View Full Version : 1st Gen Neon
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. Need Engine Wiring Harness for 95 Neon DOHC
  2. blew a timing belt
  3. asking before paying for it
  4. Window
  5. Heater Cores are...
  6. New to me 99 expresso, mods?
  7. trans problems
  8. Radio--Electronics
  9. any ideas? on cruise control
  10. 225/50/17 work?
  11. painting
  12. Keyless entry on neon
  13. horn help
  14. has any one ever?
  15. buildin a stroker could use some advice
  16. parting out the neon
  17. where can i mount my 3.5" speakers
  18. found a
  19. small problem....help me out
  20. VSS swapping???
  21. Possible problem?
  22. know what is wrong?
  23. Extremists Anyone?
  24. Painted intake manifold
  25. think i found the problem
  26. header
  27. Clutch question
  28. battery relocation question
  29. does any one on here ...
  30. kickdown switch
  31. Anyone?
  32. I can't believe it's this hard
  33. lifting my neon
  34. torque converter circuit
  35. im looking for a set of 2 or 4
  36. oil/fuel mix in intake
  37. does any 1?
  38. would a fuse pump relay
  39. Throw-Out Bearing
  40. burnt hose problem
  41. Maybe Clutch, Not sure!!! :(
  42. how i made my short shift
  43. anyone know where i can find this?
  44. Help ASAP!!!
  45. any one have a 3.0 intake?
  46. Where do i find?
  47. downstream O2 sensor
  48. 3.0 intake!!!!
  49. fuse problems maybe
  50. should i pick it up?
  51. carbon-fiber hood for sale
  52. Clutch cable help
  53. any one have a?
  54. Dodge neon vs Plymouth Neon?
  55. how much?
  56. Seafoam help please
  57. Help?
  58. Struts?
  59. Interior design 4 dr
  60. Change from 4 bolt to 5 bolt tire pattern
  61. Clutch Question
  62. regular neon tranny with srt engine
  63. Ode to Neon
  64. '98 Tail Light Socket
  65. new fuel rail
  66. Car Overheats When On Hills
  67. Anyone have a...
  68. steering wheel swap
  69. How to turbo your neon....
  70. I want a 13 sec neon
  71. Wire unplug
  72. gas mpg
  73. Intake and exhaust cam?
  74. whats different?
  75. Running into probs....
  76. Yay!!!
  77. Got it running!
  78. Help, I'm an idiot :)
  79. 1995 sohc to dohc questions. please read
  80. Engine Swap ?
  81. what size ?
  82. a little help?
  83. pcm plugs
  84. where can i find this?
  85. Persistant break squeek
  86. neon camshaft
  87. $600...to much?
  88. 1995 Automatic to Manual Swap
  89. Got a lil problem (hard to explain)
  90. finally !fixed?
  91. high volume oil pump?
  92. 95 dodge neon 2.0 engine swap help
  93. Getting a neon again! (I hope)
  94. Quick question
  95. sohc to dohc
  96. Another A/C Blower Motor Problem
  97. Crazy Idle
  98. Been a While...decided to bring her back to life :)
  99. Bottom End Specs?
  100. Troubleshooting my idle problem
  101. Need Help with Tach Instalation
  102. 1000cc injectors...only 3 work?!?!Help
  103. question?
  104. Idle is all messed up
  105. could a bad wheel bearing...
  106. gauge clustor problem
  107. Damit!!! Exploded axle
  108. Timing Belt Intimidation
  109. anyone have a udp forsale cheap?!
  110. is this normal???
  111. 2.4 last minute questions.
  112. Back fires when starting out in 1st
  113. Rough Idle & Hard to Start? HELP!!!!!
  114. DOHC swap
  115. 2.4 egr with or without
  116. MTX Redux Part II
  117. #3 cylinder lean condition.
  118. Road Race cam timing suggestions
  119. more details on tranny swap...
  120. Need 99 R/T door panel blue driver side
  121. got bored this evening
  122. egr blocked off
  123. misfire
  124. cam question.
  125. Proper oil....
  126. 1999 Neon grinds in second gear....
  127. Emergency Fuel Cut Off Switch
  128. lifter tick
  129. EGR Valve
  130. How to paint a car...
  131. sucked up some water.....
  132. iat sensor
  133. just got a 95 neon SOHC need some advise
  134. paint job questions
  135. 97 & newer connector pinouts
  136. compression?
  137. another question
  138. 98 2dr Door Panels
  139. Clutch Help ASAP Please
  140. PT Cruiser to neon swap
  141. need advice
  142. Blowin' fuel pump fuses
  143. question
  144. Code 51 woes-96 Neon 2.0 SOHC ATX
  145. 5-Speed Cables
  146. 1st gen valve cover
  147. when you turn your key off ,what shuts the engine off?
  148. Body questions
  149. Dodge Neon 98 SOHC
  150. Question to my Neon Experts
  151. Calling All DOHC Experts
  152. which one?
  153. random missfire
  154. 95 neon fuel filter leak
  155. which cam should i get?
  156. headlight adjustment?
  157. srt4 seats
  158. afr's and boost prob
  159. Shopping for a Neon.
  160. 2nd gen center console- will it work?
  161. Sohc, He351cw, 1000cc, got boost?
  162. Lip kit
  163. question?
  164. should i ?
  165. code=random missfire and car stalls
  166. head bolts
  167. Not familar with dodges.
  168. Oil Pressure Light
  169. tranny swap(updated)
  170. Im ****ing done with neons...
  171. Need help ASAP please!!!!
  172. battery fuse
  173. I need help with my Neon money pit.
  174. 2.4 engine swap
  175. DOHC swap to SOHC
  176. Got my neon running again!!!!!!!!!!
  177. question
  178. urgent help please..
  179. tech
  180. Intermittant speedometer
  181. gas milage ques.
  182. I need an engine
  183. '96 Neon charging light and battery discharge
  184. Back brakes creak no matter WHAT I do, help...
  185. dohc tranny swap
  186. radiator fans
  187. 99 r/t engine swap
  188. i am in need of
  189. Horn won't blow
  190. chrome grille for 95 neon
  191. Interior painting...?
  192. 95 Neon Speedo Trouble!?!? HELP HELP HELP!!!
  193. any 1 know y?
  194. steering/signal issue!
  195. Failed inspection
  196. Silent engine
  197. Please someone help me out
  198. how are you...
  199. overhead monitor
  200. does any1 know
  201. Short Throw Shifter
  202. Bad Rings @ 104K?? Is this common?
  203. Turbo Installation
  204. depos
  205. yellow shtuff
  206. Dodge neon '99
  207. what should i do?
  208. Dad in need of some help
  209. Need some input
  210. stock fuel regulator and begi rrfpr
  211. racing seats
  212. 99 dodge neon
  213. fan problems
  214. opinions please
  215. need some help on finding somethings
  216. 95 head fit a 96?
  217. for sale make offer+ shipping and its yours...
  218. parts wanted for 98 neon
  219. alternator woes
  220. all motor setup questions
  221. Problem wiyh my 97 neon
  222. Struts and stuff
  223. Highway hesitation
  224. 98 ACR Won't start...It's complicated please help!
  225. does anyone know anything about NINJA style body kits?
  226. radiator part numbers! ATX and MTX
  227. junkyard radiators.
  228. Selling:98 Dohc Mopar Performance Pcm
  229. Connecting rods
  230. this is getting annoying
  231. Driver side door latch is stuck
  232. 1st gen turbo or SRT swap-I need one
  233. rear brake self adjusters
  234. headlights
  235. Question
  236. how to run powerwire
  237. my car $400
  238. Radiator Fan Not Working
  239. any 1
  240. Fuel Pump Fuse/ piston rings
  241. Camshaft installation
  242. neon atx vs. caravan atx
  243. just to be clear??
  244. wheels
  245. Turbo Question, need answer asap
  246. think it will fit?
  247. replacement engine
  248. blowing ignition feed fuse neon number 10
  249. unanswerable or what
  250. how hard is it to..
