View Full Version : 1st Gen Durango
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. Cable Adjustment
  2. P0430 1999 durango
  3. Error Code P0203
  4. Head lights help
  5. 02 Rear end howls
  6. PCM Install?
  7. 1999 durango service manual
  8. Middle of Nowhere Auto
  9. How to find out if PCM is bad
  10. 4.7 made me angry help
  11. 4.7 engine interchange
  12. Transmission help...
  13. Idle issues
  14. New guy needs transmission help...
  15. p0171
  16. heater not hot
  17. got any suggestion or have I covered my bases well enough?
  18. 35's on 20's
  19. Numerous codes
  20. Brake & ABS Lt. on above 35mph + C.C. out
  21. apperently mud is bad for bearings
  22. Blinking D
  23. 2000 Durango Trailer harness wires??
  24. Rear Axel Speed Sensor / Rear ABS Sensor DIY
  25. Should I change Transmission fluid & where to buy gears
  26. is a T/S lift worth it?
  27. Temp sensor on rear differential
  28. What would make a Battery just die.
  29. Just pulled a truck with the D
  30. '01 V8 overheated today...
  31. 2001 V8 overheated today...
  32. 3-4 shift problems
  33. 2002 security lights,security system help
  34. Rusted up Sparkplus cap bolt
  35. Door Locks. Same problem, different approach?
  36. 98 Durango OBD 1597 HELP
  37. Exhaust Repair
  38. where would I buy a new engine and can I install a better one?
  39. Engine making a tat tat noise
  40. Dealer 4x4 Service (Differentials)
  41. Dealer prices for mechanic work - what would you do?
  42. ... Head Gasket job... parts list? and a shop to rebuild the heads...
  43. Squeaky Ride - 2001 Durango
  44. it time again
  45. Fornt end noise
  46. Front end troubles
  47. cv seals
  48. Oil Priming idea worked awesome!
  49. Compression Test Results
  50. Heat and Air Issue
  51. HELP!!! No rear breaks with the ABS and Break lights on all the time
  52. DIY: Rebuilding a Trac-Lok LSD
  53. 2001 Durango Squeaks
  54. May bring tears to your eyes
  55. Newbie with questions
  56. Tranny Issues
  57. Free Heated Seat Fix
  58. What should idle speed be?
  59. Rear window help please
  60. Durango R/T Liftgate pistons
  61. missfire problem
  62. 2002 4.7L Durango: Spontaneous Overheating Help
  63. Replace instrument cluster does engine size matter?
  64. Electrical issues
  65. durango drivers
  66. Duun duun dunnn
  67. I cant find these parts!! help please
  68. I want more Power!!
  69. 2000 Dodge Drango
  70. Quick Differential Help Please!
  71. Opinions needed
  72. Dash Removal
  73. T/S lift forged torsion cams
  74. wierd noise
  75. Paint help.
  76. Power outlet fuse
  77. Replaced brake line on '98 Durango
  78. No Headlights, Park Lights, Dash Lights
  79. CV Shaft
  80. power outlet fuse
  81. Edelbrok F1 Intake????
  82. custom leaf pack
  83. Pcv
  84. Durango Oil Filler TSB
  85. Won't start, help! 1999 5.2 Durango
  86. SERVICE 4WD Indicator reset
  87. Hooking up system to stock radio..
  88. stereo removal, aftermarket installation??
  89. 1998 Durango brake line replaced
  90. How do I install new speakers??
  91. Help I cant find the thump
  92. How do I install new speakers??
  93. Skull Hitch
  94. P1281 2003 Durango
  95. I Think I Have Electrical Issues
  96. RPM's spiking
  97. Thinking about buying a used Durrango
  98. New Belt for 2000 Dodge 5.9
  99. should i buy this durango?
  100. Installing a tank type eng heater
  101. TCM Location 2001 Durango SLT 4WD
  102. Cutting out and not starting.
  103. transmission surging going uphill pulling load
  104. Smoke on the water...
  105. Dodge Repair Manual
  106. Alternator
  107. new D owner
  108. dodge has the shakes--part 2,harmonic balancer?
  109. rubber/plastic grommets on 4x4 linkage?
  110. Hopefull New Durango Owner
  111. Coolant Check
  112. blinker and dash lite problums
  113. Couple of Questions on the durango 98
  114. 'Nother New Guy Willing to learn!
  115. 01 Durango R/T Tranny Issue
  116. Gap in between the bumper and grill
  117. Which exhaust??
  118. 2000 dodge durango got the shakes??
  119. Tail lights
  120. overheating
  121. durnago OEM Spark Plug Wires $63 at dealer
  122. New to the board
  123. Problems with motor fan
  124. easy mods for 5.2 for more mpg
  125. Radio replacement
  126. 1998 durango tach issues
  127. Sparkplug Durango 5.2
  128. Mirror problems ended
  129. 99 durango obd2 port dont work?
  130. Trans overdrive issue?
  131. Fog light recommendations
  132. Dropping gas tank 1998-99 dodge durango
  133. P0601 PCM Internal Ctrller Failure
  134. Tire Suggestion
  135. P 0132
  136. My inifity speakers suck!!!
  137. Need Help Hit a pole with front end
  138. Cold Weather Starting
  139. Another Transmission Issue
  140. After hot no crank & trans slipping 98 durango
  141. Durango Delima
  142. need some answers
  143. Transmission Issue, Can't figure
  144. waht to do first?
  145. New to forums and new durango owner
  146. What battery type...
  147. Fan Clutch?
  148. Electric Fan; At What Temp Should It Engage
  149. Fluid capacity for 45RFE?
  150. Trans fluid change
  151. gas issue
  152. Another Newbie???
  153. Engine Light On
  154. 4.7L Durango issue HELP!!!
  155. Braided, Flat Wire Connection Question from Newby
  156. Problems with 2003 AC Vents
  157. I'm afraid to shut off the D!
  158. Aftermarket Exhaust
  159. 4X4 not engaging
  160. question about vacuum lines
  161. Custom Cold Air Intake for 4.7L V8
  162. tires again
  163. Fuel issues
  164. Reverse lights don't work
  165. Alarm will not shut off
  166. 98 D Blower power
  167. Sub with a stock stereo.
  168. No Rear Heat!
  169. Help with wheel hub!
  170. Air noise on a 2000 Durango.
  171. Where is the Leak Detection pump on a 2002 Dodge Durango
  172. Transmission Trouble
  173. 2002 Dodge Durango (Newbie)
  174. NEWB Question: Part # request
  175. NEWB Question: Part # request 2002 Durango
  176. Body Parts Durango and Dakota
  177. Transfer Case Q&A
  178. Leaf Spring Bolts
  179. Overheating on 5.2 Thermostat??
  180. Fitzall 220 AMP Alternator Install?
  181. Electric Fan Not Working?
  182. electric brake controller help needed
  183. Crazy 4.7 Longblock price
  184. 4.7 Engine Install?
  185. heater core removal
  186. Virginia-minneapolis bound
  187. 2000 durango slt plus transmission solenoid
  188. No start. Clicking Relays
  189. 2000 Durango 46RE Transmission Problems
  190. Where to buy timing set for 4.7 Litre
  191. 33's on stock 98 durango?
  192. 1999 vs 2000 Wheels
  193. '99 Durango water pump questions
  194. 4.7 Rebuild?
  195. Idling problem... happened twice...
  196. Transfer case question...
  197. New engine
  198. pulsing battery draw
  199. What transmissions will fit my 2000 Durango
  200. Durango ildling problem
  201. 01 4.7L Durango steering shot...
  202. What are the torque specifications for the transmission pan bolts?
  203. New Tires
  204. Flowmaster
  205. Water pump replacement stubborn fan clutch nut
  206. Loud noise/vibe in front end
  207. Check Engine Light
  208. towing big enclosed trailers. need advice
  209. 2000 4x4 need wiring schematics
  210. Looking for a steering knuckle
  211. ATF+3 v ATF+4
  212. i need to find neutral safety switch located
  213. I think my Water Pump is out please help me :-(
  214. auto locks dont work on gate.
  215. AT tires on a R/T?
  216. Window Clips
  217. 2002 2wd durango rear brakes
  218. burned out headlight
  219. 99 Durango Bearing Or Differential Issue
  220. Touched POS on battery with tool, now won't run?
  221. Blowe Motor replaced but barely blowing air out
  222. Changing Trans fluid/filter Q
  223. 2000 4x4 battery draw
  224. Help! Changed Battery now it won't start!!
  225. 2003 Durango Transmission
  226. Low Compression
  227. how many quarts of oil in 98 D
  228. Adjustable Shocks
  229. Gas gauge shows "Full" all the time
  230. Recalls
  231. 4 Wheel Alignment Woes
  232. 99 Durango turns over but doesnt start
  233. Engine Swap
  234. Clattering on cold starts
  235. 99 Durango oil pressure gauge
  236. 4 Wheel Drive Linkage Grommets - How to install??
  237. Odd door buzzer and lights not working issue
  238. Headlight/Steering Column Issues
  239. Headers 4 sale (5.9L and 5.2L)
  240. 2000 Durango Rough Start-up
  241. gas tank,fuel pump,and regulator.
  242. Ball Joints
  243. when slowing down and reverse i hear clicking.
  244. Transmission Diagnostics
  245. 46RE blues
  246. Transmission Troubles
  247. power steering hoses
  248. 99 slt brake caliper pin-type/size?
  249. Rancho lift with stock rims
  250. 99 durango cranks but doesnt start.
