- fuel pressure regulator
- Stock Radio
- MAP clamp or missing link?
- saturday night...
- UH OHHH!!! TIMING BELT TENSIONER
- Body Kit
- ride height??
- Lots of parts FS!!!
- CAI question
- turbo kit moving along smoothly
- new clutch???
- does anyone...
- downstream o2 sensor
- Catylatic Converter Removal
- rims & tires
- interior customizing
- no rpm's
- Lowering
- in car cam
- subs went wrong
- Excellent Neon Page...!
- cruise control
- header question
- stupid dealership and banks
- Speed Control Solenoid Circuit!
- VC1
- Worth the money ?
- Audio
- Fuel Sending Unit
- Air Bag Light?
- 97 neon brakes
- 98 R/T Body kit/Exhaust questions
- All talk no action!
- Can't go over 4000rpm!!
- O2 Sensor
- Best Way To Remove Flaky White Paint?
- Need a way to empty the tank
- carfax
- What Is Special About 95 Sport Coupes?
- 96 Neon running rough
- PCM code question
- 95 neon sputtering under acceleration
- Catalytic Converter Question
- nothing important.
- 2 dr 95 neon ...... lol
- What Can i do to make and Naturaly Aspirated SOHC???
- Need more fuel.......?
- Air/Fuel and Volt gauges..
- '96 auto trans vibration
- upgrade
- Which should I do?
- Problems with Shaved door kit.
- Battery light is on
- -How many RPM's-
- Front Brakes
- New Pics opinions please :D
- Seats.
- HELP I want to swap sohc to dohc
- 97 Dodge Jumps
- UDP
- got horsepower
- Alternate coils
- Front Speakers
- is this a normal sound lol...
- Help with Fan Issues
- Gauge cluster already soldered
- Neons been sitting 3 months: belt smoking
- Question about shocks
- Significance of cel blinking
- 4 lug vs 5 lug
- sohc question
- trans leak
- carbon
- Royal Purple Oil
- Bad Squeal
- Srt-4 head
- push in clutch...hear air..
- sad story today...
- no spark and cel light isnt working now.
- Spark Plugs?
- HEATER & AC BLOWER DOES NOT BLOW
- FU#*^ING CAM!!
- Starting Problems...????
- oil question
- No brake lights, No turn signal in rear
- Spark plug broke in unusual place PLEASE HELP!!!
- 2005 2.0L engine the same?
- Sohc vs. Dohc
- engine swapping
- Is this Neutral Dropping???
- SRT4 cams ??
- 97 Neon SOHC no start trying everything
- fuel pump ?
- Wheels?
- quick throttle body question!
- Engine Dress up
- Oil catch can?
- intake manifolds
- 2.4 turbo swap parts list???
- Steering Question...
- question to all ye' old r/t owners
- Air Bypass Valve
- engine swappinmg
- sohc to dohc done but.....
- Got a 97 4dr DOHC
- Starter Installation?
- 1995 Neon 5 speed tranny problem
- fuel pump sender?
- Exhaust??
- 98 Neon SOHC Rough Idle, Stalls at Idle Help
- Shifting into reverse is wierd
- 1998 Neon SOHC Rough Idle Stalls
- Turbo help...coolant lines 98 420A DOHC
- engine rebuild problem
- dohc head on a sohc block?
- What's causing this loose shifter, loose front to back
- Motor swapping question?
- Dohc Turbo
- Hp Questions
- Tired of Neon Drivers bashing on Hondas.
- Neon with multitude of problems
- want to go turbo
- Master Rebuild Kits
- parts list...
- 98 sohc neon for sale
- Broken Crank Bolt...
- Passenger Window Replacement
- Where is the fuel pump relay ?
- CHANGED ALTERNATOR, SUDDENLY CAR SMOKES REALLY REALLY BAD WHITE SMOKE!!!HELP!!!!!!!!!!!
- 95 neon electrical short/garage ripoff
- Is it possible?
- Help PLEASE!!!
- oooops
- ATX to MTX I'm New :(
- help needed fast...
- Turbo installed.......now smokin!!
- HELP!
- Removing Shift Knob?
- Advance the look...
- Crankshaft Pulley
- Oil in tailpipe
- engine swapping nightmare
- WTD PCM
- ABS
- 1995 Neon Fuel Pump Replacement
- Need some guidance.
- some tube???
- turbo line hookup
- Power Steering
- Question
- Engine Oil Cooler
- Shift Cable bushings
- chopped shifter????
- Neon Sensor and Part Locations
- Severe Hesitation - no CEL codes
- PCMs: SOHC to DOHC? Worth it?
- Scan code P0601???
- -Head & Tranny Q-
- spark timing and cam timing
- Brake problem
- oil puddle under my car
- Question
- My 97 Dodge Neon Tie Rod
- piston question
- dohc engine
- And that was it...
- 1996 Dodge Neon Problems
- Plymouth Vs. Dodge width...
- bigger brakes
- throttle body Q
- got my turbo today!!!
- kyb gr2
- Help! Something is Wrong!
- two disapointments
- help please....
- cam sensor code problem please help!!!!
- short shifter
- o2 Sensor
- bolt-ons????
- turbo help
- Howell Automotive
- Power Lock Question
- Help!
- 3.0l intake filter
- o2 and Converter
- O2 Sensor
- Brake Master Cyl.
- Interior Part Interchangeability
- 98 ACR racing SRT-10
- would this be a quick temp. fix?
- door fixin question????
- The Tao of the Neon
- srt-4 seats
- Couple questions??? please help!?!?!?
- got a new toy today!!!!
- lash adjusters
- i think i know the answer to this question....
- Horn
- Rear Seats
- driving slow, motor dies
- Dynomax Exhaust
- AC
- Motor mount issue
- in my 99 r/tsrt-4 swap ??????????
- 98 neon, EGR problems
- motor mounts
- Random Vacuum line on passenger side...
- rim question
- Overheated and then ??
- Code 45????
- another engine question sry...
- cam question
- guage instalation problems
- Wheel Noise
- o2 sensor question
- head gasket
- V8
- 3.8 from a windstar..hmm...
- cluster problems
- Tachometer Install Problem...
- TB at last
- '97 Neon cooling fan problems
- Which fuse/relay
- NOS
- Is This Safe (or Practical)?
- 96 Plymouth Neon FS
- Can u swap...
- Sad day on wednesday...
- AIT sensor
- the unthinkable happend
- old turbos
- Tranny????????
- Needing help
- need some info
- popping in exhaust
- supercharge quiston
- engine noise??
- 97 dohc for sale
- trouble shoot
- Leaking
- My new whip!
- 96 neon trans
- fuel and rpms
- Engine Rebuild question...
- 98 R/T wont start on its own.
- question and a lesson
- click, click, click ... and nothing
- Header
- euros vs. altezza
