- OBD II Readers
- Parking Brake Issue
- 3.5L Thermostat and PCV valve
- Can I take off governor or speed limiter on 06 magnum SE?
- Make my magnum rt sound better
- Wierd Rev
- 2007 Magnum Rear Wiper Arm
- Mygig Ren Need Help
- engine won't stay running
- 2008 Magnum SE Check Engine Light
- Malfunctioning back lights
- Spark plug change
- 2005-2008 Dodge Magnum Station Wagon Retrospective article
- Magnum Strut Replacement
- New tire change (from 18" to 22")
- Switch to full synthetic in 5.7 Hemi
- 2008 Dodge Magnum 3.5 oil consumption
- WiTech
- 05 Magnum hemi speed sensor
- Thermaquad Float Setting
- Turn Signals
- Ok, what's the deal?
- Starscan/Mobile... WPBeach Fl...
- Front speaker problem, '05 magnum se
- Plugs for a Hemi
- Rear and fron main seal leak
- dumb question regarding odometer
- newbie need help
- short runner valve
- Replacing brake rotors
- Tires, I need some advice
- air intake
- Speedometer failure
- exhaust?
- Black 2007 Magnum Anyone?
- 2006 Magnum low oil pressure
- Radio Harness to uConnect
- Stalling
- custom speaker box
- uconnect not working
- Time to replace spark plugs in hemi
- We are NOW a FOUR MAGNUM family!!!
- interested in 2005 magnum sxt..need opinions + winter driving
- Motor oil
- 2005 Mangum Speaker Problem
- 2005 Mangum Speakers
- Code P0406 egr position sensor high
- 2,7 not running right
- Stupid question
- CAI installed the other day...............
- Knocking sound
- fuel gauge ???
- Cooling fan comes on but will not shut off!
- strangs noise
- whirling noise from tranny?05 rt magnum
- 2005 magnum Rt rear windows issue
- Tail-lights: bulb replacement
- NEED HELP..2.7 or 3.5
- How often Magnum needs oil change?
- Wierd problem in reverse
- Where to buy Lug nuts - Calgary
- A Dodge Magnum by any other name...
- 2005 Magnum, lots of clunking noises from front end
- Headlight (not bulb) Removal
- Sat nav question
- Falken tires
- Wiper issue
- Squeaking Brakes
- transmission filter fluid change
- Drove with parking break on
- code 0520
- buying a magnum
- start-up
- Gas grade (87, 89 or 91) for Magnum
- installing electric seats in magnum -05 from chrysler 300c 2008. HEEEEELP!!!!
- New chin spoiler concept
- Sluggish acceleration
- Question on Factory Installed Remote Starter
- best repair manual
- MOOG tie rod ends
- steering column noise
- Time Problem
- Plugs, coils & shifter handle
- 2005 Magnum RT
- continental tire settlement
- Dodge Magnum = Ram Tough
- 2005 E-Brake issues
- Just bought an 08
- No FM reception
- uconnect does not talk any more
- Cruise control not working
- Differential seal leak
- Thinking of getting a Magnum....
- NEED Opinions
- OBD scanner won't read
- Metric in my cluster ?
- AWD vers 2WD Hemi..
- 05 magnum tail lights
- EGR evap sensor low voltage ?????????????
- Spark Plugs
- Heated Seats
- Car and truck of the year voting NOW
- headlight adjustment
- I have Aliens in my car
- Antenna location on 2005 Magnum
- Seat belt sign always on even when a have seatbelt on me
- Car not running good at all
- Odometer milage is it in the Engin computer
- Seat belt sign on always??
- FM radio died
- Error code p1400
- plug change
- Dodge Magnum radiator drain
- NAV Radio REC vs. REJ?
- Add on UConnect
- Key Fob Programming
- Wife's SXT starts; then just turns over??? Help!!!
- Part Numbers
- Custom CAI
- Turn Signal Prob Help Please!
- Burning premium gas in a Hemi
- are dodge magnums reliable?!
- Is 2006 2.7L Reliable!
- gear problem?
- Steering Issue
- Unexpected Chirp
- Rear Disc Brakes
- Lug Nuts
- whats a reasonable price?
- Check Engine Light
- The MagWag
- Aftermarket Uconnect wiring question
- Installing uconnect in 05 magnum
- ProCharger is giving away $5,000 CASH
- Used Oil not rated MS-6395...Now what?
- Hands free phone system
- Hot A/C at startup
- ESP BAS fault
- Brake Pad Rattle
- Change Plugs on SXT
- Input for Performance Modifications
- How to remove side door panel on 2005 RT?
- best tires
- Considering a Dodge Magnum... Thoughts?
- Just purchased a 2007 dodge magnum sxt...
- Need Drive Side Side Skirt (2005 Magnum)
- Sad Loss - 2005 Dodge Magnum RT
- Stereo Install
- 20" srt awd wheels on a magnum rwd sxt?
- 07 SXT Adding DBL DIN Question
- DF Video!
- Clunking Noise when turning....
- Replacement
- Airbag light
- Tie rods
- Well, I learned something NEW today!
- new member-lug nut torque?
- 22" rims w/tires for sale
- Noise from under car
- Is Paul Mitchell hiding in my R/T?
- 2005 R/T Magnum compression loss
- Looking at buying a Magnum
- Dummy O2 Sensors
- magnum for sale
- OK Got the R/T - Which Hitch for a 2500lb boat?
- 05 Dodge Magnum SE
- Cargo Net Anyone
- New Here - Tow Package install after purchase??
- New to Magnum! MPG Question!
- couple questions with regards to aftermarket products
- Question about the Magnum's snow driving
- did i do alright?
- roof box
- Aircon panel - not working
- 2005 DODGE MAGNUM SERVICE MANUAL
- navigation got usa - want europe
- Upgrading Navigation diss
- factory headunit swap
- HELP, radio static on hot days
- passanger side airbag light
- RT 4th gear weirdness
- CRANK NO START 1ST TIME START2ND TIME
- Panoramic Sunroof System
- Factory Warranty for 2005 magnums
- Dented 07 Magnum is this for real?
- 2006 Magnum SRT8 For Sale
- A/C Problems 5.7L
- Magnum tire size question
- 05 Magnum SXT
- Saw this Magnum in San Diego.
- Capital Forged Photoshoot: Magnum
- 2005 Magnum AWD
- Magnum R/T AWD ride height
- Brake Failure
- intake bolt torque?
- egr valve/sensor replacement?
- 2005 Magnum AWD v8 questions
- Repair Manual?
- Map Sensor
- Hmmm
- Trying to replace the console cupholder
- 05 magnum dash lights
- '05 RT rear windows issue...
- Check out a review of the Nitto Invo [video]
- anyone know of a freebie or online service manual for the magnums?
- MDS and the A/C system
- 2007 Dodge Magnum SXT Headlight Question
- Removing Resonators
- Cheap plasitc trim fading/turning white
- New 2 a Magnum
- Body Mods
- Tailgate Light Bar
- magnum/durango radio
- Vortech V3 Supercharger System - Installed!
- Brakes
- OEM (Alpine) NAV question
- Please Help with my 2005 Magnum SE
- gas grades
- Magnum SRT8 Exhaust Mod in Popular Mechanics
- SRT8 Rims and tires for RT
- Best Tire and Wheel Size calculator site.
- Shifting
- tire problem
- Lock horn
- Lug Nuts
- Noobie question
- Stock Rim Exchange Website
- Suspension
- Cargo Area - Max Length?
- TAKE OUT MDS
- Needed a new air filter
- 2005 Dodge Magnum looking for and question
- 05 RT Install Aftermarket Nav
- Gen X Underdrive Pulleys
- How do I get ESN of satellite radio?
- TIE ROD PROBLEMS
- Thinking about a Used Dodge Magnum
- Where to find quality custom auto mats
- can you spot todays small mod?
- Wheel Offset
- sort of a legal question
- Air conditioner just quit
- Towing Needs
- TSB on 06 Magnum
- 06 Magnum TSB
- 2006 Magnum TSB
- Mopar cat back exhaust kit
- Very stupid question....
- what kind of oil ? COLD WEATHER
- used car ?
