- Signal Light Help!!??
- transmission shifting
- Anyone driving a 08 with the new motors?
- Durango problems
- Used body parts
- 05 with error code P0038
- Spark Plugs
- Navigation error message
- Diablosport is looking for tester durangos
- The 2008 Durango Assembly Plant Tour
- '05 bumper cover?
- '05- where do I find what codes mean?
- 2004 Durango Limited PCV valve location
- 05 durango rough idle
- New onwer Durango Hemi.
- Looking at an 05
- Check Tire Pressure Light Stays On - Any Help?
- Might buy 04 SLT, a few questions...
- Transmission Chirping sound??
- Exaust Manifold bolts
- power outlet failure
- Cooling problem
- DF Video!
- Durango rear gears
- Goodyear Wrangler Silent armor
- trailer brakes controller wiring harness
- Mil code for 2006 durango
- plastic woodgrain...good job dodge
- 2006 Durango won't start when hot
- 06 D Overheating when towing
- Rust
- REC Navigation/Radio '05 Durango Limited
- AutoblogGreen tries out Chrysler's new Aspen Hybrid
- Programers for hemi
- Drive by wire??
- 2005 Durango Codes
- power steering and water
- Trailer wiring harness
- air bag light
- Interior/Courtesy Lights
- Wiring Harness ?
- DVD player popping the fuse
- Clicking noise
- Hemi Exhaust Question
- 2007 Durango door locks
- new owner 07 durango limited 4.7 flex fuel
- New 05 Durango Limited 4x4 Hemi Owner
- 2 Question
- 07 Durango Rear Bumper Step Pad??
- Looking for part ## or "what's it called"
- Blower Motor Resistor- 2004 Durango
- 05 Durango AC not getting cold
- Which Transmission, Transfer, and Diff?
- 4 Wheel lock flashing
- 2005 Durango Hemi Air intake
- Radio R&R on 2005 Durango
- Help, $ Wheel Lock
- Car TEMP question
- MYGIG LOCKPICK IN-MOTION HACK
- SLR performance chip
- Durango Guys
- DVD in 2007 Durango
- Keyless stopped working
- Bad EGR Valve, made all kinds of problems for me!
- 05 durango blower motor not working
- When to get a transmission service
- Radio and Navigatio
- 05 Durango Ltd ?'s
- About to buy 04 D
- Safe Towing Question
- Black RANGO with new shoes
- Black RANGO
- Jet chip and better Gas mileage
- H-Valve (Air Conditioning)
- CEL help please
- 2004 Dodge Durango Big Horn
- Flowmaster Exhaust
- Aftermarket Radio Installation
- NEW to me
- fog lamps
- I have a trailer hitch and complete wiring for sale if anyone is interested.
- 06/07 Bumper covers
- Fuse Information
- Radio problem
- Keyless entry quit working
- axle ratio? 3.55 or 3.92?
- Key Sets Off Alarm When Opening Door
- I very seldomly post but....
- NAVIGATION MOTION BYPASS
- chip firmware upgrade
- Flowmaster Exhaust + Amplifier ?
- Electric Throttle Control
- Exhaust question
- stored code p2299
- 2004 DURANGO A/C PROBLEMS,HOAT COOLANT
- 2006 Durango smoking problem
- Durango 2005 4.7L: idling problems
- Question - Cleaning Engine
- 2004 durango/2004chrysler 300 radio
- Motor Oil
- Headlights
- Handfull of Questions
- ENGINE LIGHT/ REMOVE KEY STILL RUNS
- Outer Tie Rod for 2005 Durango
- Drivability problem 2004 durango Hemi
- Rack and Pinion
- Thud noise through steering column
- Where is this IAT sensor
- Few Durango towing questions
- Tire Pressure Monitor Sensors
- Axle Ratio
- anyone know any lift kits out there?
- Rear air bags for towing
- Nav Gps Antenna
- Trouble Looming?
- My 08 D on Air Bags
- How to deactivate the daytime running lights on a 2007 Durango?
- LIFT KITS FOR 2006 "D" 4x4 LIMITED
- Programming key fobs...I can't get it completed!!!
- EGR Valve
- Best Fit Wheels Durango 08
- Dual Exhaust System Durango 08
- 04 Durango SLT
- Nice Intake
- suspension lift kit
- Help with ESP
- 2004 and 2005 Durango - Nav Upgrade
- Battery shorted out
- Won't start
- 07 Service Manual
- New to me '04 Durango AC recharge question...
- 2004 Durango Transmission
- 2004 Durango Radio Problem
- Gas Mileage
- durango dual exhaust
- Looking for trailer lights and electric brake wires
- Tornado
- 2004 Durgano 4x4
- 04 Durango Problem
- Large trailer towing w/ the Hemi and 3.92
- '05 Durango ?'s
- Digital Climate Control
- 08 overhead console
- passenger side airbag
- performance chips
- Adding coolant : Need a little advice from the 4.7 crowd
- Tire Size
- Radio Question
- Overhead computer???
- LUG PATTERN
- need your opinion
- REC NAVIGATION UNIT 2004 DURANGO
- Need hitch advice
- advice on CAI for 2007 durando
- Help!!! 2005 Durango Rims are a mess
- Brake dust on rims
- What is this on the overhead console?
- 08 Durango shutting off
- Hello to All, 1st Time Dodge Owner Here
- this is my GM has lost so much ground.....
- 2005 Durango Drivetrain Vibration Concern
- I want to upgrade to REC NAV on my 2004 Limited
- '04 SLT Factory fog lamp lens replacement
- Turned out to be valve spring
- PAINT ISSUE!!!
- Fluid Leak
- can you guys/girls please help me
- ? programming second transmitter
- Aftermarket DVD System solutions
- oil light???
- Large vacuum leak
- Replacement mirrors and Brake Pads
- Newbie
- 2005 Durango Bulk-Up!
- Factory options in 06 Durango
- SCT Tuner for 04-06 Durango's
- 04 Durango shutting off
- Turbo Durango.....
- Rotora 8 piston big brake kit
- no. 8 cylinder mis-fire
- best way to improve gas mileage?
- wheres best price on K&N FIPK for 5.7 hemi durango
- crossover rails
- Transfer case actuator motor
- 09 Durango
- 06 Durango with Hemi, Airbag, brake and ABS light just came on, on my dash. HELP!
- dvd console
- Durango towing mirrors too short
- windshield wipers come on at ignition
- alarm probs
- Royal Purple
- What truck did this come from
- MPG on a 06 Hemi
- thinking of buying 05 Durango???
- Audio question
- Airbag Sensor
- Anyone with the new 08 4.7?
- Four Wheel Drive Functionality
- installing a grill guard on 06 durango
- Rear Diff. question
- part # for headphones
- Drivers side mirror needed. ASAP.
- How do you replace a rear tailight?
- Noise Only when in Overdrive
- Stock 04 and up airbox.
- Problem with my Durango..
- Adjusting headlights
- '05 Hemi just quits
- Back up camera
- Airbag Light/Code found
- 04' Mygig? SOMEONE HAS TO KNOW!!
- 04' Remote start?
- Problems with billet grille! please help
- Will MyGig unit work??
- Reading dignostic codes
- Need new tires at 34k
- Newbe, Just purchased a 2004 Durango Limited
- Looking for base plates 04 Durango
- New here and need some help re: recall issue
- 2004 Durango Instrument Panel.....
- truck won't start...
- Black trim turning white.
- Venting...Why aren't they responsible?..
- Strobe Lights for Signal and Brake Lights
- 2005 5.7 HEMI noise when started
- 2004 durango AWD wont start
- 04 Durango Wheels
- Question from girl.... Durango won't start
- C Clips
- spark plugs
- Dodge Durango caravan crash
- keyless remote
- Gas Mileage ?
- 06' DURANGO HEADERS
- 4 Lock Light flashing occasionally
- EGR..Check Engine Light Help
- Any problems towing with 3:55 and Hemi?
- I rolled my Durango! RIP
- A Key Problem
- newbie to the hemis......
- Magna flows installed
- E85
- keys
- Adventurer Options
- OEM running boards for 07 Durango
- CHROME CLAD COVERS OFF?
- vibration while brake fully depressed in 06 hemi
- Newbie w/questions
- Looking to buy new Durango or Pilot
- Liftgate Cargo Light
