View Full Version : 1st Gen Ram Tech
- 1981 d150 questions
- Engine tick
- Oil Fill Cap For 82 Ram
- 89 problems with lights
- Gas Tank Interchange
- Just bought a '91 W150
- Carb and Intake Manifold replacements, stock 87 5.2L
- E 3 spark plugs 83 ram
- Auto to Manual Swap
- Couple questions for my 89 2500 ram van: window track and windshield wipers
- 83 dodge ram shift points
- High idle, hesitation, and stalling. only when its cold???
- what years for steering wheel interchange?
- gear ratio
- How to remove AC from 89 Dodge W 150 318 motor
- Our Heads
- High Idle
- Transmission won't go back in!!!!
- timing gear
- What are the correct fatory names of my '85 two tone exterior paint combo?
- Manual Transmission Swap
- Intake Manifold Suggestions
- Camshaft Question
- 360 acceleration problems
- Good Manifolds?
- 1988 318 dodge truck, timing
- timing issue need help
- smelling fuel
- Code 27
- 1988 Dodge W100 Idle Control Sensor - Idle Kicker
- Are my u joints bad? And could i fix them myself?
- New guy
- Brush guard's or bumpers
- Not getting fuel
- Shifting into OD at 50mph instead sooner...
- Identifying a Trans Sensor
- Check Engine Light
- Transmisson Sensor Plug 1993 d-250
- Smec ?
- New to the forum
- Lighted Ram's Head Hood Ornament
- 93' d-250 trans jumping from 2nd to od
- converting to 4wd
- No Fire, Please Help
- transmission woes
- Just joined
- Waterpump
- Conversion nightmare
- Truck dies at low rpms?
- 1992 w150
- Cam install
- 87 d150 heat riser
- intake painting
- Gen 1's with cap/topper-what did you put on the back???
- Problem With Hydraulic Slave Cylinder
- Question on Replacing Wing Vent Window Seals
- missing cig lighter
- Steering shaft
- exhaust manifold
- Valve Cover Replacement
- Any ideas on this connector
- dana 44 dust caps?
- Engines Options
- 76 dodge pickup passenger right tire stuck
- Torque Converter
- 1991 Dodge W150 318 TBI Help
- deciding on a cam
- On board air?
- Maybe don't need new bumper after all!!
- rust repair
- heat riser
- 91 d250 tail lights not working
- Pre fit spark plug wire stes...UH HUH....
- 78 D150 posi-track rear end? stock?
- Eliminate Rear Drum
- Door Window Parts
- 76 dodge truck 360 won't run
- 74 dodge adventurer sport master cylinder questions
- Irratic idle, where is my idle control valve?
- Truck Will Not Start
- 93 D150 transmission problem
- instrument cluster lights
- open loop runs like crap
- Need info about swapping a 77 D100 grille on to a 84 D150 Stepside
- Has SEAL, CRAZZYWOLFIE, ever helped you out???
- I'm looking for a replacement front & rear bumper?
- Fuel gauge erattic, 91 318 Power Ram 150
- 78 Dodge D150 318 dual ballast wiring diagram.
- 318 tbi to carb
- cam help
- Well, it IS brighter!
- How to convert a 318 to a 340?
- 86 I just picked up on CL
- So Frustrated!!!!
- 318 timing
- 727 Question
- Purge solenoid connections
- Transmissions
- Back Fire
- Buzzer under dash
- Help!! dash vacuum harness
- relay locations 1991 Dodge trucks
- Anyone got any tips for a 76 440?
- 1986 & 1993 ram parts
- question about body seams(diy painters)
- w150 questions
- parasitic draw on batter
- Towing limit for 1979 W150
- Where is the oil pressure sender?
- 86 D100 Issues Gauges & Bed Shaking
- 1990 ram 150 fuel issues
- steering
- 1989 D150 looking to lower it (HELP)
- What number rear axle (final drive) ratio would/could an '85 ram 150 have?
- Starting issues.
- My first post here! I'm buying an '85 318/torqueflite ram 1500...
- 83 d150 318 4BBL auto
- Brake controller wiring.
- Gear ratio help
- need to know lift questions.
- 92 dodge level kit
- New parking lenses/ plastic headlight bezel
- Rough idle problems
- 89 dodge TBI oil pressure 318
- Steering Wheel for Steering Feel?
- Got a restoration to do 81' Ram150 - Looking for input
- 92' W150 hard start - new fuel module
- First,no fire.. Now, timing issue? 1978-318v8.
- 88 ram d250 electrical problems
- Can't find a proper wiring diagram
- fuel rail compatability
- 83 ram rv cam, fuel mileage
- I must be a DA!
- 93 scrap
- Buying an 89 Power Ram 360 4x4 in morning, what to check?
- 1st gen shaker intake?
- Braking system frustrations
- 89 ram TBI 318 stalls
- Rustoleum Paint Job Finished
- 92 Ram Running Very Rich
- Windshield Wiper Problem!
- Clutch linkage
- Bad Injection Pump? Help
- Speedo doesn't work
- 85 engine swap?
- Truck Bed
- power chip for a 91?
- 4x4 Dodges sit low on the drivers side?
- Hello everyone, new Dodge Ram owner here, it's a 91
- Rear Disc Brake Swap
- getting rid of rear stock block
- 318 help
- Big Block swap
- 87' Ram Van Squeek n Hiss problem
- Hurst
- Headlight Troubles!
- Front end really bouncing around...especially when applying brakes
- 2000 ram1500 4x4 clunks when putting in gear
- EFI in early 1st gen
- MOOG 7226 or 7226s
- 1987 d100 turn signal wiring diagram NEEDED
- Need a detail picture 1982 318 engine
- 1981 W250 Wiring Diagram
- Plenum
- 239 Magnum Headers
- Check Engine Light ( I screwed up )
- Smoke!!!
- Belt line window seals
- My first truck. Need help with parts
- power ram mods?
- Help 1990 Dodge Fuel Module
- Knuckle question
- Questions regarding random engine wiring (PICTURES!)
- 93 dodge 350 transmission slips around corners only in OD
- Locker
- Trans Cooler and Shift Kit
- Transmission Options
- '85 Ram Project
- Whats my options?
- Boxing Frame Rails
- KEGGER MOD question
- Restoration of the Ram Fender Emblems
- 88-93 engine swap
- Booster or Master Cylinder or Both?
- NV3500 vs NV4500 5 speeds - Help!
- Slow 1st to 2nd shift
- Rear end 84 dodge d150
- 84- LA 318 performance
- Rear Brake Lock-up
- 904 Tranny Problems! Help
- vacuum leak at pre-heater diaphram line
- Help
- Still need HELP
- Please HELP
- Fuel tank ?'s
- What size is the steering box input?
- Slant 6 to 360
- Magnum motor in a 1st Gen ram
- Issues getting dash back in
- Need Guidance on Removing Wiper Arm
- '78 Power Wagon and '91 Ram
- 89 360 tbi to carb need some help
- fuseable link burnt short in ignition?
- my 1973 build
- 87 Ram auto Transmission problem
- "Lincoln" locker?
- Fuel Pump Differences
- Bogging down
- potent fuel smell
- NEED HELP! 1992 Dodge w250 leaf spring
- 1989 ram 50
- 1989 Ram 50
- where to buy chrome fender trim?
- What ball joints
- does it have lockup
- bench seat
- Adding AC
- manual Transmission swaps
- '85 Cranks but won't start
- Power window problem 1989 d150
- 4 speed from a 86 d150 slant 6 in a d250 318?
- Lug Pattern Swap
- Lowering/drop shackles. What fits?
- Grille Guard write-up
- Dash Swap?
- No Headlights
- 1991 318 hp rating?
- Major changes coming soon, engine, gears, brakes etc
- 1991 Won't stay started...
- 1981 D150 Coil spark issue
- cant find them
- Steering Seal ID?
- Cracked Intake Manifold
- 4WD vacuum questions...
- header install
- Anyone rebuilt their transmission themselves?
- need help with my 88 chrysler 360 t/b engine
- What's it Worth? 1986 Dodge Power RAM
- post-header install engine issues. help?
- Rear bumper options?
- 1990 Ram ignition Cly Removal
- Replacing front brake discs, 1989 W250 diesel
- 44-8fd front axle
- best shocks
- Dodge_D150
- '92 5.2 in Jeep Wrangler...cruise control question
- Crank sensor replacement writeup?
- power steering pump leaking!!
- check engine light flashes
- Pitman Arm... Help!
