- Shifting issue Stratus 00
- Sway bar link removal
- Shutting off and P1684
- A/C clutch bearing
- Strange rattle coming from under the hood
- Wondering
- dumb dumb question
- Valve cover gasket job
- 2002 2.7L question
- Windshield Washer Pump
- 01 Stratus rattles when accelerating
- About to buy a Stratus
- Cai
- Thermostat
- 2001 Dodge Stratus RPM issue?
- Common parts: Stratus / Avenger
- Electrical problem!
- a/c
- idler pulley for timing belt
- oil pump gasket ?
- R/T Badges went bad
- Good price for tint?
- Serpentine belt-2000 Sratus
- temp sensor
- my 2006 dodge stratus dashboard and tail lights are out
- 97 Stratus not starting
- Crankshaft and Camshaft relative positions
- Blower motor?
- Sludge begone!!!!!!!!!
- air conditioner
- Hitch for 1996-1998 stratus
- 01 stratus r/t headlights and taillights
- 99 Stratus High Beam Indicator Light Stuck on!
- Codes P1698 and P0500
- Vibration on braking
- Stratus stalls at idle and when changing into reverse
- Engine Idle, Speedometer, Trans Issue
- Angel Eyes Projection Headlights
- turbo strat sxt
- 1997 Stratus Brake Issues
- New member - 02 Strat R/T
- cv shaft or wheel bearing
- Little black box????
- What is this part called?
- service manual
- Stock Speaker Help Needed
- AC compressor blows Radiator Fan Fuse
- Adjusting Headlights
- Conflicting ideas on spark plugs
- Fan not working
- Dumb Dumb questions:)
- Won't shift, no speedometer, messed up fuel gauge 01 Stratus
- Dodge Stratus LED Tail Lights 01 02 03 04 05 06
- locations
- Oil Pressure Light
- Immobilzer problems...Pleeez HELP!!!
- changing HUB bearing
- tune-ups
- Engine/ Transmission swap for 2001 Stratus
- need HELP
- Aftermarket Header Question
- Replacements for stock struts?
- octane
- Clear tail lights
- Newbie to the Stratus
- 02 Stratus R/T
- 00 stratus SE 2.4
- Rack & Pinion
- '04 Stratus R/T Coupe Exhaust Noise
- Interior Power Failure
- rear window override?
- 97 Stratus hesitation problem - HELP!
- P300 after engine replacement. PCM Conflict?
- 2001 - Weird A/C issue - Shop said everything was fine
- I'm concerned about driving this car again
- Noisy front end
- Recommendations for replacing my coil pack and other ignition mods?
- Headlight Switch
- brake system on base 1998 stratus
- I'm too afraid to drive this car again
- 02 Stratus dieing
- Do 14" Neon rims fit a 99 Stratus?
- Engine swap question
- 1996 2.0L ATX - remote door opener
- 1996 2.0L ATX - Radio failure - tape piece fine
- How can I access engine codes for my 2005 Stratus Coupe R/T?
- 2000 dodge stratus died
- 2003 Stratus idle RPMs bog.
- Just sold my '95 for $1200...lol
- A/C is overheating and not working on dodge stratus 2002?
- what is this part called??
- Electronical Problem Possibly??
- AC cycles goes on and off
- Air Conditioner Fissure
- cars dies
- stratus es 2.5 wont start
- Tune Up
- buying parts at the parts store
- Engine knock....i think
- 02 stratus
- 2001 Stratus Heat/AC All Problems
- 01 stratus radaitor plug
- Rear tires are kicked out.. what parts do I need?
- Car dies, then sometimes it starts immediately.
- 1999 breeze transmission swap HELP!!!!
- Anti lock brakes or not?
- spring replacement
- rattling noise
- Engine dying when operating temp. reached
- first car... need sites
- Instrument light bulb size Stratus R/T 2002...Wanting an engine swap
- Asking for info about the dodge stratus
- 01 Stratus A/C unit, help. Anyone can help
- HELP transmission swap but torque converter dose want to line up with flywheel bolts
- 2002 stratus tranny
- 2000 stratus 2.4 crank balancer removal
- Performance mufflers?
- Ecm/pcm
- Lowering Kit
- 01 Dodge Stratus R/T issues...
- Engine replacement what else should I do?
- 02 stratus r/t haynes manual
- Looking for headers for 01 dodge Stratus 3.0 R/T
- 2004 Coupe Headlight Removal
- Couple questions, 1995 2.0 stratus
- any info on 04 sxt?
- 1999 Dodge Stratus oil leak
- Radio woes
- code po703
- grade of gas
- Flashing of the onboard computer
- 1997 stratus bucking
- c.v. joint/half shaft replacement
- Plenum removal for tune-up
- Trouble with running
- Tranny question
- Question about the factory rims on my 02 R/T
- Dropping fuel mileage
- Serpentine Belt Replacement
- '01 Stratus SE Intermittent Heat
- Stratus R/T Transmission
- Where's the battery???
- 2001 squeaky suspension
- where to ground???
- Big 3 upgrade
- Help 1999 stratus transmission went out
- dodge stratus 98
- P1775
- power steering pump
- 2004 Dodge Stratus
- 2000 stratus fuel filter question
- Need to replace a hose on my stratus
- Stiffer ride for 2001 stratus, help?
- To Replace the Clutch?
- 2003 Stratus 2.4L
- 2000 Stratus wheel problem
- Bad catalytic converter?
- Water pump outlet pipe
- '07 Third Brake Light bulb is out. How to replace?
- Rough startup and ideling
- engine swap or rebuild
- 05 stratus env controls fubared
- Problem with starting
- 2002 stratos auto transmision
- Air Bag
- Code p442
- 2000 Stratus brake rotor tolerance (searched!)
- Leaks around tranny/block area
- Leak under front of Stratus
- Engine rebuild, with pics
- Remote Key Programming
- Buying Engine Mounts for '95 stratus, 2.0L????
- Routine maintenance rip-off????
- 2000 Dodge Stratus 2.0 Engine Seized?? HELP!!
- Timing belt
- clutch Replacment
- duel edge map sensor enhancer
- 2001 Dodge Stratus 2.4 dohc timing help
- 2001 R/T Factory Alarm
- need some help on my engine swap
- motor mounts
- What kinda of trans fluid is compatable with mitsubishi
- Sometimes sarter cranks good, sometimes no juice
- 2000 Stratus 2.4 dohc idle issue
- 2003 stratus trans ??
- Anyone have a rear sway bar for a 00' 2.4 sedan?
- 2001 Stratus R/T - Fan blower won't work
- Stratus intermittent p0340
- Very high idle after cleaing EGR valve??
- 1998 Stratus Wont Start with Code P0340
- 04 status wirng?
- My car thread
- Starter Fuses Blowing
- Programming Key Fob
- Air Temperature Sensor
- Stratus R/T Coupe Tapping Noise
- 1995 stratus es update.....
- 01 Dodge Stratus Se Steering Wheel
- How do you reset computer on 01 Stratus
- Multi Port Injection
- chip tuning, remapping ???
- stratus r/t parts
- 99 stratus autostick shifting problem
- What Model Stratus do I have?
- 1995 stratus help
- 2000 Stratus tire problem
- '98 Stratus headlight issue?
- WTB a Stratus; ABS Option how many are out there?
- 2000 2.4l se with P0403 code
- Brake pedial travel
- Trip Odometer in 1996 Stratus
- How to change instrument cluster backlight color?
- difficulty level of chaning a wheel bearing?
- Opinion on buying used 2005 Stratus SXT 2.4
- 2005 Stratus SXT 2.4 DOHC problem...
- 04 Stratus P0303 Cylinder 3 Misfire Detected
- 2000 2.4 Stratus Fuel Pressure?
- Shift Solenoid
- 06 Stratus SXT windshield cracking
- 98 dodge stratus knocking noises
- 2005 Stratus SXT Coupe Bumper Covers
- 2000 2.4 flasher relay
- Knock sound when starting warm engine.
- High idle. iac or something else? 3.0 v6
- 1999 stratus Bucking (surging)
- 01 stratus r/t high rpm issues
- 99 dodge stratus es wont start
- Front wheel bearing Stratus 2006
- Need Mechanic in Cleveland OH
- 1996 dodge stratus ecm problem
- Cleveland, Strauts 2006, grinding noise
- Strauts 2006, grinding noise
- Turbo 2.4?
- I got pulled over today...
- 2001 Dodge Stratus Fog Light Lamps.
- Which engine do I have?
- Rear Creaking Noise
- Reverse lamps stay on
- 04 Serpentine Belt Tensioner
- stratus p0071 ambient air temp sensor range/performance
- Auto tranny popping into neutral
- Hard start / No acceleration / Fast shutdown
- Need help with Stratus' twin the "Breeze"
- Opinions on buying a used 03 stratus SE 2.4L coupe
- 2005 Stratus Coupe 5 speed Shifting rough
- Little tutorial to change Valve Gasket Stratus 97 2.4 DOHC
- Transmission problem
- 2001 Dodge Stratus sedan: where on earth is the rear defogger/defrost fuse?
- Replacing speakers, Need a little help
