View Full Version : 1st Gen Neon
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
  1. Need camshaft help
  2. 1997 Neon will not fire!!!
  3. turbo build
  4. ebay springs
  5. Why must some people Rice out their neons?
  6. put my neon up for sale
  7. 10.5:1 comp with nitrous
  8. Shift limits?
  9. FYI on water leaking into a trunk of a Neon
  10. Adding a rear sway bar
  11. Adding a Cruise Control to my car
  12. Rebuilding my 2.0
  13. Car Alarm
  14. Front End Issues
  15. 96 dodge neon wont start - need help!
  16. trans cooler?
  17. throttle swap
  18. 96 Dodge neon Project
  19. car is for sale!
  20. Fuel fillter neck issues
  21. Dohc Cam Id Question
  22. 99 plymouth cranks but wont start
  23. rough idle sometimes
  24. Megasquirt wire harness
  25. Help - 95 neon sohc idle RPM
  26. extra fuel injector in egr inlet hole??
  27. Rhd
  28. Want to buy clutch
  29. Just great!
  30. top End Swap Questions-Dohc back to Sohc
  31. needed fuel filler tube
  32. Finally some pics of my car
  33. Larger cam/Injectors?
  34. Turbo questons
  35. How can I tell if a car has the "Competition" package?
  36. Dodge Neon PCM
  37. My Neon
  38. Water/methanol injection!
  39. Post your pic/mods
  40. ohio
  41. Car dies when I press in cluch over 2k RPM
  42. Fuel-rail thread size?
  43. Auto transmission linkage problems. Shifter won't shift
  44. Sitting in there running one minute, dead the next!!
  45. still idleing high
  46. 97 neon is it my Engine or Tranny going???
  47. anyone selling lowering springs?
  48. Huge dilema
  49. 2.4 top to 2.0 bottom?
  50. CEL codes 12, and 37
  51. Coal Canister is making the engine lighit
  52. transmission shift cable.
  53. dohc header on sohc?
  54. Purge valve solenoid and park neutral switch help
  55. OBX-R Exhaust ?
  56. Cranks but won't start and a code 54!!
  57. 4 lug to 5 lug?
  58. Video of Neons.
  59. please head question
  60. 95 neon motor swap need help
  61. 95 Neon driving problems
  62. 96 Neon No Start
  63. Need help reading a "bad" cluster guage.
  64. changing out heads
  65. Neon '95 Problem. Possible Coil/Fuel Pump Problem
  66. changing rear struts
  67. 99 neon overheating
  68. lambo hinges for sale
  69. auto transmission sticking in 2nd gear
  70. 98 neon rt idles funny
  71. I think it's running lean.
  72. Throttle Bodies?
  73. 95-99 front lip spoiler
  74. 1995 2.0 SOHC engine swap question
  75. Neon Transmission Help
  76. heyqwell
  77. Gauge Clusters
  78. new here, looking for some good knowledge
  79. looking for a 95-99
  80. Shifter shifts but nothing happens
  81. instrument panel problems
  82. 95 cam in a 97
  83. 96 Dodge Neon - No Spark, No Start
  84. Hit deer good idle poor acceleration 98 SOHC weird plug burn
  85. Used 1995 Instrument Guage Cluster
  86. srt 4 dash
  87. ok made up
  88. Iportant Questions please help
  89. Coil pack question...
  90. DOHC and SOHC heads
  91. 2003 neon motor
  92. no 1 would see this
  93. Will a 2.4 from a 03 pt fit in a 96 neon?
  94. Vehicle Speed Sensor - what is it good for?
  95. Fuel gauge prob.
  96. EXPORT euro tails 4 sale 1st gen
  97. 1998 dodge neon, bettery light came on
  98. engine code
  99. question about 3.0 cold air setup
  100. Neon 1998: Engine light on due to radiator fan not coming on
  101. Running hot
  102. How to replace a thermometer on a 1998 Dodge Neon with a 2.0L SOHC engine?
  103. srt-4 seats
  104. Trans question
  105. Engine Harness?
  106. 97 neon dohc overheating?
  107. Nuts to me! New Issue! Battery Temp Sensor busted!
  108. turn signal issue
  109. 97 DOHC starting issues
  110. Starter and Fuel Pump
  111. clock spring
  112. maybe water pump?
  113. 97 Neon Sport!!
  114. 95 neon ECM?
  115. <~~~help needed~~~>
  116. Battery Light is on
  117. Trouble codes
  118. No start head banging
  119. Car Will Not Start
  120. nean mud flaps
  121. 95 ATX Part out
  122. oil blowing out air filter
  123. Wiring
  124. Projector Headlights Up For Trade!!!!!!!!!
  125. Water getting on the floor
  126. Wont crank after engine install.
  127. Defroster-No air-new owner
  128. What is this?
  129. DOHC swap need help
  130. Manual Transmission + shifting problem
  131. Hard Starting Neon
  132. o2 sensor problem?
  133. shifter problems
  134. Coolant Temperature Sensor
  135. 1996 neon spring rate
  136. Engine Swap
  137. switchblade key...
  138. window motor
  139. A little info please
  140. PCM, Auto Shutdown Relay (ASD), or something else.
  141. Selling my turbo neon Dubuque Iowa
  142. 1995 pcm
  143. aNdRo_LiKe_wHoA just sayin Hello!
  144. nc neons
  145. i have a brain teazer
  146. 1996 Neon need some answers please
  147. Trouble code po122
  148. New to the Forum
  149. 98 Dodge Neon Stumbles and Surges
  150. car chuggings and stalling problems
  151. best place/price for fuel pump
  152. brakes sticking on
  153. Leaking under the dash on passenger side
  154. 99 neon dohc ticking at start up
  155. front end problems
  156. Overheating new rad?
  157. Lower Class Club
  158. Stock stereo ?'s
  159. fried wires.
  160. 3.94 trans and dohc computer
  161. Projector headlight question
  162. Thinking about changing out struts and shocks
  163. Has anyone installed Dynamat in their ride?
  164. 99neon starts then stalls in morning?
  165. Answer this please
  166. Please
  167. made the coolest exhaust
  168. Need to locate
  169. no spark, no fuel..
  170. redbook?
  171. When I brake my headlights turn on and dash lights up
  172. look what i found!!! bkr9eix's
  173. 1996 Neon Check Engine Light P0171
  174. my 2.4 is detonating (spark knock)
  175. timing and other problems
  176. body improvements
  177. Exhaust question !!
  178. would running too lean cause me to blow the head gasket
  179. 95 neon dies when braking at stop light.
  180. How to test oil switch?
  181. modded my fuel canister. lmk wat u think. pics
  182. 95 plymouth neon with just fixed now sensor trouble
  183. Part out
  184. turn signal switch
  185. Bigger Chrysler Injectors??
  186. manual trans in stratus/sebring?
  187. will this fmu work for the spool boy mod???
  188. p0203, p0132, p0134
  189. Chatroom?
  190. Swapping cams??
  191. dumb question
  192. heres a good one for you guys...
  193. tranny question
  194. i know this is the neon forum but...
  195. Odd Problem??
  196. 4sale in ATL
  197. Figuring out piston ring size..
  198. Bent rod
  199. Mattdog adapter
  200. stupid question but hard to answer
  201. run fuel return line through the evap hard line?
  202. run fuel return line through the evap hard line?
  203. run fuel return line through the evap hard line?
  204. rear lip
  205. what cars come stock with a 58 psi fpr
  206. compression
  207. Interior lights
  208. Sticking Calipers - Melting pistons
  209. Getting to expander rings from the bottom?
  210. megasquirt
  211. lot o miles minor problems what should i do
  212. part out or sell whole?
  213. p0743 & p1899
  214. 1998 plymouth neon s.o.h.c need help badd
  215. 98 Neon - Replace or not replace
  216. Code 31
  217. overheat?
  218. Radiator Help!!!
  219. anyone have a wiring diagram for the alternator
  220. Used parts
  221. everyone should switch to the srt oil filter
  222. i made my own solid bobble strut
  223. 97 neon sport issue with guages and belt squeeling with a/c
  224. 1st gen neon collector wheels
  225. odd question!!
  226. a lil off topic
  227. FandSfab.com NOW OPEN. 2.4 power steering brackets!
  228. Low spark on #3....
  229. 98 neon, pinging
  230. I need help with my Dodge Neon
  231. EGR question
  232. fuel pump fuse keeps blowing
  233. 3.55 vs 3.94
  234. Saying hi and showing the new car 56k warning
  235. turbo parts have started comming in
  236. Got a purple 98 sohc
  237. '96 engine rebuild
  238. Question???
  239. Question on diagnosing Knocking
  240. Anyone want a free Mishimoto thermostat?
  241. please help!!!!!!!!!!
  242. *!!! Nightmare OVER !!!*
  243. FS: srt turbo
  244. Wierd idea.
  245. built 2.4L turbo wont run right at all
  246. Daytime Lights Dont Work
  247. 2nd gen short throw shifter in a 1st gen?
  248. 97 Neon sohc Squeeling belt! cant figure out
  249. Fuel filter..
  250. Rotate cam magnet 90 or 180 deg?!?!?!?
