View Full Version : Dodge Stratus
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15
  1. stratus paint codes HELP!!
  2. Re: 2001 stratus-bad batt. and radio issues
  3. Finally a magazine for the Stratus!
  4. Help-Burn fuse
  5. windshield banner
  6. Stratus Turbo
  7. FS Set of stratus Pistons
  8. battery light
  9. 04 strat sxt
  10. New Member
  11. Stratus AC Compressor
  12. 01 r/t performance mods
  13. Fuel gauge and light
  14. Radio/CD issue
  15. replacing timing belt
  16. Back bumper of 2002 rt?
  17. air intake 4 2.4L
  18. 96 2.4l engone govener
  19. 96 Dodge Stratus 2.4l Thermostate
  20. Rear speaker installation - getting to rear deck help
  21. Sub Installation
  22. Can't shift into park - 1998 ES - V6 - auto
  23. Stratus "S" Package arrived today.
  24. fuel pump relay switch
  25. 1997 stratus for sale
  26. installing cd player in 2000 stratus
  27. 2000 starter stays engaged
  28. car wont start. oil level relay????
  29. bad coil, had to replace distributor
  30. '06 Stratus Arrival??
  31. No more Stratus coupe.
  32. Cold Air Intake for 04 R/T Coupe
  33. starts,but wants to die when cold
  34. 2004 stratus sxt with a turbo?
  35. Wiring Trailer Lights for 2001 Stratus
  36. 2001 RT Sound System Questions
  37. Anyone else having these troubles? (2001 RT)
  38. Wiring schematics?
  39. Power Steering woes
  40. dash speakers?
  41. CAI for my strat?
  42. CD Changer Options for 2005 R/T
  43. In need of help
  44. Dreamspeed cold air intake questions
  45. superchargers
  46. '97 Stratus ES
  47. 2004 Dodge Status engine light on
  48. MOVED: No Bus?
  49. 2004 stratus coupe R/T - Experiences
  50. Any Ideas!!!!
  51. Here's my plan
  52. gurgling sound?
  53. ABS light
  54. hi flow cat converter
  55. help!!!
  56. Wheel offset question
  57. brake warning light
  58. Stratus 2000 Strut Replacement
  59. Purchasing a Stratus/ 2 to choose from
  60. 97 transmission problem
  61. brakes for stratus r/t
  62. Noise coming from timing belt cover
  63. 1999 Status Timing Belt ?
  64. stratus computer
  65. Cold Air Intake for 2004 stratus 2.4Liter
  66. Just bought 2004 2.4 4cyl stratus
  67. 2000 dodge stratus problem
  68. 2005 Stratus SXT
  69. HELP ME! Stratus R/T Insurance is terrible!
  70. 97 Dodge Stratus
  71. 96 dodge stratus problems "please help"
  72. 20+hp speedchip
  73. cold air intake?
  74. IAT (Intake Air Temp.) sensor
  75. hoods for a 97 strat
  76. R/T symbol
  77. 1995 stratus no start
  78. throttle body on 97 strat
  79. srt 4 motor
  80. Tail light and body mods
  81. Where is the Idle Air Control?
  82. Got My Lower Control Arm Replace For Free. AGAIN!!
  83. BEST WAYS TO ADD POWER/SPEED
  84. 95 Stratus wont start HELP!
  85. how to remove governor
  86. Turbonator
  87. do i have keyless entry ? ?
  88. Fuel Filter and Other Mods
  89. Considering Stratus R/T purchase.
  90. How much to replace the timing belt?
  91. 96 stratus 2.4 l dohc trans type
  92. engine stats
  93. newbie
  94. a
  95. rear disc brakes?
  96. How to check codes on a 99 stratus
  97. 99 Stratus ES 6 Disk Changer problem
  98. 96 w/ epilepsy
  99. Maint questions.
  100. 2.4l I4 interference or no?
  101. exhaust leak
  102. engine swap
  103. seat belt help
  104. 99 stratus, common problems?
  105. 98 Breeze radiator drain?
  106. looking into buying a stratus
  107. Disconnecting the battery problems?
  108. stratus
  109. New 2005 Dodge Stratus R/T Sedan Options:
  110. Serpentine Belt Replacement! HELP!!
  111. Electrical Problem - 2000 Stratus
  112. Stratus R/T performance chip
  113. were is a good place to find upgrades for my 97 stratus
  114. question!
  115. Crankshaft vibration damper pulley fo 2.4L
  116. which one is it??
  117. Question about the Stratus R/t 3.0 L
  118. 1995 dodge stratus no start
  119. Code P0401
  120. code p1294
  121. SORRY, DUPLICATED BY MISTAKE
  122. Stratus 96 Remote
  123. damn water pump
  124. 96 Dodge Stratus
  125. 96 Cirus w/remote start has elec woes (long)
  126. 2003 Startus R/T Sedan - a few questions
  127. tire recommendations for 2003 Stratus SXT?
  128. badging?
  129. just bought a 2004 Dodge Stratus
  130. 99 Startus rough idling ... help
  131. hidden buzzing/motor sound
  132. 2002 and 2004 Starus use the same cd Housing
  133. Model # for 02 cd player
  134. throttle body
  135. 2001 windshield washer leaks
  136. 3.0
  137. Brakes & washer fluid shooter on a 99
  138. I bought a 2003 stratus R/T
  139. 98 stratus ES needs cold air intake
  140. 97 Stratus - Sat a while...what to expect?
  141. i need some more power.....
  142. 2003 Dodge Stratus SXT Sedan Problems
  143. 97 Stratus - how do I turn off "check engine" light??
  144. turbo
  145. What size muffler for 3.0L
  146. 2002 dodge stratus r/t coupe performance stats???
  147. 2002 dodge stratus r/t coupe performance stats???
  148. 1997 Dodge stratus misfiring? Poor acceleration.
  149. Custum Paint/ Graphics
  150. 2002 dodge stratus code p0018 p1684
  151. 2001 Turbo?
  152. just bought a 97 Stratus looking for more HP
  153. '96 Stratus 2.4 Tranny in limp mode
  154. Blower selector
  155. 95 Stratus not running after timing belt and head gasket repair..pls help
  156. Can I Get $12,000 for a 03 Stratus SXT
  157. '96 Stratus 2.4 Head Gasket major help wanted
  158. 95 Stratus wont start, need help ASAP
  159. how do i check codes?
  160. 02 stratus se. Please help
  161. another question
  162. 97 stratus questions
  163. Supercharger on an R/T
  164. O2 Sensor?
  165. 99 Stratus - Vibrates when Idling
  166. 20 HP "Chip" on Ebay
  167. Exhaust: 03 2.4 Coupe
  168. Heater blows cold air
  169. Newbie needs help
  170. Checking the Timing on '98 Stratus(4cyl)?
  171. OK DODGE GUYS, HELP!
  172. Speaker/Preamp Problem
  173. Searching for aftermarket parts..??
  174. Alarm Problem!
  175. 98 stratus engine coolent problems
  176. Spark Plug Wires
  177. Speaker install
  178. 96 Cirrus Instrument Cluster Problems
  179. HD struts
  180. 2001+ Stratus 2.7L sedan HD struts
  181. Check Engine: What the Dealer said...
  182. I have A new 2005 stratus coupe
  183. Check engine light and bucking.
  184. DF, my last hope for unknown problem.
  185. You think your fuel pump is fine.. Check this out
  186. 97' stratus rear speaker removal
  187. Eibach Lowering Springs
  188. PO 171 Code
  189. Ignition problems
  190. type and weight of oil; OCI
  191. (SORRY TO INFORM EVERYBODY BUT MY CAR WAS STOLEN LAST NIGHT. THEREFORE NOMORE STRATUS FOR ME AND FOR
  192. SES: Multiple Cylinder Misfire?
  193. 2000 Stratus Crankshaft Position Sensor Question
  194. 01 dodge stratus 2.7l v6 engine swap
  195. "Shifting" and CE light question
  196. 2005 Dodge Stratus Sedan - Steering Recall (12-23-04):
  197. Newbie with a stratus need help with belt
  198. 04 Strat r/t coupe ?'s
  199. Here is my flystratus98 years of work including new engine all done by me from system to mechanic wo
  200. Computer Software Upgrades?
  201. 97 Stratus with Check engine light on
  202. problem tranny?
  203. 2000/2001 Stratus SE - What to look for?
  204. 1998 Dodge Stratus
  205. new stratus
  206. got a new code p0420
  207. What to look for when buying used '98 2.5lx
  208. Dodge Recalls Durango - Seabring - Stratus
  209. 98 stratus oil light?
  210. Posessed HVAC??
  211. Engine no start 2000 dodge stratus 4 cylinder
  212. 1/4 mile question...
  213. Parts Magazines?
  214. humming noise on 2001 stratus
  215. Newbie question
  216. darn ash tray lid!
  217. 02 R/T wheels AGAIN
  218. Intrepid SXT wheels/tires on 99 Stratus?
  219. Intrepid SXT wheels/tires on 99 Stratus?
  220. strange fan problem on 01 stratus
  221. 02 R/T tires and wheels
  222. How do i disable the seat belt alarm??
  223. 2004 Dodge Stratus sxt 2.4L
  224. High idle when cold....
  225. Testing interest! Please bare with me.
  226. Transaxle flush with ATF+3
  227. Trim model
  228. motor mount help
  229. Cirrus trouble
  230. 2001 Sebring LXI winter tire help?
  231. A lot of ... wishes
  232. Odometer problems
  233. Newbie: dash lights question
  234. 2005 Model Year Sedan Recall: 11-02-2004:
  235. "Service Engine Soon"
  236. Trannie Trouble
  237. super charger w/ innercooler
  238. 04 Stratus R/T Alarm?
  239. Am hood 03 strat
  240. K&N Intake
  241. NEW-B!!!
  242. Tail lights
  243. my dodge needs help
  244. Stratus or Interprid
  245. sparks plugs
  246. 1996 Battery
  247. AIT sensor
  248. 01 Stratus programming
  249. 2005 Dodge Stratus Special Edition:
  250. 96 dodge stratus
