View Full Version : 1st Gen Ram Tech
- EBRake Non Op
- Emergency brake indicator light
- 318 Magnum Intake Manifold
- Finished re-wiring engine bay
- File request- 1983 Dodge D150 - ANY MANUALS or Spec diagrams.
- Transmission Identification
- 1st Gen Dodge Ram Wiring Issues
- Truck not level on chassis
- Manually downshifting an automatic transmission...
- Update
- Help
- D series Axle question
- Roll bar hardware question
- Door handle trouble
- Macho Power Wagon decal
- Steering column
- 1990 W150 Shuts Down While Driving
- Yoke size?
- 1986 360 Power Upgrades
- Changing gas tank grommet
- 4WD question
- A non-shocking issue.
- 1990 Ramcharger Magnum swap
- Anyone using Holley Brawler 4 Barrel on 318?
- 1990 Power Ram Fuel Pump Assembly Replacement
- 84 w250 318 no spark
- Np435 mystery
- How to drop gas tank?
- 1974 Dodge FSM?
- Engine oil dipstick question.
- 1985 Dodge Ram manual swap
- Computer relearn process?
- 84 250 transfer case rear output yoke
- What’s this line?
- 1987 Dodge Dakota carburetor engine won’t stay running
- 1986 W250 Diesel Swap Project
- Rear band won't torque
- Axle length question
- 1991 D150 Fog Light Switch Location
- 1986 dodge d250 no headlights
- No Fire To Coil, Turning Over Great 1993 Dodge D150
- Tire size question
- Driving truck without reverse piston
- 1992 d150 idle adjustment
- No Fuel Getting to Carb
- On the road
- No spark
- Transmission leak - what’s this?
- Rear Axle identification
- Died, No Start
- Steering wheel question
- Adjusting the Gear Shifter 85 D150
- Dash pad removal
- 1992 Dodge Ram 150 V6 Fuel Filter location
- Water pump/440 question
- '78 Grille Touch-Up
- 22 x 12 -44, 305/40 or 33 x 12.5 fitment
- 4x4 Indicator Light Meltdown -help!
- 1980 dodge power wagon
- Electronic Fuel Injected Carb?
- Rims Stuck on Truck by Paint
- 4 wheel drive wont engage
- Hard start problem
- Is Exterior Trim Stainless or anodized Aluminum?
- Axle Help
- Cab questions
- Radiator question
- What battery
- Acceleration dead spot
- 1990 Dodge 3/4 T manual transmission swap
- For Sale: '86 Power Ram W250 5.9 Auto
- Add power door locks
- Bed Liner for a 1st Gen long bed
- Alternator Pulley not Aligned! Help
- 1988 W100 Spraying Fuel
- Wiring issue, 1986 D250
- Need tranny numbers decoded
- Cab swap info
- Info on how to remove engine & transmission 1988 D100
- Transmission filler tube and dipstick
- Convert to power windows
- 1989 w-150
- 89 ram d100 trans od issues
- FACTORY TIRE SIZE ??....1989 Dodge W100 Power Ram
- steering linkage help, stock 1985 4x4 w250
- Fuel pump eccentric
- 1986 D250 5.2l fluids
- 1987 Dodge Ram D150 Fuel Tank
- Spare tire bracket and hardware
- Rear view mirror
- Newbie! 1978 W150 Adventurer
- Basic bolt on 318LA - cam suggestion, intake and carb?
- 5.9 12 Valve Swap Questions
- Under Dash Piece
- Cargo Light
- Bluemule
- 78 seat belt mounting
- Dodge 1984 w350 sno commander
- Water temp gauge issues
- 1st gen/2nd gen hubs interchangeable? (2wd)
- Dodge lil' red truck
- 99 ford explorer 5.0 v8 into a v6 1st gen dodge ram
- 1987 dodge d100 that jumped time
- Misfires at startup
- Is it possible for me to fit a 440 big block into my 1977 power wagon?
- 4,000lb axle rotor hub assembly
- Fan shroud for a '78 W150?
- Identify transmission type
- '91 Camber Bolt Length
- differential pinion oil seal replace
- Ignition
- Front Brake Upgrade?
- Engine Coolant Sender Range
- 81-93 Hood on a '78
- Interchangeable Suspension Components 88 D100
- 318 swap help
- Hood and fender badges removal and replace
- Voltage issue (92 12 valve)
- Vibration Troubleshooting
- Fuel filter lines
- Anyone add Mech Oil Pressure Gauge with T?
- 88 with 93 30 gal sputter problems
- 1991 Power Ram 360TBI. RPM Questions
- Problem
- Thermoquad Choke Operation 1983 W250?
- Best Carb Replacement for a 1983 318 Engine
- I little something extra
- coolant temp gauge odd behavior
- main bearing replace
- Distributor condenser
- 1978 D150 Stalling issue.
- Stock 2wd front spring rate?
- Searching- Wheels that fit - from other vehicles
- Gas/Exhaust Smell in cabin
- RPM confusion
- 1st Gen Ram Tow Truck Value?
- 1992 Lug nuts/rims
- Torque converter lock up
- Complete rebuild
- speedometer inaccurate
- 1992 Dodge d150 3.9 need help please
- 89 D100 will not start
- Tailgate Handle Clips(?)
- Dome light Issue
- What model transmission
- 93 1st Gen Diesel Throttle Racing
- 1st gen rear pinion yoke
- 89 D100 steering Column question
- 79/80 Dual Headlight swap to an 88
- Power brake upgrade 1982 d150
- 93 Engine Swap
- 92/93 Fuel Pump 5 Pin connector
- '86 W250 - Ignition/Starter Motor Issue?
- W250 - Engine Diagram
- W250 - Master Cylinder Leak
- 1985 Dodge d150, 1975 engine
- 86 Ram Electrical Issue
- Hello everyone
- Ac - '86 w250
- Hvac - '86 w250
- Washer pump/reservoir
- 1985 D150 225 slant 6 / 360 V8 swap
- 1990 d350
- Need help with ignition issue
- Banks power
- 1988 Dodge D150 hesitation issue
- 1985 w100 custom
- Positive Battery Cable
- Does bleeding the brake lines also bleed the master cycl & combo valve?
- Combination valve brake warning light didn't work
- Alternator Pulley Alignment
- Good old truck
- Efi-hd vs carb.
- Information
- Will a NV4500 bolt up to a 2wd 318?
- Engine Swap 318LA Rebuild questions.
- Idle air control valve location 1992 1 ton truck?
- 85 D350 Gas Line @ rear axle
- 1985 dodge ram d100,slant 6,front exhaust pipe
- In search of a 87 passenger door
- Using a 93 Tank on 88.
- 17" Wheels
- Axle help please
- Does the Volt Regulator Ground on Firewall on 1983
- 16.5 Wheel Conversion to 16
- PA for me to supplant my leaf springs for towing capacity
- 16" 4x4 Rims to Replace 16.5's?
- 4th Gen Wheels on D150
- 1997 Dodge ram
- 1983 W250 Fuse Blowing Fun/No charge
- 87 Control Arm Snapped
- Brake pedal with long travel and slow return
- Alternator or battery?
- 1983 W250 -Ammeter or Voltmeter
- 85 Dodge D150 no headlights
- Dies when coming to a stop and lopes like it has a hog ass can
- cabin pressure relief vent
- Intermittent crank no start
- Air con condenser 1986 D100
- Motor swap/ transmission compatibility
- Light Bar Mount
- Return line to Gas Tank/other?
- 1985 D-150 v6 conversion
- First Gen Radio? Need one please
- Mystery wiring from factory!
- Fender Flares? (Non OEM)
- Lost in brakes
- Tps, iac and throttle body temp sensor codes, engine surges
- HELP? 1st gen diesel fuel sending unit
- 83 D150 help with Throttle Linkage
- wiring diagram 1989 dodge 5.9 cumming
- Oil pressure gauge not working
- 93 30 Gal Tank on 88
- Speedometer
- prindle needle
- Electric Choke Voltage
- prnd21 needle
- Ticking, vibrations and bog... oh my!
- 1988 d100 318 intake air temp senser
- Intake Manifold ID
- 89 w150 driver side drop axle
- 88 D100 Not starting please help
- Need help Fuel Tank
- 82-90 Dodge W150 Turn Signal Switch - Hazard tilt wheel
- 92 w150 nv4500 swap
- A/C vacuum diagram
- vacuum line help
- 88 3.9l throwing Power Steering Belt
- 84 w250 318 A727 transmission removal
- 1992 318 & 2000 360 magnum
- 88 D100 AC/Heat Switch Wiring
- LA 360 Slap Shift ?
- Bed Patch
- Putting later model 5.9 in my 84 Ram 150 SE
- 4bbl Intake manifold
- Kdp
- Turn signal gremlin?
- Headlight switch 81 Dodge d250
- Need help
- Manual window swap
- Ram Tire Question
- 3 speed manual transmission????
- Automatic transmission
- Quick thought on EGT and Manifold temps...
- Anyone Know Any Good Pulley Sets?
- 1982 dodge d150 stalls when slowing to a stop and in reverse
- Smog Pump Hook Up
- Steering Gear Mounting Bolts
- Completed several small projects today
