View Full Version : 1st Gen Ram Tech
- Could use some help
- Changing interior color
- Exhaust
- 1990 D150 w/318 bucks when lifting off the gas
- 55 ford twelve valve cummins
- Running warm
- Personal Boost!
- ac recharge
- Vibration
- Best Sounding Exhaust
- 93 W150 help!
- No Gas!
- Best place for hard to find parts?
- Thumbs Up!
- 87 w150 a/c
- 1985 D50 Running Rough
- LOST BODY PART! Naked Bed!
- 1st gen Ram stuck in park
- 81-93 tail lights
- Why no lights?
- Rear End Q's
- idle
- 93 Tranny/Overdrive
- 1989 360 Swap *Question*
- dana 44 vacum/actuater not locking in. need help please
- Lift
- Will my 4 speed bolt up to a 318?
- i have a 1976 powerwagon . i need help!
- I am getting dumber the older i get, help?
- were is the diagnostic plug in on a 1993
- fuel pump relay
- truck bed
- In need of some tail-light lenses.
- Part Jumped out of my hand, Please Help?
- NP241 Leaking Fluid
- wtb 8ft bed
- W200 rear brake nightmare
- Help - 360 missing
- '90 D150 - Couple questions
- i killed the leaning tower of power
- 1984 W350 fuel pump
- 90 will not turn over
- high beam headlights
- Woof woof sound when accelerating
- '90 W150 New Floor - How to Seal?
- Need a wiring diagram
- Rebuild Book
- trans help
- 88 D100: Sputter, Misfiring
- 1989 Dodge Ram Truck D Series 318 engine
- Sure this has been asked hundreds of times
- ***Rules and Tips for the Calendar contest***
- Tubular control arms! Come get em!
- 1989 W150 no start
- Air Idle Speed Motor
- I am pissed.........help?
- New here!
- 89 w150 4x4
- 87 w250 stumbles and stalls
- Violent shimmy/vibration in steering wheel
- airbagit.com drop spindles for 1st gen
- brake booster problem
- 89 D100 318 Ram running real rough - need some expert advice
- Transmission Problems!!
- Exhaust ?
- Remowing the oil pan
- HVAC stuck on Defrost 1985 Ram
- problems with 79 dodge ramcharger
- '87 D-150 Weird Coolant Issue
- Is this some kind of resistor?
- transmission dipstick
- air diverter valve?
- Alternator Rebuild
- Need 440 oil pan for 2wd!!
- Power window problems.
- 1989 Dodge RAM D100 V6 sitting in driveway for 7 years. Advice?
- 360
- 88 -318 TBI rough idle
- Need a new transmission for my truck
- 85 d150 headlight problems
- What the heck IS this thing??
- 1985 D100 Not starting and Radio Out
- My 91 D150, is givin me a-fit.
- Mystery dohickey
- 1992 crew cab dodge cab front clip for sale
- 1st Gen Problems 1974 dodge
- 87 D-350 4-Speed pops out of gear on decel.
- 2nd gen seats
- Please help...urgent
- 92 5.9 TBI fuel issues
- Dodge D-150 225ci project sleeper truck
- 1992 MPFI 318 needs more power
- Center caps
- Front Dana 44 Question
- Looking For a Slant Six Expert!!
- 01 5.2l starting issues
- Lowering kits and who carries them?!
- water pump
- tranny leak
- Parts for the old truck
- 1992 mpfi 318 needs a little more power
- Wheel fitment-chevy to dodge
- Turn signal/brake light wiring from scratch
- another 4x4 problem
- trying to locate a gas tank
- need help decoding a VIN
- Adjusting doors
- 1980 Ram electrical issue
- 1970 D100 clutch question.
- first gen specs.
- tow package
- Replacing the heater
- 91 ram 150 4x4 problem
- new to dodges 318/360
- May buy 88 Dodge 3/4 Ton. Options to fix the fuel injection?
- what size tire you running....
- '91 V6 3.9 fuel issue??
- 91 dodge charging system
- Carb help!
- How many of us have front sway bars?
- Which automatic transmission do I have? 88 Dodge Ram D100
- W250 stock height?
- 85 Ram won't start when hot
- Rough start after a long sit
- accessory brackets for serpentine belt
- 2nd gen rims on 1st gen truck
- 1980 dodge
- Dodge 250 smokes a little
- Gas Fuel Tank straps......... where to get them???
- Speedometer
- 93 d-150 318
- rear bumper swap?
- Running hot
- 89 w-250 questions??
- Help! Reassembly after water pump replacement
- Heard a "POP" from the front drive shaft
- does ECM store total mileage?
- 1990 Power Door Lock Relay Location
- 91 D350 master cylinder
- newbe needs help
- 1990 power ram 150
- 1984 Dodge D350 crew cab sb info ??
- Operation Power Ram Restore ( With pictures)
- 1985 dodge ram - electric window convert to manual windows - help!
- Need rear axle for 88 dodge ram d100
- Alternator intermittent charging
- The Seatbelt Debate
- Newer Ram Wheels
- transmission swap
- small block transimision big block engine
- Weak spark and no fire
- 318
- Replacing rear axle oil seals, 88 Ram
- need dash cluster wiring diagram!
- Exhaust manifold Butterfly
- Outer Axle Shafts
- 91 ram fuel problems
- New
- Transfer Case Gear Ratio
- any camo 1st gens out there?
- 93 ram turn signals stopped working
- long vs. shorty headers
- Intermittent Starting Problem!
- 1990 Dodge Ram W150 4x4
- 87 ram 50 dash wiring harness
- Edelbrock 440 "Power Package"
- timing advance
- What will fit under the truck?
- Finally got the fuel injected 5.7L to work
- noise ??
- Possible to add A/C to a 79 D100?
- automatic to 4-speed swap?
- 1993 dodge 360 parts
- Help....Question re intake manifold on 318
- original tire size for 87 dodge d150??
- replace differential fluid, 88 dodge ram d100
- Need a new window regulator 93 dodge ram
- u joint problem?? tranny question. 88 dodge ram
- Part websites
- desert oil
- 4x4 engaged light always on.
- tire size vs lift size
- Check out the general discussion subsection!
- What on earth is this thing?
- Washed engine, now weak spark! Help!
- '85 D150 - Been sitting, Question...
- trans fluid leak
- '77 D150 coupla questions
- 87 d100 3.7 auto lock up in forward can only go backwards???
- 92 ram won't start
- Wanted Rear doors off a '74 Crew Cab...one??...any
- NV3500 in an 88?
- 1988 w150 fuel sending unit help!!
- computer ??
- trans mount
- Carb Setup
- Found these cool seats at the boneyard
- Any Edelbrock carb guys in here?
- window handle kit?
- 1989 d100 3.9
- 1992 Ram radio noise
- 1st Gen For Sale
- 9 1/4 vs 9 3/4
- why wont it spark???
- need cab
- HELP! Truck dies at highway speeds!!
- Timing 1990 Ram with 318
- old ram vs new ram need help.
- leaking antifreeze
- radiator
- Best headers for 440 swap?
- transmission fluid
- Power Window Troubles
- 91 Dodge ram fuel problems
- 1989 D250 steering knuckle
- Hello everyone
- July 3rd Gen Ram TOTM - Go Vote
- advice needed on tackling body work
- 360 Heads on a 318 block????
- Paint Suggestions
- Locked parking breaks.
- no brake,turn, or hazard lights
- getting truck wednesday need help
- truck trailer wiring
- Diagnose this.
- Wheel question
- Where to get a New bumper and roll pan
- 84 prospector
- misfire at low speeds....
- runs cooler
- carb spitting gas
- can't get rid of code 22
- 89 dodge snow commandor
- Location Barometric Solenoid
- 88 D100 Tailgate Cap
- 1990 Dodge Ram 318 cold misfire
- timing chain/gears
- Trouble Finding Battery Tray (1979 D100)
- 88 D100 runs rough, "bucking"
- new here, got a 1st gen!
- swap from tbi to carb
- Please help! New dodge its running rough i dunno whats wrong!!!! Please
- Need 92 Diesel Trans throttle valve cable
- 1984 Dodge Sno-Commander w/ Plow
- RWAL/Speed Sensor testing
- cat...converter
- Window regulator help
- Oil Filter
- all aluminium radiator
- Home made Hydrogen Cell.
