View Full Version : 2nd Gen Dakota
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42
  1. TIRES for STOCK RIMS
  2. Exhaust
  3. trying to decide what crate to drop in my 97 Dak
  4. Programmers
  5. ABS & brake light on
  6. Click in steering wheel??
  7. New member looking for parts
  8. engine wont start
  9. Spark plugs for 4.7
  10. Gasket bad between Engine block andexhaust man.
  11. Clear Corner Install?
  12. Gears
  13. Aircraft Landing lights
  14. spring replacement, hours of labor
  15. Water on passenger side floor
  16. HOW TO INSTALL A POSI...
  17. Turbo blue prints
  18. new member - ignition problem and hissing
  19. AC/Heating Improvement
  20. spark plugs on a 3.9
  21. Viper motor swap
  22. 44RE to 46RE swap??
  23. Help With something
  24. license plate
  25. Lift
  26. vacuum leak/ Burning oil
  27. nvr mind
  28. backspacing
  29. lowering
  30. To many miles?
  31. What Size Tires are on Your Dakota
  32. Brakes
  33. thought TB spacers were out of control?
  34. stage 1 or 2
  35. tires after lowering
  36. Programers
  37. engine swap
  38. rhoads lifters?
  39. Stock 99 Dakota looking for suggestions
  40. No brakes! Need help!
  41. ignition
  42. Rockers or E-Fans
  43. Installing Dual Exhaust
  44. Dodge Dakota Taillights Smoked?
  45. computer tuning
  46. highest miles on a DD
  47. lug nut pattern
  48. Guage Mount Question
  49. TB cable
  50. 4.7 firing order
  51. Noise at idle, Tensioner?
  52. my kickass scan tool plan
  53. 97 Dakota Interior A\C|Heater|Outside Air Control Vent problem
  54. 545RFE transmission
  55. Late model Dakota
  56. General Info, Check Engine Light Codes, Paint Codes, Calculaters, ect.
  57. Transgo shift kits
  58. 2003 4.7L A/T Fluid Capacity?
  59. Paint Code
  60. Code reader
  61. A Dakota how-to!
  62. Replaced The Crank shaft Censor on my 2000 dakato 4.7
  63. heater core
  64. 02 slt
  65. brush guard
  66. 3" lift
  67. Trailor towing package...how good is it?
  68. remote start
  69. ball joints
  70. Shaker
  71. Exhuast and HP question
  72. hissing noise
  73. Sputtering
  74. 3.9 v6 ticking??
  75. Oil pressure sending unit
  76. Were is the Crank shaft Censor located
  77. Uncranked torsion bars and handling...
  78. Converting to power windows
  79. just curiouse-oil change...
  80. Were to buy turn signal lens
  81. Were to buy power lock acuators
  82. Help Crank shaft alignment Code
  83. Tonneau cover for sale
  84. part # for 98 dakota r/t
  85. Aftermark coil question?
  86. Help Cam shaft alignment Code
  87. round filter HELP ASAP
  88. help
  89. anybody know stock alt. amps?
  90. durango to dakota?????
  91. oil pressure gauge acting silly
  92. From vacation
  93. lost compression
  94. 4.7 with Auto, how durable over the long haul?
  95. Replacing the resistor block
  96. 2 engins problem codes - how do I check and fix these?
  97. U-Joint replacement - How difficult??
  98. Cooling fan
  99. Inside door panel
  100. Noob R/T questions!
  101. stereo speakers
  102. U joints or wheel bearings
  103. Underbody Thud and Dash Pop
  104. shifter knob
  105. n00b question about lowering springs
  106. Headlight adjustment
  107. Shocks
  108. which ones?
  109. Performance Intake manifold for 3.9?
  110. Dodge Dakota Manual Download
  111. 01 4.7 quad cab lift
  112. window cranks
  113. heater/AC
  114. srt-10 rims on a dakota
  115. NEW HORNS!!
  116. question on 2002 headlights
  117. 2002 DAKOTA RT TRANSMISSION FLUID
  118. themstat instalation??
  119. 2000 rwd rear axle question
  120. New member has questions
  121. Pictures wanted will pay
  122. windshield
  123. r/t engine fit w 3.7L engine swap
  124. Double din head unit?
  125. Turn signals not working??
  126. Wiper Blades
  127. Supercharger Question.
  128. New to forum....
  129. ANyone from Oklahoma?
  130. Center Console
  131. Another question about difforent Air intake systems
  132. Rear gear
  133. Striping kits
  134. Door panels
  135. Security device i found tonight.
  136. heatercore is leaking
  137. CarDomain dot com
  138. Gooseneck hitch
  139. Programmers
  140. What do you guys think?
  141. 180 Stat: Drill Hole?
  142. When is the air to cold??
  143. rims
  144. Exhaust headers
  145. fram boost availability when???
  146. helllllp!! can anyone help me with this????
  147. Advice, tips and suggestions needed!
  148. body lift
  149. headers
  150. air intake kits and higher mpg???
  151. polyeurethane bushings and header heat
  152. head unit
  153. Somebody Please Clear the 33" tire question up for me!!!!
  154. loud exhaust
  155. tires
  156. got her back from the bodyshop
  157. How to get more Bang.
  158. Looking For Quick Input: '99 vs. 2000 Dakotas
  159. 33x11.5x15
  160. Custom Grill "How to" anyone know?
  161. multiple questions thank you
  162. Answer this one please
  163. I want it loud
  164. OD question
  165. Wacko Gauges
  166. Update on horrible vibration
  167. LSD
  168. Recommend a good OBD scanner for me?
  169. Carbed + Fuel Injection???
  170. bouncing idle is driving me nuts!!! help!!!
  171. IAT Removal
  172. Headers
  173. overhead console mpg
  174. Which intake is better?
  175. Tranny Problems
  176. New to Dakotas but not Dodge.
  177. seat exchange
  178. tach signal
  179. supercharger, will it fit?
  180. oem wheels dont fit on lift kit? no problem
  181. Shifting 1st to 2nd
  182. Missing Bolt on Rear Differential - Size?
  183. throttle body
  184. trouble code P1756
  185. new tires...
  186. G-Tech Tesla Experts?
  187. 5.9 R/T Performance Questions
  188. gears
  189. performance chips/programmers
  190. Water on the passenger floor?
  191. Synthetic transmision fluid
  192. 97 Dakota
  193. Performance Mods For 02 Dakota
  194. Speaker Replacement
  195. windows smashed out
  196. 160 degree vs 180 degree
  197. trouble codes...need help
  198. 4x4 floor shifter loose (flappin') how to fix?
  199. tires
  200. 5.2 fuel system problem ?
  201. Can't Clear Code.
  202. dur
  203. performance please
  204. pics after fabtech lift
  205. 98 dakota, 3.9 v6, transmission trouble code
  206. a little help would be nice
  207. HELP!!!!! I Have Rust.
  208. ? about plugs
  209. codes 355..357..any ideas?
  210. Exhaust
  211. What else can I do
  212. 2001 Factory Service Manual, PFD Download
  213. for the 5.9ers
  214. Replacing a head w/ new aftermarket
  215. A painful Vibration
  216. 2001 Dodge Dakota Service Manual
  217. Transmission Problem
  218. What kind of wax?
  219. Want To Raise the Rear up a Little?
  220. Bauging Down At idle when Turning Sterring Wheel ! TSB?
  221. 2000 Daktoa Shifter Knob
  222. 5.9 transplant
  223. electrical ?
  224. anyone want a tutorial?
  225. Has anyone Here Tried The Turbonator Out?
  226. 2.5 gets 8.66 mpg......Help!
  227. HID lights????
  228. Need Your Opinion: Keep the Decals or Not
  229. 97 running hot
  230. anti spin diff lube
  231. a arm install
  232. 01 R/T wont run
  233. What the HeLL!!!
  234. Hi To ALL ,I'm New on The Forum (?)'s
  235. eyelids?
  236. Jerky starts......
  237. 2000 Dodge Dkota Sport, need advice on next upgrade
  238. throw out bearing?
  239. temp sensor
  240. Cold air intake?
  241. sts Turbos
  242. aftermarket stereo/taillights problem...
  243. Engine Shutter Problem
  244. New Dak in the yard
  245. Few questions...cooling system...
  246. throttle body spacer
  247. Ring and Pinion Question
  248. no code
  249. cruise control problem
  250. Hard steering on 2000 SLT, 4x4, 4.7 Liter
