View Full Version : Dodge Stratus
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15
  1. de badge
  2. Need help with electrical windows
  3. Blinking A/C light
  4. Looking For 01 Stratus Door Panel!
  5. Car/Truck of the Month
  6. 2.0?
  7. '02 Stratus Trans issues - have codes
  8. new stratus owner with some ?'s
  9. Electical issue HELP!
  10. 97 ES fuel Filter location:
  11. Replacing brake light on 04 Sedan
  12. 01 Stratus Stereo Advice Needed
  13. 96 Stratus TCM Padding Material
  14. Turbo KIt
  15. How do I remove a governor on my 2000 Stratus ES?
  16. STS Turbo
  17. Help Don't know where to start 97 Stratus 2.4l
  18. PCM part number
  19. 2003 Stratus anti theft system
  20. Remove door trim around lock/unlock and window switches
  21. HELP!!!
  22. Shifts to 2nd instead of OD
  23. 2001 Stratus Coupe stereo console problem
  24. 2001 Stratus RT Coupe Front Struts
  25. 01 STRATUS RT 20 INCH RIMS
  26. 97 Stratus 2.5L V6: "Normal" oil pressure at idle
  27. Engine Rattle at shift points and idle at 2k rpm
  28. anyone have a dash for sale????
  29. Front end noises
  30. Stratus aftermarket carpeting
  31. paint bubbling
  32. Help: any 41TE rebuild experts here?
  33. water pump 2.4 2000
  34. Floor wet under mat
  35. need help
  36. 97 Stratus stock stereo problem
  37. performance
  38. Any way to test a PCM ?
  39. 95 Stratus PCM/ASD and Battery Hook up Wrong
  40. engine light-non flashing
  41. EGR Problem
  42. 95 Stratus ES Stuck in 2nd Gear
  43. Stratus cuts off
  44. Need Altezza's or Clear Tail lights for 2008 Stratus
  45. Question about placing battery ground wire.
  46. Looking for new headlights
  47. 2001 Stratus Sedan 2.4 for sale
  48. Stratus 2004 Fuel filter/online retailer
  49. Trans in "limp" mode
  50. Quick A/C Question!
  51. 02 Stratus R/T 3.0 Battery problem
  52. A/C recharging
  53. What about 04 R/Ts?
  54. Buying first Stratus and I have Qs
  55. Car loses power when accelerating
  56. 98 Stratus 2.4 radiator fans not coming on
  57. 99 ES Questions from new owner
  58. '01 Stratus questions.
  59. CD Player connections.
  60. What Do You Recomend?
  61. Newbie Stratus 1996 Help Request
  62. Decreased Shift Time (standard)
  63. CMTC temp problems
  64. What spark plugs to run
  65. 98 transmission
  66. Leaking R134 air cond
  67. 01 Dodge Stratus recalls
  68. Shift Solenoid
  69. Accessory signal not received by radio
  70. 2000 stratus
  71. turbo kit
  72. appearance
  73. Sirius Re-Install from Ram to Stratus
  74. locking gas caps?
  75. Stratus 1998 Immobilizer
  76. Help 2002 Stratus 2.4L
  77. I think it died....
  78. Changing speed sensor on 2000 Stratus
  79. Problem with the battery or could it be something else?
  80. Is there anyway this could be true?
  81. chirping noise in transmission
  82. nos question
  83. gas mileage?
  84. Adding aux input to '01 factory radio
  85. Bleeding brakes
  86. Could a faulty speed sensor cause 3 other codes?
  87. Manual Transmission Fluid
  88. Corrosion Warrenty
  89. I have an 04 Stratus SE editon
  90. SE/RT
  91. Electrial Problems Need serious help
  92. 98 radiator reservoir boils
  93. Replacing hood emblem
  94. Stratus from the future!!!
  95. Just bought a 97 Stratus, have a few ?'s
  96. where is my fuel filter?
  97. 2005 Stratus Cruise Control
  98. Mechanic replaced rear oil seal now leaking transmission fluid. Need to troubleshoot.
  99. Need to bleed clutch on my '02 stratus rt
  100. Suddenly the motor stops! (Electrical?)
  101. Black 02 R/T Paint Peeling on Roof
  102. Tranny Coolers?
  103. 02 r/t coupe antenna
  104. 99 Stratus - persistent brake noise
  105. seatbelts
  106. '99 AC issue
  107. 97 2.0L engine bog/loss and noise
  108. Question about touch-up paint..(PX8 vs PX9)
  109. stratus drag race
  110. New to forum/Stratus's
  111. Is the sludge monster coming?
  112. Timing belt tension pully
  113. CamShaft Position sensor location
  114. help
  115. Engine replacement
  116. Fuel Economy
  117. 98 Stratus
  118. 04 headers
  119. reset computer
  120. fuses
  121. IGNITION REMOVAL
  122. 1999 stratus struts
  123. cv joint, axle, or struts??? or other
  124. Need Help ASAP!
  125. How to mount front license plate???
  126. stratus shift hard
  127. dodge daytona?
  128. 1997 Stratus HELP PLEASE
  129. 02 Gauges
  130. My Stratus R/T
  131. 97 Breeze Air Conditioning turns off after engine warms up
  132. Problem?
  133. New problem, where does Neutral Conductor Cable get plugged in?
  134. I can't find my paint code
  135. 1998 stratus wont start
  136. Any mechanics here?
  137. General A/C Question
  138. wont start
  139. how do i get power
  140. 99 abs computer location
  141. '06 Stratus R/T (4 door) production numbers
  142. 2004 idling problems help!!
  143. rear disk Brakes
  144. huge A/C problem...
  145. engine swap
  146. 97 strat - strange clunking noise suddenly
  147. Hey everyone im trying to sell my Stratus.. its a 1995 full work around it re-done engine..
  148. got in an accident.;(
  149. Parts for mt 05 sxt coupe needed
  150. '02 Air Conditioning
  151. Blower Settings
  152. Is it worth fixing rear engine seal with car that has 205,000 miles?
  153. Water Pump
  154. Check angine light
  155. Cigarette lighter Problems (2004 Stratus)
  156. blower only running on high
  157. 99 stratus abs fuse keeps blowing
  158. 02 Stratus Noise ..PLEASE HELP..
  159. Instrument Panel Backlights
  160. 99 stratus O2 Sensor Location
  161. Help with rear brakes
  162. Odometer and Tach not working???
  163. Arizona Residents Unofficial Meeting 5/26/07
  164. '01 Stratus R/T - 5 different codes given!
  165. Help with 2001 R/T Code P0403
  166. Plastic under car behind bumper
  167. Rear Speaker deck access help
  168. P0451 CEL Problem
  169. Pwr locks, radio, and int light not working
  170. Tighten belt tension
  171. 97 Strat - Upstream O2 sensor location
  172. 98 stratus A/C issue
  173. Wiper Blade Problem
  174. is this thing really works ? help please
  175. 6 speaker system needed for stratus
  176. performance chip help!!!!
  177. The Noob Questions
  178. tires and rims for 02 stratus 2.7L SE
  179. Parting out Stratus
  180. anti-rattle clip
  181. 01 CoupeTranny Issue Please Help!!
  182. interior neon lights
  183. Musty Smell
  184. will these tires fit OK
  185. Rear Wheel Bearing nightmare!!!!????
  186. 98 stratus 2.5 stalls, bad idle, no codes
  187. 1999 Stratus A/C Problems
  188. A reliable car?
  189. Several "electrical" issues
  190. twisted rack boot, should I worrry?
  191. 2005 Stratus noise coming from the front end
  192. 02 stratus
  193. faster
  194. 98 stratus
  195. New radio bezel for 2001 R/T?
  196. Factory alarm issue
  197. May be buying 96
  198. Hissing noise from brake after replacing rack and pinion
  199. Just saying Hi
  200. 99 stratus 2.4l engine rattle
  201. Automatic to Manual?
  202. 2006 Dodge Stratus SXT Seatbelt help!
  203. 1998 Stratus problems at idle/deceleration
  204. How to take off the air condition vents
  205. Anyone interested in a 2001 sebring coupe?
  206. Springs / Lowering kit
  207. Brake Shoes
  208. Timing Help on 2001 Stratus
  209. 1996 Stratus 2.4L 02 Sensor
  210. headlight eyebrows?
  211. Looking for a few tips
  212. Strut Bars
  213. air condition
  214. Failed Clutch Cable/Self Adjuster
  215. Check Engine Light-Code P0455
  216. 2003 Stratus downshifts hard
  217. 99 stratus, 2.4l timing belt, replace crank/cam seals?
  218. Blower Motor Resistor
  219. front bumper
  220. hoods
  221. New Skins
  222. Fuel Warning Light
  223. need nominations for car of the month
  224. Wheel noise???
  225. Won't start
  226. 2003 Dodge Stratus RT Tires
  227. don't know if this matters
  228. EXHAUST HELP!
  229. 99 dodge stratus cd player
  230. Programming Key Fob?
  231. Help with repl. O2 sensor
  232. Head Light Bulbs (2005 Stratus)
  233. '00 Stratus Interior Panel Pin
  234. 03 Stratus SXT auto temp control
  235. $3.5K for 03 stratus r/t cats?
  236. help with 2000 stratus
  237. A604 Transmission Problem? Come here to solve your problem!
  238. 2000 Intrepid 2.7L v. 02 Stratus 2.7L
  239. Philladelphia area dodge owners
  240. TSB question
  241. 98 2.4 DOHC VIN X starter installation
  242. 96 strat feels like tugging
  243. 97 dodge stratus Oil sensor location?
  244. 2005-2006 Stratus SXT
  245. PLEASE HELP! Stratus Tune Up List
  246. Dropped!!
  247. Cold Air Intake for R/T 3.0 V6 2001 stratus
  248. low pitch horn
  249. Help...what should i do??
  250. Compatible transmissions for 95 Stratus??
