View Full Version : Dodge Stratus
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15
  1. v6 stratus turbo kit
  2. inside panel removal
  3. Engine Light On
  4. 2000 stratus problems mucho
  5. Replacement Cigarette Lighter
  6. Turbo installed.......now smokin!!
  7. R/T with extreme road noise
  8. Eibach spring kits
  9. anyone interested?
  10. mp3 input
  11. to the junk yard it goes..... 1996 2.4 stratus
  12. Was I ripped off? Or one heck of a deal?
  13. Help me - what is name of this plastic panel
  14. Stratus and Sebring sedan compatibility?
  15. ? about Catalytic Converter
  16. EGR VALVE
  17. thought someone might find this useful
  18. 2003 Stratus Popping noise
  19. Looking for a dohc
  20. Where can i find some smoked headlights
  21. Rim for 01 r/t
  22. inginition alarm
  23. 98 Stratus Starting Difficulty
  24. CD Player.
  25. Headresst headaches
  26. idle question?? wierd all of a sudden
  27. Electrical box under passenger seat?
  28. Keyless stopped working after having batt unhooked
  29. Timing on 2.4L DOHC?the mark
  30. 99 Stratus Wont Start
  31. Not running. Gurus here. Strange problems.
  32. ????ideas????
  33. ??Does the STRATUS have a timing belt that needs to be changed
  34. Are my rims YAy or neh
  35. if anyone wants to help out the site!!
  36. how to tell when your head gasket has gone bad??
  37. For anyone who wants racing seats!!!
  38. '00 2.4L Transmission running unsmoothly
  39. Weather stripping
  40. Key won't turn ignition
  41. WATER PUMP????
  42. WATER PUMP????
  43. engine swaping questions and a rotor question
  44. Buying a 01 stratus? Need some insight.
  45. Problems with the cooling system (???)
  46. O2 Sensors
  47. Power Windows stopped working
  48. changing battery
  49. Torque Mangement Wire
  50. Water in horn.
  51. a/c compressor
  52. ac compressor clutch????
  53. got a 1/2 tank of gas but has a hard time getting it started
  54. Body Kit
  55. oil filter ON 06 stratus
  56. 2001 Dodge Status SE 2.4L - Noise Issue
  57. Car pic
  58. 01 Stratus
  59. No more Stratus
  60. at the gas station every single day??
  61. newbie needs help with 00' Stratus
  62. Carbon Fiber Hoods
  63. SRT-4 Stratus...
  64. fuel gauge 1996 stratus
  65. key wont turn
  66. AEM Tru-Power Pulley Kit Dodge Stratus RT 01-03 3.0L V6 question
  67. Governor
  68. Wiring Diagram
  69. Radio
  70. AEM Cold Air Induction System
  71. Anyone here changed a leaky steering rack?
  72. Dodge Stratus 2.0 LE 'tick' sound
  73. engine swap
  74. 2002 Dodge Stratus for sale
  75. Anyone a turbo expert?
  76. Got a 97 Stratus, need service manual!
  77. 1998 Stratus Engine Mods????
  78. Ground effects coming loose stupid plastic anchors
  79. 2005 DODGE STRATUS REAR DECK SPEAKER WIRING
  80. WHY I LOVE MY 2.7
  81. mileage display and rpm counter are only working occasionally
  82. Plastic Rivet Assortment
  83. Engine Surging
  84. Service engine light
  85. location of motors
  86. want to stay american
  87. Vertical Doors?
  88. A/C Problem Need answer FAST!
  89. HELP! Oil by spark plugs!
  90. engine swap
  91. Girlfriend just bought a '05 Stratus
  92. motor mounts in a 2001 3.0
  93. 96 Stratus Money Pit
  94. 1999 Dodge Stratus Intakes?
  95. power steering trouble
  96. need advice please: wet air temp sensor
  97. I drive a Dodge Stratus!!!!
  98. OBD Port
  99. Wet Interior
  100. 1996 water pump? Maybe??
  101. H
  102. 2.5L timing belt replacement
  103. Tachometer / odometer problem
  104. rippmod supercharger
  105. Stratus policecar in Mexico
  106. 01 Strat Coupe tranny.
  107. 99 DODGE STRATUS
  108. Mopar Nationals
  109. Trying to find a door panel part for a 2001 Stratus Coupe...
  110. water pump
  111. belts for a 2001 stratus HELP!!!
  112. 1998 Dodge Stratus 6 Cylinder
  113. 98 Stratus ES
  114. New
  115. 98 Stratus ES
  116. Headers 04 R/T
  117. rims Q
  118. Front Bumper Bra?
  119. 96 stratus won't start please help
  120. '01 R/t Performance Parts
  121. New Pics...
  122. a couple of hopefully easy things
  123. My Transmission
  124. 06 Startus RXT fuses
  125. CarFax Please
  126. Newbie
  127. '99 Gauges, AC, Wipers die when it's hot out
  128. aftermarket torque convertor for automatic stratus r/t
  129. Looking for easy/cheap mods...for SXT 4cly.
  130. 00 Stratus Header
  131. Timing belt Popped- No Bent Valves
  132. 2002 Stratus Power Loss
  133. Hard Start in Morning
  134. Air Conditioning Stopped?!
  135. need help
  136. considering a 2003 stratus rt..??'s
  137. Help new here and have a little problem with A/C and wanting to die.
  138. odometer tachometer out
  139. About the fuel filter in my 01' startus se sedan
  140. rim off set for 01 r/t
  141. AC warm air after 1 hour
  142. Body Kit
  143. signs of trouble
  144. VAPOR LOCKING
  145. Air and heat only work on setting 4
  146. Stratus Reliability
  147. Stratus Altezza taillights?
  148. help
  149. 2000 Stratus - Wheels Squealing?
  150. New Rotors!!
  151. Dynomax SS Catback
  152. bolt on supercharger for 1998 2.5 v6
  153. August Car & Truck of the Month!!!!!
  154. a/c clutch
  155. 2007 dodge stratus
  156. Door Problem-(98 stratus)
  157. Im at loss?
  158. Confused???????
  159. P0172
  160. Brake shoe replacement?
  161. Tachometer and Odometer Problems
  162. CHECK ENGINE LIGHT
  163. Headers on the 2.4 DOHC
  164. Alarm system
  165. Where to run power wire through firewall?
  166. Free $10 Money
  167. How to maintain and improve the gas mileage of stratus?
  168. Headlights
  169. Engine runs after key is out
  170. New to Stratus
  171. my new car. kind of late though
  172. question about acceleration
  173. 96 died! Ca't figure it out.....
  174. Awesome tunes
  175. speaker sizes
  176. ? for badstratrt
  177. climate control switch
  178. 99 Stratus 2.4L DOHC OIL GAUGE?
  179. Defrost vents
  180. 98 Stratus Base model, parts compatibility
  181. 99 Stratus 2.4 Engine Mount Vibration
  182. finding an auto kit on the net?
  183. ? for SE Coupe owners
  184. Remote
  185. Timming issues
  186. shaved emblems
  187. Air intake for 96 Stratus 2.4L
  188. Top Speed 96 Dodge Stratus
  189. WHats the difference
  190. lowering springs question
  191. replaced head set timming belt and
  192. Transmission Q
  193. 99 Stratus - timing belt or chain ?
  194. Headers
  195. battery died, now won't idle
  196. Confused by numbers on compression test
  197. The ever apparent over heating issue...
  198. Rear speaker Install
  199. Coolant Leak!!!!! Help!!! Im broke
  200. K&N filter for sale!!
  201. ecu chip for 2006?
  202. parts for 06 model hard to come across....
  203. intake install Question
  204. Tweaking /'05 SXT Computer
  205. Does the 2001 R/T have a Dryer?
  206. 99 Stratus Specs?
  207. 97 Strat - accessories not working
  208. How do I change the alternator in a 98 stratus?
  209. 95 stratus tune-up
  210. Clutch?
  211. Rear Speaker Problems – Amplifier
  212. TIMING BELT POPPED. WILL I NEED A NEW MOTOR??
  213. 2001 stratus rt speaker problem
  214. HELP with my 2004 Stratus ES
  215. Engine steaming but not overheating
  216. why my car's gas doesnt last long?
  217. 2000 Gold Dodge Stratus
  218. Cam gears
  219. 98 Stratus smokes blue
  220. Alignment Issues
  221. engine swap
  222. Dome Light Replacement
  223. 03 R/T Coupe Aftermarket Struts
  224. spoilers
  225. engine code
  226. AC Compressor
  227. brake problem
  228. Paint? Not 56K Friendly.
  229. 2000 Stratus Dies
  230. 2 Questions.
  231. Removing Door Trim
  232. a/c compressor
  233. 2001 stratus water pump
  234. ANYONE, ANYONE
  235. 2000 Stratus with issues
  236. popping noise in 2001 stratus sedan
  237. 2004 Stratus R/T sedan 2.7 liter engine problems.
  238. Thanx
  239. Question about 03 Stratus Sedan SE
  240. I need answeres if possible
  241. is this kit worth it? too cheap?
  242. 1999 Stratus hesitates when going uphill
  243. 2000 stratus cd changer
  244. 95 Stratus v6 2.5L SOHC, Oil Pressure Sensor Location, Rough When Warm?
  245. thoughts on 2000 Stratus
  246. Stratus R/T engine in Stratus sedan (95-00)
  247. little problem, intake, k&n
  248. blinker problems????
  249. New Rims?
  250. Tranny Problems or not???
