View Full Version : 2nd Gen Dakota
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. R/T axle
  2. CV Axle question
  3. Rain water on driver's floor
  4. Misfiring? Went through some mud puddles
  5. Transmission Problem Code PO740
  6. Lift question.
  7. Strange Smell...
  8. Help Please?
  9. shift knob
  10. Quick oil question
  11. Cruise control problem
  12. 4wd Standard Transmission from 99 Dakota and other parts
  13. Weird RPM thing
  14. custom sniper style grille
  15. hood for sale
  16. FAQ subsection
  17. Nov. DOTM Nominations
  18. Transmission (I think)
  19. Daytime running lights/Taking truck back to Canada!
  20. axle weight limits
  21. wheels
  22. Fender flares
  23. Is it possible?
  24. Help!!!!!!!!!! Lights not working
  25. Tire sizes on stock 2002 4x4
  26. Torsion bar heigh affecting steering?
  27. Race advice
  28. Stalling coming to stop
  29. RPM limited issues
  30. Newbie!!Can someone help me??
  31. New guy needs transmission help...
  32. very poor mileage
  33. removing back windows
  34. free owners manual
  35. Fluids
  36. I just repaced my water pump and Spark Plugs and now truck wont idle
  37. AWD Dakota???
  38. any major differences from 2001-2004
  39. Glove box light?
  40. transmision swap manual to auto limpmode
  41. Po601.
  42. WaterPump Replacement
  43. motor questions
  44. Anyone ever change out piston rings on a 4.7: before?
  45. governor
  46. 97 v-8 swap
  47. Confusion on TTY bolts in the 4.7L
  48. 1997 with VSS problems, driving me nuts!!
  49. Anyone here plow with their Dak?
  50. exhaust with best low end...
  51. Intake manifold gasket replacement 2001 5.9
  52. Stereo
  53. Durable Shocks Search: who you got?
  54. 98 Dakota Audio
  55. HELP: Mystery Gremlin in Engine/Transmission Control
  56. 00 vs 02 Netural Safety
  57. 1.7RR question
  58. P0443.....My Solution
  59. Gasoline shoots out during fill-up-anyone else?
  60. Dodge Dakota lifts?
  61. How To: Fix bumper rust
  62. Tail Lights wont turn off
  63. Sweet Summer Pic...
  64. Interesting Main/Rod bearing wear marks
  65. Check Engine Codes
  66. B&M or Flex-a-lite?
  67. Hughes Air-Gap vs. M1 for 5.2L
  68. FAQ Ideas
  69. Faq
  70. Bad connecting rod in 4.7L
  71. clueless about exhaust
  72. 2000 Dakota question
  73. acceleration problem, bad tps?
  74. 04 Dakota Heater Problem
  75. SoCal Truck Club now accepting members
  76. Fact or Fiction
  77. Has anyone replaced a waterpump bypass hose?
  78. Headliner removal
  79. Question on Heater Core System
  80. Another tire question
  81. I have questions about mods I want to do
  82. difference in trim packages?? newbie here
  83. DIY: Rebuilding a Track-Lok LSD
  84. T-case shifter extension
  85. Will replacing the O2 sensor increase fuel economy?
  86. 97 Dakota Charging Issues: Please Help
  87. Dirty Tranny Fluid Flush...Yes or No
  88. 2004 2WD SXT Rear Brake Drum Diameter? 9" or 11"
  89. Suspension: Ball Joints & Shocks Install
  90. just a quick post
  91. suspension question
  92. Sqeeking Noise
  93. Cant find an answer!
  94. Flowmaster 40 Muffler + Seafoam Treatment
  95. Problem w/ Anti-slip Differiential
  96. 4.7 swap
  97. alternator compatibility
  98. washer nozzle broken
  99. Bump Stops
  100. 5-speed driving for mileage
  101. 5.2 rebuilt-oil in 1 valve cover-low pressure?
  102. Flowmaster 40, 40 Delta, 50 HD?
  103. Lowering Kit?
  104. 02 dakota 4.7 overheating problem
  105. '00 Tranny swap question
  106. Finally Got my Body lift & shocks put on my truck !
  107. Unpowered Cig lighter?
  108. Differential Help!
  109. FS: DDM Tuning 8k High/Low HID Kit 9007 Bulb
  110. Caught them in a lie!
  111. Batman Sighting!!!
  112. 97 Dakota No Start HELP
  113. Amp installation
  114. bellhousing/tranfer case separation
  115. Someone Help, PLZ PLZ PLZ HELP!!!!
  116. yay new headunit!
  117. 99 dakota 5.9 RT trans?
  118. My work on my 2001 QC
  119. Please help..truck won't stay running after TPS calibration.
  120. What is the thinnest tires that could fit stock SXT 16 inch (7inch width) rims
  121. t-case nob
  122. How much does insurance cost on your Dakota?
  123. New to the forum! Afew Questions...
  124. Hooking up Trailer brakes w/ controller. Do I have tow package?
  125. can i get a little help with my new 00 Dakota?
  126. European Headlights- best?
  127. 99 dakota tranny
  128. 99 dakota fuel
  129. new wheels and tires
  130. Jet Accu-Speed Calibrator
  131. 318 engine problems
  132. Hooking up Siruis into Stock 2002 Radio
  133. 98 Dakota Rear Brakes
  134. So yea dry rot sucks
  135. 97 v6 dakota overheated and wont start!!
  136. new daily driver
  137. Wits end with Stalling 97 dakota any help?
  138. Help register truck
  139. Water damage
  140. Removing your cat
  141. ummmm....
  142. stock infinity headunit
  143. Drum brakes
  144. Driveline Lock-up Scary Stuff and highway Speeds!
  145. Locking Steering Column
  146. 98 Dakota Tran issues
  147. O2 sensor removal
  148. peeling clear coat
  149. nv231 transfer case question
  150. Quick headlight Q...
  151. 5.9 exhaust advice?
  152. No brake lights, hazard or turn signals 2003 Dakota
  153. WTB some slotted front rotors for a 1999 5.9
  154. Tuners! Clear Corners!
  155. engine/transmission combos?
  156. ye or ghey?
  157. Headlight mods.
  158. Purchasing Dodge Dakota, towing questions, former owner
  159. Pillar mount gauges
  160. HELP! Overdrive kicking off
  161. split hose
  162. Lift Kit for a 2001 Dodge Dakota
  163. Exhaust question
  164. 22 gal tank?
  165. Bosh vs. Denso Alternator. Important?
  166. 02 ABS issue
  167. Alternator, Battery or Voltage Regulator in Computer?
  168. Voltage Regulator, Alternator or Battery? 1999 Dakota
  169. Instrument Cluster
  170. question about 4.7 dakota (gas mileage)
  171. wheels
  172. People amaze me...
  173. cam??
  174. Sway bar bushing options
  175. 99 dakota flywheel
  176. Non R/T Package Durango with a 5.9
  177. Good deal or no?
  178. need some help with motor build
  179. Djm 3/5 inch drop ?
  180. 99 dakota 3.9l at transfer case
  181. broke torsion adjuster bolt!
  182. What R The Differences Between Dakota 4.7 n Ho. 4.7 In The Jeep Overland
  183. Cold start trouble
  184. got some cragars
  185. rear pinion seal
  186. Check engine Light
  187. Bfsc?????
  188. REAL cowl induction hood
  189. Radio has power but no sound?!?
  190. Turn signal woes
  191. 2004 dodge dakota car stereo question
  192. Looking for 4.7 manifold upgrade info
  193. Truck whips back and forth?
  194. No heat on low fan
  195. 97 Tranny Issues .... Need Assistance
  196. Having trouble selling 2000 Dak
  197. I wish I was retarded !
  198. coolant leak help
  199. Where is the tach wire?
  200. spindle/key lift for my 02 dakota
  201. electrical gremlins
  202. 1.7 Harland Sharp Roller Rockers
  203. killed the 42RE...
  204. tranny problems code p0733 and p0734
  205. another fiberglass part in D Kota
  206. Turtle Wax ICE question
  207. 99 Dakota 4x4 Front axle
  208. Front Brakes Locking Up PLZ Help
  209. What a thing to wake up to
  210. Aftermarket Air Intake/Filter
  211. differntial problem
  212. 03 Dak with odd issues need ideas..
  213. please help 99 Dakota
  214. 318 Tranny issues
  215. 3.9 engine miss
  216. engine chatter in the cold mornings
  217. 98 Dakota Club Cab 1/4 Window Replacement
  218. Brake adjustment...
  219. Dash Problem
  220. 2001 4.7L Trouble starting hot
  221. '01 Factory Stereo ID
  222. Leaking coolant/water from somewhere...HELP
  223. 32x11.50 Goodyear MT/R's on 15x7 Dakota Wheels For Sale
  224. Whats the best - Tires?
  225. tire size
  226. will this tranny work?
  227. 4.7L Valve Cover Gaskets
  228. Got manfiold leak partially fixed. lol.
  229. mechanic says 2004 dakota computer 'locked down'
  230. back seat subs...
  231. Replaced brake flex hose and now I have leak
  232. coolant leak at timing cover
  233. Vibration when in gear
  234. TPS problem P0123 high volts (please help)
  235. 2001 Dodge Dakota 4.7L 'Clattering Noise'
  236. anybody want subs? pretty cheap
  237. headlight bulb smoking
  238. What do you use in oil changes?
  239. Old truck new user 1999 Dakota
  240. DOTM Oct
  241. Plenum Gasket Bad?
  242. Is high mileage bad?
  243. 2001 Dakota 4 cyl clutch install... torque specs?
  244. where do i dig??????
  245. Help please from the UK
  246. 97 Dak rough idle..sometimes..suspect MAP
  247. Tires
  248. CEL Code P0601
  249. high idle?
  250. oil pressure/dip stick overfill?
