View Full Version : 2nd Gen Neon
- Starter Problems
- turn signal flasher wiring diagram
- 2001 dodge neon squeaking!
- engine wont turn over
- Dodge Neon or Chrysler Neon
- Spraying sound while running
- Difference between these CAIs?
- Looking for help electrically, 2000 Neon
- 2000 Dodge Neon Clutch Problem
- Water Issues PLEASE HELP
- 2003 Neon AT transmission stuck in second lots of codes :)
- 2001 neon 2.0 sohc compression
- need grille trim....
- cluster
- need some answers
- installing keyless entry in 03 neon sxt
- Help
- '02 Vibrating/Grinding
- Short on Fuse 21 - Please Help
- Parting out 2003 Neon SXT!!
- 2nd gen spoilers
- 2002 Dodge Neon issue
- Loud crunching noise, thud, and now neon wont move forward or backward... HELP?!
- afx pcm
- Shift Knob Question
- transmission cooler or heat sink?
- 2001 neon se with a clunk in the rear.
- 2003 neon horrible mpg- need help
- 2000 neon door will not open
- Please help! Neon Issue with codes and full description of problem
- 2000 neon needs help!!! sputters and dies on acceleration from traffic lights,
- **fault codes-neon**
- Just got a diagnostic, can I get info/tips?
- SXT Manual conversion
- short throw shifter
- 2000 Neon Rear View Mirror Cable Problems
- Gear Shift light bulb
- 2004 Neon vibration prob
- flip flop/ floating hood
- Help! P0340 Cam Sensor Troubles 05 Neon
- 2004 Dodge Neon SXT Help PLEASE!!!
- light weight pullys for 05 neon sxt
- srt-swap
- Power Steering & brakes fail for one min
- Shocks - Damaged/suggestions?
- simple question about a 01 neon. please help.
- 2nd gear grinds
- Test Pipe/ Tail Pipe Issues
- No Fuel
- 2002 Dodge Neon Electrical Help
- Exhaust question. sick of the stock xD
- Radio and Ac fan and Lights and Odometer blanks out
- does anyone have torque specs
- Excited! Need some answers though.. Magnum Intake
- 2003 Won't Crank..
- viper body kit and air bypass valve
- leak detection pump
- Limited Slip Differential
- no power to radio
- looking for a new brain...
- Rough Idle Fix !
- What kind of mileage do you get?
- 2002 atx kickdown?
- power steering pulley
- Battery Light
- no bus 2001 Dodge neon
- Dodge Neon Part Numbers, Maintenance Intervals and Fluid Capacities
- Clear corners in Massachusetts
- Noob!!!
- SRT OEM Strut Bar
- 2005 Neon Backfiring (new PCM)
- bellow tube
- 2005 SX question OBD light
- 04 neon cabin filter
- No start please help!
- Quick-strut problems
- dodge neon transmission, im really cofused. help! brass shavings?
- gas gauge going funky..
- how many motor mounts?
- wont start need help
- General questions about my `03 SXT
- My tranmission went out (03 SXT)
- 00 neon no crank and injectors wont shut off
- 00 Neon not cranking at all
- Installing Pioneer Receiver.. Please Help
- anyone use bosch super+ copper plugs?
- 05 sxt cam sensor problems
- 2001 MT Shift issue
- Immobilizer problem PCM
- a/c lines
- new to car modding
- 2001 neon ULEV catalytic code p420
- 05 Neon getting codes P0016 and P0344 Help!!
- 03' Dodge Neon Turns Over 10 times then starts and Sqeals
- Major problem
- 01 manuel neon R/T
- Hello, there! =) New to modding..
- 02 AT Neon Transmission issues
- Might be joining the ranks...
- hard shuttering
- Random Overheating
- stalls during hard stops.
- p0344 code even after sensor replacement
- car wont start after 4 months of sitting.
- #1 Sluggish Acceleration #2 Grinding from 2nd to 3rd
- megasquirt question
- Sts
- Will these tires fit '03 SXT?? Awesome deal I don't want to pass up
- Wheels and Suspention
- Struts and springs
- rear brake swap
- Can't find my O2 problem
- 2005 sxt ac problem
- Difference in Downpipes?
- O2 sensors
- Timing belt change cost
- what size is the rear axel hub nut on a 2000 neon
- Crank Position Sensor
- engine swapp
- different SOHC/DOHC swap question.
- 2002 Neon R/T Front Bumper Help
- 2005 Dodge Neon Water leak
- air sucking sound
- O2 Sensors
- manifold
- Stock Leather Shifter
- 2000 fuel pump?
- Cheap Ebay mufflers any good?
- 2004 dodge neon
- 05 sxt shooting p0513 trouble code
- Crankshaft sensor location.
- i know its common but plz help i went thur three pages if post
- idle help
- caliper problem
- 2 Tries to Start
- 2000 neon hard starting
- 2001 neon 3 speed lock up problems, says fuse in dash as soon as i put it into gear?
- intercooler
- 01 Neon, Won't start Red round Security lite is on
- 2003 SXT - water leak?
- 2001 Neon
- megan drop springs
- Front emblem loose. How to tighten?
- New taillights =]
- 2001 Neon non-functioning Air Conditioner
- Lowering Springs
- Ongoing issue
- Seafoam, vac lines, opinions please.
- ASAP Help With IAC!
- I think im really screwed now
- oil soaked plugs
- Heads 1st & 2nd Gen
- New lug nuts?
- Timing Belt and Water Pump
- Folding Mirrors?
- Strut tower bars: Opinions please
- 02 neon help
- srt exhaust fit on sxt no problem?
- rt tranny
- 2005 Cruise control
- Thoughts on a topic within a diff. forum
- '05 SX2.0 (neon) misfires only at idle
- 2004 SX Tans Swap**
- Interior problems
- neon hesitation
- Missing Front Lip
- 2000 neon won't downshift
- Need Direction with Dead Engine
- Fade/Treble Knobs
- belt tensioner/pulley
- Camshaft
- Part #'s for Neon & SRT's along with Paint codes
- looking 4 a exhaust system
- 2nd Gen Neon Parts Manuals
- Key comes out with car on
- security system light
- PlLEASE HELP Tire Size
- SRT4s any more reliable?
- air fuel ratio gauge
- exhaust???
- Before i get neck deep
- Rough Idle and other problems
- 05 neutral safety switch
- 2005 Dodge Neon stalling problem
- Axle Damage
- speedo question
- Need any advice.
- debating whether to get these or not whats yalls opinion????
- I'm at a loss here :-(
- Front exterior door handle sticks out after opening
- srt4 speedo into sxt
- Different clutches
- Front Subframe failure
- Do you have to change spings with struts?
- Front suspension and camber advice wanted
- Stock sway bar end link has no washer & nut?
- 01 dodge neon problems
- dodge logo style letters
- Stabilizer Bar Questions...
- 2003 Dodge Neon Oil Pressure Sensor Torque?
- removing automatic shifter
- 02 neon ALMOST stalling at light
- repeat cyl 1 misfire
- 2003 neon SE strut and spring time to replace?
- noise from intake??
- 2001 died while driving
- trans fluid question
- 2001 with some cel codes
- 2001 neon
- Factory Cd Changer
- Ebay volt dual exhaust
- O2 Sensor Or Other Possibility Question....
- dropping oil pan
- oil debate
- Power steering help
- Fuse 21/ASR keep blowing! WTF?
- 2000 Dodge Neon Clutch Problems
- 2000 Neon Fuel Problem
- 2000 Dodge Neon Fuse 16 keeps blowing
- 2001 Dodge Neon Transmission Issue?
- Mopar Lip Kit
- oil pump seal leak
- Need some info on body kits
- plug wire questions
- Priorities-
- P0743 after PCM replacement
- Parts for 2k
- 2004 Dodge Neon Sxt Flooding out Help.
- Engine Swap
- MSD coil pack, worth it? Opinions please!
- Buying a used Neon? What to look for...
- my new neon and its problems! HELP!
- Spark plug change
- Expensive repairs - question
- throttle response
- SRT bumper cover question ??
- Looking at buying a 2005, what to look for?
- neon es engine rebuild need advice
- MOPAR Lip kit ...
- Looking for tips on door replacement
- P1607 engine code
- Installing a CAI .... quick question ....
- OBD-II Trouble Codes- What do they mean?
- code question
- Rear wheel bearing.
- Bahamian Neon
- breather filter location
- 03 Neon stuck in Limp Mode> P0700
- Megasquirt
- Not sure what happened to the sxt
