- Remote Starter Recommendations
- octane question 3.0
- problems with engine
- Trunk Release And Remote Down, They both won't work
- 2.5 V6 has timing belt or chain?
- 05 rough idle
- Coolant Leak
- 02 R/T ... Black paint going bad
- whereee can i get a custom
- 1998 Dodge Stratus Pop Noise
- Heater - blowing cool air only
- Won`t turn over 3000 rpm
- Need help once more
- 01 Stratus Coupe...LOST KEYS!!!
- strut bar and suspension
- 1999 Stratus Axle replacement
- Maximum rims size for Dodge stratus sedan 2.4?
- Couple of issues with a 98 Dodge Stratus
- Power window
- KillerGlass custom glass radiator hose piece for sale.
- True Flow Air Filters
- strange sound from my stearing
- Need New Doors
- Looking at a 98 Stratus, anything to look out for?
- 05 Stratus trunk won't latch
- code p1492 help
- I'm A Beginner Can Somebody Please Help Me
- Stratus Headlights are very dim
- trans replace
- 97 Dodge Stratus Overheating
- Any Help for a '97 2.4L???
- How are HVAC bulbs replaced?
- 1998 dodge status mods
- I cant control the heat its always on hot??????
- Teaser Pic CF Hood (NEW PICS ADDED)
- Aftermarket Stereo
- 96 stratus blown pcm, asd fuse
- How Much Should i be Charged
- Brakes
- I just bought a 2001 Stratus ES what should i expect?
- engine swap
- 1995 DODGE STRATUS STALLS
- Woman that Need Help info bout my 1997 dodge stratus
- Tip for "baking" crank pulley
- 5 strange codes all at once
- Value of 02 R/T
- anyone need a 2.4
- 2000 Stratus headlight switch turns on wipers
- EVAP system: can one go beyond just reading the code P0441 without taking off the gas tank?
- Trani question
- computer for transmission
- oil catch can
- 98 stratus radiator change??? is there a diy
- Blower on high only
- AC Compressor
- firewall in 2006 stratus
- HOW TO RUN WIRES IN 2006 STRATUS
- 97 Stratus 2.5 Starts then Stalls Why???
- another 95 es problem
- 99 Stratus ES Keyless Remote
- Driver Door Auto-Unlock All Doors
- is it bad?
- sensors
- Headlights
- Rear brake squeek
- How to install indash cd changer?
- Help!Sunroof wont close
- Coolant leak near oil pan
- Air Box?
- HID retrofit?
- Stratus Exhaust
- Oil Change ????
- How to remove headlight cover?
- Anyone know what this bracket is? 1996 Stratus 2.4l
- New Dodge Forum Decals. Got Mine!
- Howdy
- 01 Coupe Dash Cracks
- 2.4l engine
- 2001 Stratus R/T coupe question
- 1996 dodge stratus 5 speed clutch problems
- Intermittent Dash Problem
- 03-06 Stratus Coupe CF Hood on EBAY
- buying viper hood
- Front License Plate Mount?
- 2000 stratus driver door opening when driving
- P1243 Problem
- 95 stratus MAP sensor location HELP !!!
- Help pls. Codes P0605 & P0700 on a 2001 Dodge Status Transmission
- 01 stratus wont start
- Oversize my oil filter?
- Suspension "Thump"
- K&N FIPK Gen2 (Fuel Injection Performance Kit)
- 02 with 05 , can i make it work ?
- Odd Idle
- 2.5L w/o A/C???
- 01 Wants to die at lights
- 95 Stratus 2.4 loud vibration in Drive
- 97 Stereo Install
- 02 Stratus R/T clear tail lights?
- Installing speed sensor
- Bumper
- 04 stratus stalling
- 98 Stratus Engine
- Aftermarket accessories.
- Tick..tick..tick, but I don't think it's exhaust
- Mystery wires attached to the steering "box"
- flickering brake warning light on dash
- 96 dodge stratus bent valves ?
- Engine Swap
- shift button not locking in place
- POA valve high side a/c hose
- 99 intake help
- '97 Stratus Upper O2 Sensor
- Daughter's Stratus Water Pump Help
- 2004 Sebring 2.7 swap ?'s
- JB Weld Saves Money
- headers
- I'm back!!!!
- Valve Cover Gasket Replacement - CAUTION
- 2.4L exhaust
- 2000 Stratus is stuck in first gear.What is?
- lowering question
- i want to lower my 2001 stratus 4 door es
- need help car wont start
- UPS I shortened (hit - with a +) audio wires..
- Replaced CPS and still hard starting
- 2004 Ford Stratus
- 2001 Stratus ES Copue (another radio question)
- Need repair in port st. lucie Fl.
- Getting subwoofer powercord under the hood..
- ABS light stays lit on 01 stratus
- Speedo not working
- 2004 Dodge Stratus and Keyless Entry
- Car Alarm Went Off - Car Won't Start Now!
- hey guy with question
- EGR & EVAP leak
- What octain fdo I need in my 03 stratus coupe r/t 3.0 v6?
- 2003 Dodge Stratus R/T Key Immobilizer Security System
- more power!!
- Custom exhaust for 2.4L
- Clear Coar Coming Off. not cool...
- Driver's Side Front Door Replacement
- Painting Headlights
- 96 stratus question
- 2004 dodge stratus problems?? help
- Coolant Level Down After Drain/Refill
- noise!!!!
- about to purchase?
- I'll be adding a CarPC to my 03 r/t coupe
- Addition of Keyless entry
- Strange Start Up Problem
- New to the site...
- Air conditioning/heater switch not working right.
- stratus 98 fuse #5 keeps blowing at high RPM
- 4g63 stratus swap
- Cracked Front Bumper
- Exhaust Clip...
- 98 Dodge Stratus Electrical Problem??
- Crossover Pipe R & R -- '96 V6
- Retro fitted or aftermarket fog lights?????
- Stratus stalls...:
- cold air intake for sale $25 SOLD!!!!!!!!!!!!!!!!!!!!
- How you think ? 03-06 Stratus/Sebring Carbon Fiber Hood
- 05 stratus wiring question
- New member to Dodge Forums
- '96 stratus electrical problem
- Need info on tbs 24-018-05 for a Stratus
- My Subs Wont Work HELP!
- Tranny swap
- A/C Problems
- RPM Problem
- Stratus stalls
- Need Help!
- program door opener
- loose rattling noise near engine area
- Drove through deep water now stalled
- 04 dodge stratus clunk
- FLASH ECM????
- Need pictures of Stratus R/T Coupe
- 98 stratus temp keep going up and down
- 05 R/T 3.0 Fuel Filter
- Getting ready to sell 2001 R/T, need advice on some problems please!
- very important questions.
- Supercharger or Turbo charger, whats better whats different?
- Air filter upgrades
- 98 Stratus wont start
- 02 Front bumper removal help
- Water under passenger seat! HELP!
- Is the Transmission Gone?!?
- 2001 RT RADIO WIRING HARNESS PROBLEM
- P1610 whose got the secret
- 02 Stratus R/T 2dr Coupe...(Hood cover)
- 05 Stratus SXT improvements???
- I keep blowing fuses- Please help!
- timing belt broke
- Error code
- wire harness help!?#$%$
- Coolant Change Procedure?
- 2.4 overheating can't figure out why..Updated Fixed
- help!
- 2000 2.4L PCV valve location?
- Oil pan and gasket
- Mitsubishi Aftermarket parts
- Problems
- Ok this is easy for you guys HELP
- I need some help quick
- clacking noise
- Huge Electrical problem
- 2001 A/C Question
- tranny problems 01 Stratus Coupe
- 2000 Thermostat
- need advice on oil pan on97 stratus
- 01 Stratus 2.7 DOHC camshaft position sensor location
- WHAT IS GOING ON WITH THIS CAR??
- woops
- Difference between '98 and '00 engines
- strange problem
- a few more questions....
- HELP! 1998 Stratus 2.4 Not Starting??
- Help!! '98 Stratus Headgasket Replacement
- 98 2.5 external coil modification
- 2004 Stratus
- no spark 2002 dodge stratus
- removing oil pan 1997 stratus
- tranny cooler lines
- how to test fuel pump
- 2000 Dodge Stratus Air Conditioner Problem
- 2002 stratus stereo install
- pull codes without computer
- 2002 dodge stratus 2002 rt 2.4 no gas at when cranked
- horrable sound on start up
- help!!!!!!
- service engine soon light! grrr
- Any one with a 2.4L
- Homelink help(not programming help)
- 2001 stratus rt wont drive when service engine soon light came on
- 97 Stratus - need speakers
- ahh... the '99 Cirrus
- Trans Filter 03 Stratus coupe 4cyl?
- Starting problem
- Leaking?
- '05 Stratus stalling.
- speedometer & transmission
- "auto" power window won't work
- Someone please help a desperate man here!
- rough idle and power loss
- need directions on how to cange lower ball joints on 97 stratus
- first dodge strat.want to unleash its potental
