View Full Version : Dodge Stratus
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15
  1. Idle Speed reset
  2. 00 Stratus ES radio/dashlights problem
  3. Crossed wires?
  4. 2001 R/T Auto Transmission Concerns
  5. Air Bag Light/Sensor?Belt...
  6. Brake drums/shoes
  7. I dont know how to explain this...
  8. Cel
  9. what do you think the problem might be?
  10. need info on wifes dodge
  11. Electrical/ Circuit breaker question
  12. Keypads and backseats
  13. Ongoing steering problems
  14. Installing aftermarket stereo setup in '04 RT
  15. link pin
  16. Where is the ASD relay on a 95 stratus?
  17. 2004 Stratus R/T Coupe Alternator Problem?
  18. 2005 Stratus Tranny and Front End problems
  19. head gasket
  20. 2.4 oil pick up tube question
  21. !!!!rims will not fit my stratus!!!!
  22. New R/T Owner
  23. '05 2.7 Heater
  24. Power Steering only one Direction
  25. Transmission problem with my 02 stratus SE
  26. 03' stratus.. please help!! Heater core??
  27. '98 stratus problems
  28. Should I buy a Stratus ??
  29. Really Stupid But Serious Question
  30. HVAC noises
  31. what is the size
  32. ventilation problem
  33. How Do I Obtain Error Codes?
  34. Performance Modules
  35. Build List
  36. 98 Stratus Oil Pressure Light HELP PLEASE!
  37. Fog light relay?
  38. Factory Cd changer
  39. 01' RT Serpentine Trouble
  40. Turboing Stratus
  41. type of transmission fluid?
  42. Jumping Starter Relay?
  43. Questions
  44. transmission, hard downshift,kickdown problem
  45. High RPM
  46. Alternator quit charging, battery dead.
  47. 95 stratus rpm guage is not working
  48. Air Bag Light On
  49. 96 stratus stuttering problem
  50. gauges
  51. dodge stratus
  52. What is this part?
  53. Oil Pressure Light Problem - 2004 2.4L
  54. '00 Stratus Door Sensors for the Interior Lights.
  55. Parking Brake Adjustment
  56. 05 Stratus Sub install
  57. Rear Disk Brake Conversion
  58. Clutch Pedal Makes Popping sound
  59. Horn blows by itself.
  60. sputtering when stopped
  61. Thumping noice in new front rotors on 1997 Plymouth Breeze
  62. 2001 Dodge Stratus R/T Overcharging - high voltage at Alternator / Battery
  63. Custom headlight for sale for your 01-02 Stratus Coupe
  64. New on Stratus. Help Please :)
  65. Replacing a bushing on a 2004 Dodge Stratus R/T?
  66. 04 Stratus R/T manual transmission remote starter
  67. Intermitent Charge Light
  68. 2002 2.7L Stratus Sedan Spark Plug Change and Fuel Filter Change Question
  69. 1998 Stratus wont start, NEED HELP!!
  70. belts grrrr.
  71. Power Seat Problem
  72. someone please help!!!!!!
  73. Autostick conversion
  74. 2000 front end squeaks like an angry pig
  75. Bright lights turn off headlights
  76. shocks/struts
  77. No warm air at idle
  78. 97 Stratus, morning start up.. constant Stalling
  79. Stratus 2.7 vs Intrepid 2.7 (among others)
  80. 04 Stratus 2.4L
  81. 2004 Stratus V6 - Won't Start
  82. Headlights and tail light questions
  83. Question about: Fuel pump on stratus 96 2.4L
  84. will this fit
  85. new owner 2005 need antenna and user manual
  86. Noise behind or in dash
  87. EGR Valve On 97 Stratus
  88. Odometer Light OUT, and RPM neddle in 0
  89. 2004 Dodge Stratus Help
  90. Camshaft sprocket notches
  91. cleaning my airfilter
  92. Where's cig lighter/horn fuse?
  93. Rear Crankshaft Oil Seal Replacement
  94. trunk
  95. newbee
  96. pic request
  97. Brake fluid
  98. Air flow sensor "Clock" position ?
  99. Engine studders at ~4k rpm
  100. Rear Brake Seize
  101. 2002 dodge stratus heating until 3/4 the fans start
  102. 96 2.4 timing belt tensioner same as 2.0
  103. Trunk Release not working
  104. Questions
  105. Knocking noise (96 Strat)
  106. new spark plugs and wires
  107. Which Hub Is It
  108. gas fumes
  109. Brake Releasing Issues
  110. Brake Job
  111. Smoke from transmission dipstick!!
  112. '06 Sedan PCM flash and Performance Upgrades?
  113. 2001 stratus ecu questions
  114. What to do...
  115. Car Idles At High RPMS...
  116. 05 SXT Cooling fan turns on and off
  117. Dtc p0304 ??
  118. stuck e-brake
  119. New pics
  120. 05 Stratus Gas Gauge Problem
  121. Starts then won't start
  122. 03-05 Coupe owners with OEM chrome wheels
  123. Power steering fluid
  124. Sustained high speed - 90Mph or more
  125. fuel pressure test adapter?
  126. 02 dodge stratus boiling over??? Help!!!
  127. Poor idle and codes
  128. 98 2.4l are the valves knockin or
  129. 01 R/t Coupe 2 door 3.0 ltr, rear suspeneions help
  130. Anyone running on Water/Hydrogen??
  131. Dash Problems
  132. "Auto Lock" activation
  133. Help! Brakes start locking when hot!
  134. rpm
  135. Radio wiring schematic
  136. Steering judder
  137. 02 stratus hard to shift into 1st gear
  138. EGR Valve
  139. rim specs
  140. Stratus 96 questions
  141. 2004 stratus speed relay
  142. 98 Stratus - VSS
  143. 2000 ES V6 Security Key???
  144. 04 R/T problems
  145. Removing Stratus R/T 3.0 Transmission - help?
  146. Unknown Hose Name
  147. Which Headlight Bulb Lasts Longer
  148. Replacing A/C Comp....Special Tools?
  149. Roof Rack Questions
  150. 97 stratus tranny problems
  151. DF Video!
  152. Idler Pulley Bolt
  153. Stratus making rattling sound and gas pedal shaking????
  154. Master Cylinder change out
  155. 2003 Tansmission Stuck In Limp
  156. 02 stratus idler shock
  157. Keyless entry Q
  158. 2001 Stratus quits randomly
  159. Random question...
  160. Help Finding Parts
  161. P0203 and Engine Control Module problem
  162. can anyone help???
  163. 99 Rough Idle w/ Air on
  164. Major car problem and leak
  165. 2003 Rough Idle/Jerky acceleration
  166. What The &%$#!!!!!
  167. Flashing Check Engine Light on 2004 Dodge Stratus
  168. serpentine belt
  169. 02 Stratus Coupe 3.0 V6 not stalling out not starting
  170. 2004 Dodge Stratus SXT 2dr 78k $7200 OBO
  171. car acts as if it wants to shut off....
  172. 2005 dodge stratus - problems
  173. 99 2.4 high idle
  174. 1st gen 2nd gen
  175. Engine Control Computer (For Sale)
  176. Dodge Stratus DF Group! Join!
  177. Headlights????
  178. Help
  179. For Sale - 2003 Dodge Stratus 2dr Coupe Body Kit
  180. was in a fender bender now wont start
  181. Possibly Elec Probs? Pwr Windows & Locks
  182. Should I or shouldn't I
  183. rim diameter
  184. Dodge stratus help
  185. help! How to pressure test fuel line on a 2001 stratus r/t ?
  186. new ecu
  187. adjusting head lights
  188. The stratus is getting some new paint..
  189. Stratus engine schematic
  190. clicking noise &
  191. A/C clutch fried, can I still drive it? or do I have to replace the compressor
  192. A call to stratus R/T GURUS
  193. Ign/Fuel/Sater Fuse keeps blowing 99 Stratus
  194. Help with decoding codes
  195. cold air intake v.s. short ram intake
  196. tranny problems - please help
  197. New pics!!
  198. 2001 dodge stratus SE
  199. Anybody come across an R/T with a Black Matte finish?
  200. i need help buying HID Xenon Conversion kit!!
  201. Factory Alarm and High Beams (2001 R/T)
  202. Dodge Stratus Front End Noise
  203. Car Trouble-Hard Shift
  204. Car Trouble
  205. ok whats next
  206. my car makes this sound... need help
  207. Low End Engine Noise - Knock
  208. Is This Worth It?
  209. driver door won't close with others-sync problem
  210. brake light trouble
  211. Window Motor - Stratus 99
  212. Dodge Stratus R/T Questions
  213. Radio Bass Treble mid flashing
  214. 1999 Stratus Wont Start
  215. Hi Flow Cat
  216. oil leak
  217. HELP ME PLEASE!!!!
  218. 99Strat airbag/brake lite on...no electrical
  219. obd read code of P1494..Help.....
  220. 2000 Dodge Stratus AC button problem
  221. soft brake
  222. odometer reading
  223. Blower won't stop
  224. Hey everyone
  225. Springs
  226. Help With Turbo Options. Please!
  227. 2000 stratus - steering column problem????
  228. pesty oil leak on 1999 dodge stratus
  229. HELP FAST
  230. Photoshoot 6/29/08
  231. Some night pics of my Stratus
  232. stratus
  233. 2005 2.7 Dodge Stratus Running problem
  234. fan speeds on climate control-1+2 inop, 3+4 ok
  235. Stratus SWAP NEED HELP
  236. Stratus SWAP NEED HELP
  237. air temp sensor?
  238. 2002 Stratus Tranny Trouble HELP!
  239. TURBO QUESTION.
  240. RIMS
  241. Unusual Problem With 2005 Stratus ... Need Help Please.
  242. Please Help.
  243. Popcorn Noise or Popping Noise from the front drivers side of a 2004 Stratus
  244. HELP WITH CLUTCH
  245. Gas Savers?
  246. Horrible Shaking on Startup, CEL on
  247. Replacing air filter on '04 Stratus 2.7L
  248. small crack in oil pan
  249. 1995 2.0 shudder under load
  250. 2004 sedan front end knocking
