View Full Version : 1st Gen Ram Tech
- Emissions testing in VA!
- 1990 W250 no fuel
- please timing help
- Honour Build
- Do they make a performance 318 TBI intake manifold?
- axle shafts
- recharge ac
- timing issue
- Light switch (knob)
- Transfer Case
- location of the low presure switch
- cooling system
- Timing chain
- fuel line question
- questions about the roof skin
- 318 Engine Swap
- ANOTHER big block swap thread! haha
- check it out!
- Tranny Swap - whats compatible?
- 1973 Dodge 3/4 ton as a donor?
- coolant overflow tank bubbling and leaking?????
- 2nd Gen TOTM
- Where to buy 16.5" tires??
- Adjusting a Carter AFB Carburetor
- 93 W250 pulling to the right
- 1984 Dodge Ram stalling
- 93 Trans. Question
- Truck stalled, wont start now
- 1985 D-150 Royal SE Prospector FS
- This parts site is awesome.
- 318 engine swap questions
- LS1 Dodge Ram
- Rear Bumper for 79 Utiline
- Rear swaybar for 86 W150
- What is lectric Feedback Valve, Do I need it?
- Lowering a 1977 D150 Adventurer
- need help with my 93 d250
- Sup dudes, buyin a 1st gen. PW
- Wiring diagram viper engine W250 1989
- White smoke
- 360 engine weight
- Distributor Wobble and Rubbing
- 88 dodge ram 318 w/ tbi running rich
- Brake Booster Question
- 46rh starting in 2nd gear
- Engine rebuild manual
- 1981 Dodge transmission swap
- switch on fuse panel
- B/A old school dodge!
- 3.9 engine swap
- a/c problem 88 d100 5.2
- Leaky tank help?
- Data link connector
- Ignition Upgrade for 318 Carbed
- running rough
- Looking to buy a 1973-1975 D-100 4x4
- what model carb 88 dodge ram d100 w/ 318
- Rear End Decoders???
- vacuum problem
- Dodge d150 Gas Tank question
- wheel help
- electronic vs mechanical speedo
- 91 ram diesel smokes
- '90 single ax to duallies
- sockets for rear lights
- timing advance
- Body Parts Interchange
- Stock wheels 88 LE150
- 1993 Dodge Turbodiesel 4x4 Brake Problem
- need rear view mirror for 88 dodge ram d100
- disconnected aftermarket tach, now engine will not start
- Air cleaner replacement \6 225ci
- radiator??
- how to remove o2 sensor 88 dodge ram d100?
- oil pressure question: 88 dodge ram w/ 318
- Throttle Position Sensor overide
- 1993 dodge 3/4 ton
- Accelerator
- Wheel and Tire recommendation needed. Thanks!
- '82 D-150 Custom
- my trucks build sheet
- 1991 Dodge W150 318
- Macho package power wagon graphics
- not too happy with my truck today
- 1979 Dodge Power Wagon transmission
- Distributor Problems
- What throttle body did our FI trucks come with?
- Specs...
- '79 W150 Idles great but quickly dies under Load
- newer V8
- 2nd gen TOTM, come vote
- 2nd gen poll, come vote
- drip rail (gutter) rusted out
- 318 power?
- Truck not running
- Found some sweet new 8lug rims!!
- thinking about switching from FI to carb
- blue smoke on start up
- 318 engine noise
- 1989 dodge questions
- Gulped some debris . . . engine missing
- how to get diagnostic codes 88 dodge ram 318
- An invite to 3rd Gen. TOTM!!
- LA Parts to Mag Block? Magnum Heads to La Block?
- Need a transmission pro please
- Is there supposed to be a gasket on the back of the hood?
- How to get that tinny exhaust note?
- MAY 30th Lake/BBQ/Potluck Meet, Grapevine Texas
- Hello! Carb options
- 3rd gen ram totm! Yall come vote
- how long is oil dipstick tube on a 318??
- 2x4 into the grille of my truck
- oil [dip stick?] question - 88 dodge ram d100 318 v8
- 1991 Ram 318. Flooding?
- 91 w150 tranny
- Ballast resistor location and grille assembly
- odometer issues
- 85 d350 daully will not start
- 88 Dodge Ram Charger 318 5.2 v-8 oil pan
- tune up question: 1988 Dodge Ram D100
- Steering Wheel Horn Pad
- d100 sweptline
- Tire Pressures
- Exterior Door Trim Clips
- Lifted 1st Gens... lets see 'em!
- 6 inch lift
- '83 Ram D350 will start but won't stay running???
- timing trouble
- hood latch interchangeability
- stupid question
- Any way to tighten side mirrors?
- Ignition Switch Issues
- lean code
- Jet performanc module?
- Cheap and simple
- Way to measure heads to see how much they were milled?
- 79 dodge engine replacement
- help with 89 ram 100
- 1990 D150 318c.i. DIY Gt500 SHELBY COBRA Supercharger setup and head swap/upgrade
- problem with 1990 ram d250
- Window Regulator Issues
- Transmission Shifting Late/Not Shiffing Up
- cracked block
- Drip rail question
- 6 inch lift
- Take Out The Bench, Put In The Buckets
- Window and Door issues
- Help!!!!!!!!
- Tranny Swap?
- slant 6 emission and cat removal
- Prospector Package
- rear end oil?
- Talked to a local at a car show
- Power Programmers/Control Module,are they any good?
- 360/ tranny rear end combo?
- Poly gas tank..old gas, how to clean?
- '88 D150 Rebuild
- New tires 1500
- HIGH Idle
- will a 63 383 bolt up to a 1981 A727 Trans?
- 1st genners come check this out!
- thought i might ask y'all
- 1989 dodge ram no spark
- Brakes
- Timing and Idle issue
- Flywheel and pressure plate???
- big block swap questions
- 76 power wagon does it count as a 1st gen Ram?
- Im stuck. Im also sad. Very sad.
- 86 dodge d250 carb
- tranny and transfer case ?'s
- 440 dodge ram
- transmission repair
- What's it weigh???
- Starter bolt size
- seafoam
- Exhaust stacks question
- Engine swap question
- Door Sags
- four barrel carb on six
- Steering problem
- I need a bit of help
- clanking noise
- 360 and 318 differences.
- popping and surging
- Brake fluid for 1st gen Ram
- 33" tire question
- Transmission cooler
- Exhaust issue
- 1989 W150 4x4 - A500 or A727? And a few other Questions
- in need....
- Post pics of your '88 or older Dodge Ram
- I need parts for a '90 D150
- W150 1985 Parts?????????????
- re-sale value help! Please?
- 04 ram with emission code
- 1987 d150 better gas mileage??
- 90 d250 suspension issue
- Replacement fuel injectors leaking fuel, is there a sealant?
- 1993 W250 5.9 Magnum Needs Engine
- Early 90's Ram question
- maybe carb problem
- Back Rack
- 1979 D100 stepside - things to look for?
- Installed choke thermostat..it runs rich and dies
- Name this clip
- Interchangable LA SB parts
- Truck dies occasionally
- oil pan gasket
- Replacing my DODGE nameplate
- 1987 D150 intermittent Misfire and cutting out
- how much is it worth?
- Project: Black Rambo
- Help with my 1990 Ram 150
- 1990 Ram 360 auto
- d150 318,some problems
- Lifts for a D150???
- Can't Find Paint Code HELP!
- When is it time to replace coils?
- Rebuilding Grandpa's truck --part 3
- After market intake
- engine computer code
- What 5 speed is on the 1992 D250 diesel?
- Body lift
- new (to me) truck backfires
- update 90 W150
- Source of Driveline Vibrations?
- Truck dies going down the road
- how to identify a axle
- 5x5.5 vs 5x139
- 383 or 440 in a 1st gen?
- '87 150 Tailgate Troubles...
- Screwed??
- Interior question
- hot starting problem
- 1986 w250 bumper brackets
- Newbie question:Valve cover gaskets
- headers on 1989 d150
- 360 heads on 318 problem
- Cab noise repair.
- need help lowering the front
- fluid change?
- I need a Coolant hose bracket support
- trailer wiring
- 86 W350 Doesn't start/starts then stalls/runs fine???
- 91 dodge wont start
- 91 dodge ram 150 wont start
- Tranny Cooling Line Repair Question (from a new guy)
- Auto to Manual Conversion Goodies
- Quick help please???
