View Full Version : 1st Gen Ram Tech
- 84 4x4 ram bolt pattern
- 93 318 charging issue
- fuel filter problem
- WTB OEM Steel Whls
- Can I use the Ramcharger gas tank?
- My body swap project!
- Fuel Tank Help
- Weird light problem.
- fuel filter
- Multiple Engine Personalities.....?
- What other projects are you working on?
- Pic update on my w200
- 87 Ram 318 Engine Installation Help
- please help!!!
- Was the big block ever offered with overdrive?
- HVAC Control vacuum line diagram?
- looking for over drive tranny
- pvc hose,carb question
- 1990 w250 trans rebuild?
- 77 d150
- Help! Replaced all four brakes and still no pedal
- painting
- need help with my '93
- Towing with my W150
- My 1987 Dodge ram(lot of pics)
- 84 D250, 440, need headers!
- thermostat housing and hose question
- Evil Air Conditioning
- adding transmission fluid
- Tranny Conversion - 3 speed to 4 speed
- 16's to 15's
- 1990 dodge w250 hub problem
- '75 W200 no start
- 1991 Turbo Diesel Tranny Band Adjustment
- GM Shackles/Dodge Trucks
- Installing round air cleaner... where to put vacuum line?
- 81 /6 D150 suggestions
- 318 oil pan question
- Question about back pressure
- w150 lift?
- M.A.C Drop Kit
- 85 d2500, couple questions
- speed sensor/ wiring
- Leaf spring issues!
- Steering Coupler
- 60 Front Compatibility
- 89 D150 Floorboard Replacement.
- Weekend Paint Project
- Electric problem: need wiring diagram
- carb and mpg questions????
- Buying 91 d250
- Anyone interested?
- 318 to Hemi or not
- Tint Issues
- hey yall
- Drop Shackles
- 85 ram - rewiring project, need some advice
- Rear shackles gone bad :(
- SCORE!! Picked up a D250 :D Now to swap bodies...
- Fuel tanks
- Some wiring issues
- D100 Roll Pan
- What Did You Do To Your RAM Today?
- '88 D100 Trans Problem
- '88 D100 Coil Springs/Struts
- Wiring Diagram 87 W150
- 82' D150 lift
- Newbie with an '88 D100
- D100... fit 31x10.5?
- Dash lights quit working?? Help!
- return line leak
- 86 ram /6 to 360 what do i need?
- PCM failure?
- Stroked 318?
- Header "tick" please help!
- Brake Lights 1892 W250
- 80's grille interchange.
- Normal for a wheel bearing to just fail randomly?
- Aftermarket Tach on '87
- Tourque Converter Sol / Front Hub Disconnect
- 5.9 Magnum swap?
- After market gauges
- 88 2wd D100 tranny... what other years/models fit?
- oil pressure question
- Check Engine Light - Making it go away...
- 83 w-150, durango 5.2 swap?
- Check this out!!!
- dim lights-bright lights
- So I have a D100 and a 440 on a stand...
- Best offset/backspacing for 15x10 & 15x8 on D100?
- D100 or D150?
- 360 cam?
- Looking to build a shortblock.
- limp home mode
- lic plate and back up lights,inspection in NC
- Looking for info.....
- Fuel sending unit/float replacement.
- 92\94 2wd ram transmission
- Door Panel Question
- 90 Ram 150...tcase lube and capacity
- Quick question about full time 4wd
- Swapping a '88 318 TBI into a '93 with a 3.9L
- how much atf?
- automatic to manual tranny swap
- (pics) Rusted out floor boards/rockers, what now?
- stock axel / specs
- Need some help.....
- Temp probe location.
- Steering drift?
- '90 D150 318 Power Steering Failure
- Body / Other accessories
- Speedometer Head Replacement
- Questions on my new truck!! Help please.
- Rear Info?
- 81 ram 318 no spark
- Hood Ornament - STOLEN.... AGAIN!
- she hasnt been started in 2 years
- clutch
- air heater on the manifold
- Topper size...
- Power steering issues!
- What camshaft to use?
- 35" rims and tires for sale
- Transmission cable help (pic request)
- d100 complete rebuild
- Plugs and wires?
- WTB A good 318 and Transmission
- Diagnosis help - need quick
- finding out gear ratios
- power steering gearbox issues
- trans and header question
- Repair main seal???
- rear end #"s
- Blower motor and p/window wiring
- Bucking Ram!
- D150 trans question
- Dakota of the Month!! VOTE!!
- Column to floor shift?
- Seat question
- Another busted hood cable!
- Y Pipe help
- 78 200 pickup
- Forum Feedback
- 318 dipstick tube
- Huge amount of end play on the crank
- door drop
- Good place for 84 parts?
- Tilt fix.
- YOU v-8 guys have it so good.
- Header Question??
- LA to magnum exhaust manifolds?
- 1993 dodge runnig bad
- 1993 dodge w350 pcm
- Help crankshaft position sensor change?
- Ideas....
- Great site I just found.
- not so fast, anymore.
- Workin on a truck, workin on a truck...
- Lower Class Club
- timing issue
- Blew a transmission line
- retail value pf dodge truck
- Where is everone from?
- Need a new motor
- can i do this
- Brake Switch help
- rear tail light wire nightmare
- Starting problem 89 D150
- Need a new air intake hose
- engine tranny swap
- Need a sway bar.
- A/C pulling down engine
- 1981 Ram Lowered & Tubbed
- Dakota of the Month Poll
- 91 dodge d150 coolant leak
- 1991 dodge ram 4 vacum hoses?
- Floppy Tilt on my 83
- ? about gauges
- 78' D100 318 Fuel Delivery issue Pls HELP!!
- 318 timing?
- It's alive again....
- Hi Everyone, new guy
- Carb issues
- Intermittant wiper relay
- 1990 Ram W150 ECM issues? HELP!?
- How to remove ignition switch
- whiper issue
- Brakes
- Replacement ignition keys?
- 5.9 magnum in an 86 w150?
- Am i getting shafted from mechanic?
- quick question
- Good Tranny rebuild Manual?
- Need part: Alternator wiring harness
- Need more life out of my rig
- 1st Gen Custom parts and wheels, etc
- Goodbye everyone!
- swaping a 318 tbi to a 360 tbi
- 85 D150 Charging problem.
- Stupid transmission problems
- Cleaner way to service a tranny?
- 1993 Dodge 150 pickup transmission problem
- Bolt Pattern question:need fast answers!
- Engine/Drivetrain?
- 318 problems
- tranny disptick
- Carb rebuild help
- starting problems,'86 Ram
- 83 ram
- 92 318ci falls right on its face
- Cost to have valve cover gaskets replaced?
- 47re Holds 1st Gear
- Who has a SSC?
- Not starting right
- 81-85 dodge headlamp bezels
- 273 heads on a 318
- 87 d100 3.7 auto rough running after new carb
- Tips on EZ way to drain old gas from tank?
- 318 timing chain woes
- Rarest Dodge Truck?
- Cooling problem......
- Thought I`d check in.
- 1990 Ramcharger crankshaft sensor
- Removing Windsheild
- stumped
- 90 d150 rough idle
- Need/want engine, what to do?
- 92 Dodge diesel overdrive cuts out
- scc?
- things to check for
- 1993 Dodge W150 Engine shut off while driving
- '85 150 door panels need help
- Join the TX Truck Club 1st Gen!
- Pulling a travel trailer with a 84 318 hp
- Parting out '87 Ram 150
- Not getting any fire to the dist.....HELP
- Parts trade?
- Smoked wiring, not as bad as I thought.
- Front seals?
- oil pressure
- Leveling kit - 1st Generation Ram
- Sick Gen I Ram
- 1975 D100 barn find
- Floor Organizer
- 88 D150 Rebuild
- heading for the mopar nats,who else?
- WTB engine computer
- 1989 dodge ram
- 87 dodge 318 electrical
- My 87 Ram
