View Full Version : 1st Gen Durango
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23
  1. getting ready to buy a durango
  2. Transmission Filter Kits
  3. Tranny Issues
  4. 4x4 Question
  5. Uncooperative headlights
  6. "01 durango problems?
  7. brakes!!!
  8. CV joints and/or transfer?!
  9. 99 Durango tranny valve replacement
  10. luggage rack replacement
  11. A/C Comp. noisy/99 Durango 4x4 auto
  12. WINDOWS WON"T ROLL UP!!!!!
  13. Front Center Section 3.92 gear ratio
  14. where to buy shackles
  15. Heat Shields on Spark Plugs
  16. Chrysler Tranny Plant!
  17. '99 Durango reverse light problem
  18. P0456? Evaporative leak?
  19. How Heads are and what to expect on 5.9L!
  20. Durango questions
  21. 1999 Durango Tranny Problem
  22. 1999 Durango Tranny Problem
  23. Dash board annoying squeek rattle
  24. Cruise Control Problem with '99 Durango
  25. Why not to 4x4 on dry pavement..
  26. ABS
  27. AWD vs. 4WD
  28. Starting '01 Durango
  29. Rear differential fill location?
  30. lifting a durango
  31. fog lights not working
  32. Dash squeeking
  33. Need help with my dash
  34. Windshield wiper woes
  35. Need coil info bad
  36. Hazards coming on with turn signal?
  37. im hoping someone here will help me!!!
  38. 1999 Durango Speedometer
  39. Tanny fluid and filter change (how much fluid)
  40. iPod Integration
  41. Misfire #5....any advice?
  42. Just installed a new battery cable - question...
  43. 00 5.2L Transmission problems when cold
  44. Running Rich?
  45. Dakota vs. Durango
  46. DOOR WILL NOT UNLOCK!!!!!!!!!!
  47. Fishtailing issues on my 2000 Durango ---
  48. 03 fan clutch
  49. bulb sizes
  50. Brake Lights
  51. clutch fan removal
  52. Disable security
  53. 1pc Headlights
  54. Newbie Lurking Around
  55. Chip or Programer question????
  56. Windshield Washer Pump
  57. Snow pkg
  58. 02' front bumper
  59. 1998 ABS experts???
  60. Driver's Side Heated Seat Failure
  61. Driver's Side Heated Seat Failure
  62. 98 Durango headligths
  63. air flow
  64. What transmision do I have
  65. Power and/or Fuel problems?
  66. I need to drain my fuel
  67. New problem
  68. Fuel hose question.
  69. Fan Clutch question?
  70. oil pressure
  71. 2002 5.9L with no front heat
  72. 1998 D Key Fob
  73. Activation of Tamper Alarm
  74. how do i drain the antifreeze??
  75. what should i` be looking at! CODES
  76. Wont start everytime
  77. slt or slt+
  78. HELP!! The RWAL ??? CAB is making noise
  79. Will 31s fit?
  80. '99 Durango -- Brakes grab
  81. Can anyone help with what a HO2S Circuit Bank 2 Sensor 3 malfunction is?
  82. Auto-dim mirror wiring
  83. Power Steering problem?
  84. 5.2L CRANKING BUT NOT FIRING NEED HELP!
  85. volt gauge
  86. bad sensor?
  87. Little accident, lookin for some parts
  88. 2000 Durango w/no heat
  89. 4WD Durango
  90. Best mileage with a 5.9 ?????
  91. heater core flush
  92. Adding 3rd row seats?
  93. Bearings?
  94. Preparing truck for hauling cars
  95. Scraping Noise in bottom front left only when driving straight
  96. beeping sound
  97. 4wd troubleshoot
  98. Help diagnose Humming noise problem
  99. 2000 durango r/t transmission
  100. 2003 R/T All Wheel Drive???
  101. cranking no start
  102. cranking no start
  103. I Need help with the Speed Sensor.
  104. new owner help needed
  105. How much do you think I can get for my durango???
  106. Rear End Noise
  107. Towing issues
  108. Durango burnout.
  109. mobil 1 or mobil1 7500?
  110. who lets their D's warm up?
  111. Any suggestions???
  112. Durango RPM's
  113. MOVED: I kicked some Cherokee BUTT
  114. Tire Size?
  115. Rear Brake Noise
  116. My first Dodge, I have a question...
  117. Tire size
  118. turbo?
  119. 99 Dodge 5.9 L Durango
  120. Bad Day
  121. rear defroster not working
  122. Noises
  123. Help! fuel pressure
  124. torsion/shackle lift
  125. 2001 dodge durango
  126. towing
  127. Cheap Lifts?
  128. 99 Durango shuts down while driving
  129. interior heating
  130. Occasional rattling-not sure where from
  131. Are Durango & Dakota Suspension Same?
  132. Noise
  133. changing fluids
  134. changing transmission fluid
  135. no rear heat from overhead ducts
  136. Low Oil Pressure
  137. No shift to 2nd after sitting for 2-3 days?
  138. 2000 Dodge Durango Service Manual
  139. 2003 durango. code P0038 what's does this mean??
  140. Bucking Durango
  141. timing gears & chain, distributor gear failure?
  142. 98 to 01 Durnago
  143. 2000 Audio Capabilities
  144. 2001 durango electrical problem
  145. Need some facts about stock sterio specs.
  146. Die Cast or Plastic Model Durango R/T
  147. Dash board question on '01 Durango SLT
  148. check engine light is on and sometimes flashes
  149. black durango with black or dark rims
  150. Front tow hooks on Durango
  151. P0440 engine code
  152. Limited slip addative/fluids
  153. Power Windows (Driver side)
  154. Broken Heated Seat
  155. 02 durango spark plugs
  156. Driver/Passernger Temp Control & RearWiper Control...
  157. black box upgrade
  158. Durango Problems
  159. 2001 Durango stiff steering
  160. 99 Durango stalled, now it won't start!
  161. THOR Remote Starter
  162. Front Wheel Driver side Clicking Noise
  163. Cruise/Defrost
  164. HID's on a 99
  165. Radiator Help-Replacing
  166. 2001 Durango - Random Headlight Blinking
  167. Radiator Leaking
  168. 02 A/C blows fuse
  169. Question about winter driving..
  170. WATER PUMP PULLEY
  171. A/C condensation leaking on exaust.
  172. Headlight Wiring
  173. 2002 4x4 Front Rotor Removal
  174. p o 161
  175. 1999 durango headers and downpipe
  176. R/T bogging down
  177. Electrical problems
  178. rear bearing replacement HELP!!!
  179. Transmission
  180. rear end Noise
  181. Anyone looking for a stock Durango hood?
  182. Front hub assembly without antilock sensor?
  183. 99 Durango w/ fuel PSI falling to 10 psi U/Load
  184. Checking engine codes without code reader?
  185. Bad Vibration
  186. I Think I Killed It!
  187. I need a rear bumper?
  188. '02 R/T Heated Seat Problem
  189. remote starter
  190. Changing Fans
  191. Transmission goes rrrrrrr. Like a lion!
  192. I Bought The R/T! (follow up to: Should I Buy This R/T???)
  193. My transmission is acting weird
  194. my 2001 durango starts but dies at idle in morning
  195. need a new engine
  196. Should I Buy This R/T????
  197. p0500 error, no speed and ABS light stays on: speed sensor issue?
  198. Tire dust Discusted
  199. water pump
  200. It worked
  201. Idle Troubles
  202. Smelly!!!
  203. Coolant leak
  204. speedometer
  205. 99 durango stall...
  206. 99' Front Bumber
  207. Brake lights stuck on when headlights on, parking lights come on when pressing brake...
  208. 2001 4.7 Cam Sensor Seal and Extension Housing Seals
  209. It's broken!
  210. R/T 5.9 vs. SLT 5.9 Bring it on!
  211. Glove compartment
  212. Brake pad and rotor replacement - 2002 SLT 4.7
  213. Programming software?
  214. Hey fellow DD's! Newbie here!
  215. Can someone post a picture of their intake heat shield?
  216. Door latches
  217. Remove Wiper arms
  218. 2003 durango problems?
  219. Recall info
  220. ABS BRAKE dash lights
  221. R/T vs SLT Plus
  222. HELP>> How do I get Lower Ball Joint out ?
  223. 02 Durango CEL code P0456
  224. Recalls on 98 D
  225. torque, injectors, cruise control, oxygen sensor
  226. Ball Joint Replacement Procedure?
  227. Clutch fan vs electric fan
  228. P0442 EVAP emission control system leak
  229. Help! Steering Problem
  230. Anyone need a 5.2???
  231. Hard starting
  232. that damn code reader
  233. Help Needed Solving Codes P0202, 0207....
  234. Just got My Durango
  235. 2K Dango and Belt Tensioner replacement need Help/Directions/Advice
  236. Anyone need a 5.2???
  237. Idle Problems on 2K 4.7L Durango
  238. Question about lifts
  239. Ticking noise from A/C compressor
  240. Electrical Problem
  241. Blowing hot air
  242. Stripped Brake Caliper Bolt
  243. 99 With Odd Brake Problem
  244. Durango stalls - It's in the UK and I am in Qatar
  245. 4.7 Tranny
  246. Info on towing a 2003 Durango
  247. Lift kit question
  248. Looking for info on how to build my own CAI
  249. Replacement Speaker
  250. Driverside front suspen noise
