temperature gage
- 99 Caravan/99 Stratus 2.4 transmissions interchangable
- high pitched whistle in rear of 03 GC
- Ambient Temp. Reading Stuck at -40 Degrees
- Mounting Bikes To Back of 06 Caravan?
- 02 dodge caravan
- Which brake pads for 2005 Grand Caravan. Should I go ceramic?
- Gunshot-like sound in Dodge Grand Caravan 2005.
- 2011 Grand Caravan tapping noise on cold startup and misfire
- 2003 Caravan Whining Noise - Passenger Side
- Towing With A 4-Cyl, 2.4 Liter 2006 Caravan?
- 2002 Dodge Grand Caravan 3.3 not running right
- 2006 3.3L going thru oil and coolant
- Van feels like will shut off, but doesn't
- 2006 Caravan base and towing
- 2000 3.0 4 speed trans diff pin
- Dodge Caravan 2011 Electrical
- Sliding door latch on '99 Caravan won't close
- A/C Problem on '01 GC 3.8L
- 2002 GC knocking sound
- Body Control Modual
- 2011 AC vent rattle?
- 2003 Dodge Grand Caravan blower motor replacement
- No brake lights on '01 Dodge Grand Caravan
- 2009 Dodge Brakes, pad, Drums and Rotter
- A/C not cold enough. 04 caravan 3.3L 72k miles
- noise behind front wheels
- headlights turn signals and flashers don't work interior and parking lights stuck on
- 1996 GC A/C and controls
- 2005 Dodge Grand Caravan 3.8, Engine died
- 2007 Grand Caravan A/C problem
- A/c needs oil, right? HOw much?
- 97 grand caravan in limp mode w these codes
- need rocker panel or rocker panel covers part numbers
- Hello All!
- Can I use a C-clamp to compress the brake calipers? ...
- 96 Caravan-Reawakened after two years
- Cargo Area Modifications
- Oily Leak Near Rear Left Tire
- 3 speed automatic stutters
- 2003 Dodge Sport Caravan - Humming Sound
- Interesting situation...
- 1997 grand caravan owner's manual
- Smoke from my AC compresserr?
- Firewall Boot on Steering shaft
- 3.3 tapping
- 2005 Wipers running slow in fast mode
- 2002 Grand Caravan AC Issue
- 2011 Dodge Caravan SunShade?
- Weak points?
- Slow A/C coolant leak & can't recharge
- Caravan poor idling, starting and running up to speed
- Intermittent Starting Problem (2001 Caravan)
- Which wire do I need to connect to for LEDs mounted in fog light openings?
- 2009 Rear Brake Troubles
- ***help needed***
- Flickering dash lights - 2007 caravan
- '04 Grand Caravan Rust repair
- 2001 Caravan Radio issues
- 2010 Caravan SE Catalytic Converter
- Brake pedal slowly goes to the floor.
- Safety Recalls and Technical Service Bulletins
- Chrylser Extends Brakes Warranty!
- 2008 Grand Caravan Windows
- Abs light blinks
- trailer hitch
- 2004 Caravan 3.3L replacement motor
- 1992 caravan error codes
- A/C blows warm
- Transmission mount, what's wrong with this picture!
- New 2011 Caravan -- Any items to consider doing?
- I got a skip/stutter
- Diagram for rear brakes, '09 GC SXT? ...
- Transmission service?
- Starting issues
- 2005 Caravan 3.3 stalls as if key was turned off
- TPMS for Dodge Caravan SXT 2005
- U0249 Lost Communication With Entertainment Control Module - Rear B249
- 2005 Caravan Bogs Down, Cannot Diagnose
- 2002 grand caravan idles a bit low
- Mpg
- flashing dash, head and taillights!!!
- 08 Grand Caravan - Any how to?
- 1999 dodge grand caravan ac
- 1998 Dodge Caravan Sport Transmission
- 2002 caravan blows hot air with A/C running
- 2001 caravan sport no communication w/computer
- Egr
- vac a/c system
- Brake Vacuum
- Adding SatNav module to a non-nav console?
- rear wheel bearing
- help new starter won't catch
- interior lighting
- Heater ac control is dead
- HELP.....Can't get damper off crank 1995 3.0
- Noise from Front end
- p0401 missing 2001 3.3 caravan
- power window problem
- 2007 Dodge Caravan Alarm Computer Reset - how
- dodge caravan 2001 p0401 code
- CODE P0406 option XZZ
- my 2001 caravan se wont start
- Exterior Lights Stay ON
- Power steering leak
- 1997 Dodge Caravan Strut Towers Deteriorated
- Extended Warranties - Whats Available?
- Why loose lugs make noise forward, not reverse?
