View Full Version : Dodge Stratus
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15
  1. Electrical problem!
  2. a/c
  3. idler pulley for timing belt
  4. oil pump gasket ?
  5. R/T Badges went bad
  6. Good price for tint?
  7. Serpentine belt-2000 Sratus
  8. temp sensor
  9. my 2006 dodge stratus dashboard and tail lights are out
  10. 97 Stratus not starting
  11. Crankshaft and Camshaft relative positions
  12. Blower motor?
  13. Sludge begone!!!!!!!!!
  14. air conditioner
  15. Hitch for 1996-1998 stratus
  16. 01 stratus r/t headlights and taillights
  17. 99 Stratus High Beam Indicator Light Stuck on!
  18. Codes P1698 and P0500
  19. Vibration on braking
  20. Stratus stalls at idle and when changing into reverse
  21. Engine Idle, Speedometer, Trans Issue
  22. Angel Eyes Projection Headlights
  23. turbo strat sxt
  24. 1997 Stratus Brake Issues
  25. New member - 02 Strat R/T
  26. cv shaft or wheel bearing
  27. Little black box????
  28. What is this part called?
  29. service manual
  30. Stock Speaker Help Needed
  31. AC compressor blows Radiator Fan Fuse
  32. Adjusting Headlights
  33. Conflicting ideas on spark plugs
  34. Fan not working
  35. Dumb Dumb questions:)
  36. Won't shift, no speedometer, messed up fuel gauge 01 Stratus
  37. Dodge Stratus LED Tail Lights 01 02 03 04 05 06
  38. locations
  39. Oil Pressure Light
  40. Immobilzer problems...Pleeez HELP!!!
  41. changing HUB bearing
  42. tune-ups
  43. Engine/ Transmission swap for 2001 Stratus
  44. need HELP
  45. Aftermarket Header Question
  46. Replacements for stock struts?
  47. octane
  48. Clear tail lights
  49. Newbie to the Stratus
  50. 02 Stratus R/T
  51. 00 stratus SE 2.4
  52. Rack & Pinion
  53. '04 Stratus R/T Coupe Exhaust Noise
  54. Interior Power Failure
  55. rear window override?
  56. 97 Stratus hesitation problem - HELP!
  57. P300 after engine replacement. PCM Conflict?
  58. 2001 - Weird A/C issue - Shop said everything was fine
  59. I'm concerned about driving this car again
  60. Noisy front end
  61. Recommendations for replacing my coil pack and other ignition mods?
  62. Headlight Switch
  63. brake system on base 1998 stratus
  64. I'm too afraid to drive this car again
  65. 02 Stratus dieing
  66. Do 14" Neon rims fit a 99 Stratus?
  67. Engine swap question
  68. 1996 2.0L ATX - remote door opener
  69. 1996 2.0L ATX - Radio failure - tape piece fine
  70. How can I access engine codes for my 2005 Stratus Coupe R/T?
  71. 2000 dodge stratus died
  72. 2003 Stratus idle RPMs bog.
  73. Just sold my '95 for $1200...lol
  74. A/C is overheating and not working on dodge stratus 2002?
  75. what is this part called??
  76. Electronical Problem Possibly??
  77. AC cycles goes on and off
  78. Air Conditioner Fissure
  79. cars dies
  80. stratus es 2.5 wont start
  81. Tune Up
  82. buying parts at the parts store
  83. Engine knock....i think
  84. 02 stratus
  85. 2001 Stratus Heat/AC All Problems
  86. 01 stratus radaitor plug
  87. Rear tires are kicked out.. what parts do I need?
  88. Car dies, then sometimes it starts immediately.
  89. 1999 breeze transmission swap HELP!!!!
  90. Anti lock brakes or not?
  91. spring replacement
  92. rattling noise
  93. Engine dying when operating temp. reached
  94. first car... need sites
  95. Instrument light bulb size Stratus R/T 2002...Wanting an engine swap
  96. Asking for info about the dodge stratus
  97. 01 Stratus A/C unit, help. Anyone can help
  98. HELP transmission swap but torque converter dose want to line up with flywheel bolts
  99. 2002 stratus tranny
  100. 2000 stratus 2.4 crank balancer removal
  101. Performance mufflers?
  102. Ecm/pcm
  103. Lowering Kit
  104. 01 Dodge Stratus R/T issues...
  105. Engine replacement what else should I do?
  106. 02 stratus r/t haynes manual
  107. Looking for headers for 01 dodge Stratus 3.0 R/T
  108. 2004 Coupe Headlight Removal
  109. Couple questions, 1995 2.0 stratus
  110. any info on 04 sxt?
  111. 1999 Dodge Stratus oil leak
  112. Radio woes
  113. code po703
  114. grade of gas
  115. Flashing of the onboard computer
  116. 1997 stratus bucking
  117. c.v. joint/half shaft replacement
  118. Plenum removal for tune-up
  119. Trouble with running
  120. Tranny question
  121. Question about the factory rims on my 02 R/T
  122. Dropping fuel mileage
  123. Serpentine Belt Replacement
  124. '01 Stratus SE Intermittent Heat
  125. Stratus R/T Transmission
  126. Where's the battery???
  127. 2001 squeaky suspension
  128. where to ground???
  129. Big 3 upgrade
  130. Help 1999 stratus transmission went out
  131. dodge stratus 98
  132. P1775
  133. power steering pump
  134. 2004 Dodge Stratus
  135. 2000 stratus fuel filter question
  136. Need to replace a hose on my stratus
  137. Stiffer ride for 2001 stratus, help?
  138. To Replace the Clutch?
  139. 2003 Stratus 2.4L
  140. 2000 Stratus wheel problem
  141. Bad catalytic converter?
  142. Water pump outlet pipe
  143. '07 Third Brake Light bulb is out. How to replace?
  144. Rough startup and ideling
  145. engine swap or rebuild
  146. 05 stratus env controls fubared
  147. Problem with starting
  148. 2002 stratos auto transmision
  149. Air Bag
  150. Code p442
  151. 2000 Stratus brake rotor tolerance (searched!)
  152. Leaks around tranny/block area
  153. Leak under front of Stratus
  154. Engine rebuild, with pics
  155. Remote Key Programming
  156. Buying Engine Mounts for '95 stratus, 2.0L????
  157. Routine maintenance rip-off????
  158. 2000 Dodge Stratus 2.0 Engine Seized?? HELP!!
  159. Timing belt
  160. clutch Replacment
  161. duel edge map sensor enhancer
  162. 2001 Dodge Stratus 2.4 dohc timing help
  163. 2001 R/T Factory Alarm
  164. need some help on my engine swap
  165. motor mounts
  166. What kinda of trans fluid is compatable with mitsubishi
  167. Sometimes sarter cranks good, sometimes no juice
  168. 2000 Stratus 2.4 dohc idle issue
  169. 2003 stratus trans ??
  170. Anyone have a rear sway bar for a 00' 2.4 sedan?
  171. 2001 Stratus R/T - Fan blower won't work
  172. Stratus intermittent p0340
  173. Very high idle after cleaing EGR valve??
  174. 1998 Stratus Wont Start with Code P0340
  175. 04 status wirng?
  176. My car thread
  177. Starter Fuses Blowing
  178. Programming Key Fob
  179. Air Temperature Sensor
  180. Stratus R/T Coupe Tapping Noise
  181. 1995 stratus es update.....
  182. 01 Dodge Stratus Se Steering Wheel
  183. How do you reset computer on 01 Stratus
  184. Multi Port Injection
  185. chip tuning, remapping ???
  186. stratus r/t parts
  187. 99 stratus autostick shifting problem
  188. What Model Stratus do I have?
  189. 1995 stratus help
  190. 2000 Stratus tire problem
  191. '98 Stratus headlight issue?
  192. WTB a Stratus; ABS Option how many are out there?
  193. 2000 2.4l se with P0403 code
  194. Brake pedial travel
  195. Trip Odometer in 1996 Stratus
  196. How to change instrument cluster backlight color?
  197. difficulty level of chaning a wheel bearing?
  198. Opinion on buying used 2005 Stratus SXT 2.4
  199. 2005 Stratus SXT 2.4 DOHC problem...
  200. 04 Stratus P0303 Cylinder 3 Misfire Detected
  201. 2000 2.4 Stratus Fuel Pressure?
  202. Shift Solenoid
  203. 06 Stratus SXT windshield cracking
  204. 98 dodge stratus knocking noises
  205. 2005 Stratus SXT Coupe Bumper Covers
  206. 2000 2.4 flasher relay
  207. Knock sound when starting warm engine.
  208. High idle. iac or something else? 3.0 v6
  209. 1999 stratus Bucking (surging)
  210. 01 stratus r/t high rpm issues
  211. 99 dodge stratus es wont start
  212. Front wheel bearing Stratus 2006
  213. Need Mechanic in Cleveland OH
  214. 1996 dodge stratus ecm problem
  215. Cleveland, Strauts 2006, grinding noise
  216. Strauts 2006, grinding noise
  217. Turbo 2.4?
  218. I got pulled over today...
  219. I got pulled over today...
  220. 2001 Dodge Stratus Fog Light Lamps.
  221. Which engine do I have?
  222. Rear Creaking Noise
  223. Reverse lamps stay on
  224. 04 Serpentine Belt Tensioner
  225. stratus p0071 ambient air temp sensor range/performance
  226. Auto tranny popping into neutral
  227. Hard start / No acceleration / Fast shutdown
  228. Need help with Stratus' twin the "Breeze"
  229. Opinions on buying a used 03 stratus SE 2.4L coupe
  230. 2005 Stratus Coupe 5 speed Shifting rough
  231. Little tutorial to change Valve Gasket Stratus 97 2.4 DOHC
  232. Transmission problem
  233. 2001 Dodge Stratus sedan: where on earth is the rear defogger/defrost fuse?
  234. Replacing speakers, Need a little help
  235. '00 (1g) ES V6 Valve Cover Gasket bad?
  236. HID questions regarding the Stratus Coupe
  237. Prototype LED taillights
  238. Dodge Stratus 97 2.4 ... Transmission Fluid change?
  239. heater core? maybe?
  240. 2005 stratus 2.4L spark plugs and wires change
  241. Oil Light On Sometimes
  242. 2000 stratus fuel pump?
  243. P0700 & p0730
  244. Help! - weird electrical gremlin
  245. Engine heater block or....
  246. Problems with my gas mileage on my car
  247. Start-up noise - 3.0 R/T Coupe - Valves?
  248. Interior Lighting on Steering Wheel and Shifter??
  249. Car maintenance
  250. The Biggest Hooptie Repair Ever?
