View Full Version : Dodge Stratus
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15
  1. intake
  2. Ground Wire Kits
  3. Timing Belts
  4. Removing the engine from a 2001 R/T
  5. Key Stuck in Ignition
  6. intake
  7. intake
  8. strut bars
  9. 01 Stratus body work
  10. New Gauges
  11. 1997 Dodge Stratus question...
  12. Looking for Coil Over kit
  13. Check Engine Light
  14. Why'd they kill the stratus in canada?
  15. Knocking noise when driving straight
  16. 2004 Dodge Stratus SXT
  17. speed-o, gas & temp. gauges non-op
  18. Speed Limiter?
  19. turbo capable motor
  20. P1294 Error code
  21. 2nd gen ground effects?
  22. Rebuilt top end...now idle bad...'97 Strat...
  23. need a turbo for a r/t
  24. Fuel Efficient
  25. effeciency/power
  26. Transmiaaion acting up...need help!!
  27. 96 stratus radio,power locks and lights problem.
  28. is my clutch hydralic?
  29. Problem with my 96 Stratus
  30. 1998 Dodge Stratus Engine Wanted
  31. Front suspension creeking ?
  32. Starting problems
  33. 98 Dodge Stratus - Washer Pump Problem
  34. Timing Belt/Chain Change out????
  35. V6/5speed combo reliability
  36. need to know upgrades ofr 03 strat sxt coupe
  37. Hole in Oil Filter engine kills
  38. Looking into cheap suspension options...
  39. 1999 Stratus Opinions Needed
  40. exhaust clips
  41. Clutch?
  42. warranty
  43. Is the Stratus RT availiable with a 5 spd?
  44. wheres the ECU on a 2000 Stratus
  45. After Market TB for 96 2.0L stratus
  46. gas
  47. 1995 Stratus 2.4l reliable cars?
  48. Headers And Exhaust
  49. 99 stratus axle or wheel bearing split in half???
  50. my cold air intake
  51. 2007 Stratus engine and transmission line-up
  52. Crysler/Dodge Stratus 1997 LE 2.0 4Cyl turbo?
  53. Remote Starter
  54. Where is the oil filter located ('98 stratus)
  55. Transmission problems
  56. WOuld it be worth it>?<
  57. 97 2.4l Cooling Problems
  58. Engine Mounts
  59. cooling system prob, stripped bolt
  60. '05 stratus aftermarket front bumper??
  61. 02 stratus mods
  62. I need a head...anyone???
  63. Cracked Head...
  64. FS CAI 04 r/t v6 &fac amp
  65. 2003 R/T wheels
  66. MOVED: Power Inverter
  67. 98 Strat running poor
  68. Power steering Bracket removal
  69. 95 Stratus Coil Pack Resistance
  70. Need desperate help on 98 stratus
  71. Trunk Kill Switch
  72. 97 stratos 2.4 timin belt
  73. Parts
  74. RPM / coil to plug question
  75. 95 Stratus No Start
  76. So today my car got whacked
  77. Are trotlle body spacers and boring out the thottle body worth it?
  78. Remote turn on lead for amp+sub
  79. 04 Stratus SE - Dash & Gauge Lights?
  80. 2004 Stratus SXT sub-amp install questions.
  81. 96 Cirrus Shuts off while driving.
  82. location of stratus r/t fuse boxes
  83. 1st Gen Gas Guage Playing tricks
  84. Gauges
  85. question about future stratus r/t's
  86. why solid motor mounts?
  87. polishing stock 04 rt rims
  88. Stratus 2-4 Short Curcuit
  89. Put a grill on ur 1st gen stratus...
  90. Headlights pointed too low?
  91. Head lights
  92. Time Display with Radio On?
  93. Anyone changed their power steering pressure hose?
  94. backup sensors
  95. Distributor on 96 Strat ES?
  96. Intake install for 2005 Stratus Sedan (How To)
  97. Anyone else got a header on their 4cyl strat?
  98. How to add a new cigarette lighter
  99. My '04 Strat 2.4L
  100. help: stratus/neon PCM infor
  101. Power Steering Whine
  102. HELP!! Service Engine Soon Light
  103. Need power steering resevoir....
  104. V6 Mitsu Turning Over too fast??
  105. Repair Manual VS Service Manual
  106. Need power steering help ASAP!!
  107. auto to manual
  108. Help 95 2.5L Runs great until it warms up
  109. Tire Rotation
  110. I wanna see some lowered Stratus' Post 'em up
  111. Check your ball joints
  112. Cruise Control Problem
  113. engine upgrade?
  114. 2006 Dodge Stratus Sedan Press Kit and Pictures:
  115. Help with a/c compressor install...
  116. 01 Stratus ES, oil pressure lite on while idling
  117. 19's
  118. Transmission Electronics Noise?
  119. Buying a used 01 R/T Coupe in the next week or so
  120. New R/T Driver
  121. Engine Cleaning
  122. Different Models for 2001 r/t?
  123. How much rotation??????
  124. FAQ library
  125. Need feedback about brake system
  126. Whats the diff between 95 and 96 coil pacs?
  127. Gas Guzzler?
  128. HELP me! i need car aligment schematic for dodge stratus coupe 2003
  129. cold air intake for 04sratus 4cyl
  130. ENGINE CODES
  131. '04 Stratus equipment codes
  132. Just bought a 96 Stratus
  133. tire wear
  134. Foglights
  135. Subwoofer Installation
  136. '04 Stratus clicking/ticking
  137. Air Intake
  138. Potential 00 Stratus ES
  139. 98 stratus a/c cold then warm
  140. stereo/tape player/ speaker problems. help!
  141. Radio just shuts off? Also Fog Light ? 2000
  142. 2004 Stratus AIS motor...
  143. Aftermarket Speakers
  144. How can I get more MPG out of my 2.5
  145. dodge stratus brake problem
  146. Got header and high flow exhaust!!!
  147. passenger door unlock
  148. Motor Swap?
  149. ma stratus
  150. Is The Stratus A Pillar The Same As Sebring and Avenger?
  151. Two QUESTIONS!!!!
  152. Another speaker question
  153. R/T parts on an SXT
  154. Rev. limiter on 03 SXT Sedan
  155. fog lights
  156. cat back exhausts
  157. facts on the sludge monster
  158. weapon r?any mods?
  159. engine light on again
  160. Stratus, Intrepid at top of theft-rate list
  161. $500+ wheel for 03 ?!
  162. stratus 01 short shifter
  163. cams
  164. new pics of the car...
  165. xm stratus
  166. back up
  167. BODY KITS
  168. 00-04 MITSUBISHI ECLIPSE COILOVER HI-LOW SPRINGS 01 02
  169. lowerrt
  170. 2004-2005 Stratus Body
  171. 2003 Strat SXT Sedan Exhaust In/Out
  172. Turbo Stratus Wallpaper
  173. Need info about powertrain control modules and prices
  174. Headlights
  175. Intake Air Temp sensor??
  176. disable priority door unlock
  177. MOVED: some info on exhaust systems
  178. Suspension Question
  179. dodge stratus quits when it wants to.
  180. 96 stratus 2.4 water pump
  181. stratus just quits running
  182. 2005 Stratus(NEED HELP WITH FINDIN MODS)
  183. Aftermarket product listing for the Stratus Coupe
  184. Aftermarket product listing for the Stratus Sedan
  185. Cold Air Intake And Exhaust Mods
  186. IAT sensor....?!
  187. Throttle body spacer for a 98 Cirrus 2.5
  188. Cold air filter
  189. 98 stratus/cirrus
  190. Need help w/programming key fob
  191. Factory Speaker Removal - 02 Stratus R/T
  192. need help i relly mesed my car up
  193. HELP Need BODY SHOP IN CHICAGO!
  194. Exhaust system suggestions for 97 stratus
  195. Could you diagnose this problem?
  196. 95 stratus engine compatibililty question
  197. Body Kits
  198. How to replace driver side mirror on 98??
  199. And the Verdict on the stratus is......
  200. stratus egr (code 32) and O2(code 21)
  201. Cam Shaft Postion Sensor
  202. Stratus wont start
  203. Need some information.
  204. uuu oohhh i busted something....... need help
  205. 97 Breeze heater/ac diverter
  206. 02 Stratus: Engine revs when starting
  207. Where'd the power go?
  208. No Power
  209. 2002 stratus headlights
  210. 2-door or 4-door???
  211. ebay intake
  212. fuel pump
  213. Display panel
  214. Mufflers-Pullys
  215. Timing
  216. Headers and performance chips
  217. wheel fitment question?
  218. aluminum strut mount deterioration
  219. Air Filter
  220. R/T coupe headlights
  221. replys please
  222. VIPER EMBLEM
  223. Car seems to be running hot?
  224. Radio circuit short
  225. custom grills
  226. Headers!!
  227. Gas Gauge!!
  228. keyless transmitter
  229. exhaust!!!
  230. stratus wheel base
  231. Torque settings for oil pan screws?
  232. system
  233. badging
  234. Backup Lights
  235. SRT-4 foot pedals on a 2004 Stratus R/T Coupe?
  236. 95 stratus headers?
  237. Need stuff & Ideas
  238. Supercharger or Turbocharger
  239. Timing Belt Q
  240. Need help with horn
  241. bolt on
  242. Air intake temp. sensor
  243. 20 Inches on my 95
  244. Trunk lid
  245. o2 sensors
  246. 2.4l dohc 1995 manual??
  247. 2.4l dohc 1995 manual??
  248. Performance question?
  249. 1999 Stratus Dash lights will not illuminate
  250. New on here..Need Help ASAP...Stratus question
