- Mystery Alternator Wire
- transmission slams when down shifting
- Tranny Trouble
- 2003 Neon Trans
- Neon Stalls when Head Lights are turned on
- 2003 neon transmission problem
- 2003 Dodge Neon problem
- Looking..but cant find!
- B18
- 2000 Neon with broken timing belt
- Auto tranny on 2000 help
- Adjustments?
- Blower motor or resistor?
- stumped on cam and crank sensor problems
- Qs about new SXT
- P1776 code help/advice needed
- 2004 neon sxt stalling
- Let's talk "engine mounts"
- new car shopping
- squeaky belt when it rains, whats up?
- New tail lights received today! (question about fuel system cleaner also)
- Automatic transmission problems with 2005 Dodge Neon SE
- oil pump
- dent removal!
- Cold Air Intakes
- Blow off valves
- 2 quick questions!
- cam or header
- Fog light electrical
- Horn problems on an '00 Neon
- engine sounds?
- PLEASE HELP!! Having some Transmission problems
- many, many questions..
- rev limits?
- "Rev Limiter" gone crazy?
- Engine problem!!!!!
- 05 Neon SXT fog light bulb change
- starting problem
- Trouble Codes
- 05 sxt low idle? and shifting?
- 2005 neon sxt 5 spd.
- AC Blower motor resistor switch
- Crankshaft sensor and Camshaft sensor code problems
- 2005 neon timing belt broke.....HELP
- Transmission Stuck
- Alternator Whine
- trans issues
- Shaking when stopped
- How to remove plastic over gauge cluster?
- Steering Column
- turbo
- the big 3
- Changing 02 Sensor in 04 Neon 2.0
- 2003 Neon- Codes P1775 and P0731- AT WIT'S END!
- 5x100 ET35, 215/50/17s - what suspension options?
- My PCM isn't getting signal from my cluster...SPEEDOMETER DOES NOT WORK!!
- Dodge Neon 03 P0344 HELP!!!!
- 2002 Dodge Neon Automatic Transmission Upgrade
- Clutch problem!!
- electric shock
- vacuume leak or pcm
- Got the neon back ftw....
- 03' neon look! Please help?!
- Tunning Advice Please
- Is it the PCM???
- Spark Plugs Question
- 05 SXT Front End Noises
- Flushing the Coolant
- 2005 neon shakes/chokes in drive or reverse?
- Fuse Problem
- HELP! 01' with timing belt toasted!!!!!
- Need help..another hummimg thread ..look inside
- help wiring diagram
- P0340 error code keeps returning.
- computer number match*
- haunted?
- 2ooo Neon trany number
- 2000 Dodge Neon stalls
- Is this safe?
- 05 Neon R/T brakes?
- Symptoms of bad input or output automatic tranny speed sensors 2002 SXT
- Batt thermal wrap
- **NO BUS** error
- Help with Transmission part in picture
- Rear Drum to Disc swap??
- Engine Light On and Off - Car Chugging/Sluggish On and Off
- Transmission Fluid
- SOHC or DOHC?
- Do i need a new motor??
- Please Help 2003 Dodge Neon Overheating!!
- Rear Speaker Question
- cylinder head swap
- Need Help? Bad Pinging and knocking at a stop.
- need parts
- need some help!!!!!!
- Oil Change Question
- 02 Neon overheating (Even after new radiator and thermostat)
- E-Brake
- 2005 sxt dodge neon Intermittent starting
- Need help with leaking fuel line
- 03 SXT: Transmission Shifting Issue (fix or ??)
- RPM drops off while at idle
- 2004 neon noise & missing
- New Guy
- Leaking transmision fluid into the radiator...please help!!
- Still modding
- Low-Beams
- I Need Mopar Lip Kit
- Will it fit?
- Problem w/tranny
- 00 neon sputtered, then shut down and now notthing at all.
- Pics Of My Neon Enjoy
- Dome light won't work and fog lights won't turn OFF on '01 neon?!
- Ground Strap on Negative Batt Cable for 2003 Neon
- SRT carbonfiber hood
- 02 neon sxt, crank but no start
- Turbo Kit Question
- Looking to upgrade headlights
- 05 neon sxt
- 2003 neon sxt...a little help please!!
- big engine problems
- Radiator fan/relay went out
- 2000 Tranny
- help - foglights
- Showsxts makeover thread!
- 2003 sxt
- Best way to remove harmonica balancer...
- Please Help Me!!
- Grant 5 Hole Steering Wheel To 6 hole ??
- neon stalling random and not restarting
- 2000 air intake
- Motor problems
- 05 Neon Steering wheel size
- 2003 Neon SXT- Engine/Trans Interchange Question
- weird noise on front wheels
- need fender and bumper cover 05 SXT
- Oil pressure light!!
- A/C Question.. No Clue who's right
- New to the Forum
- Help with a sensor!
- Gas leak at hose/connector
- 01 neon wont start
- 41te transmission compatibility?
- has anyone used a volo chip
- Engine cleaner..
- Transmission band adjustment
- hydraulic clutch issues 04 sxt 5 speed
- 2004 SXT OEM Headlight Assembly Replacement
- Neon motor mounts
- Local Dodge dealer asking $9995 for a 04 sxt?
- Trans cooler?
- tranny fittment years???
- 2005 Dodge Neon SXT
- What are your cars charging at????
- Charging question . Help Please
- Custom Interior
- 2002 Dodge Neon Help
- Couple of problems, NEED HELP & Don't know what to do!
- Oil Consumption
- Cluster replacement
- Gauges eratic at startup
- Torque Strut adjustment
- If you own a 2000 or so manual
- URGENT HELP NEEDED: Car Stalled after T-Belt Install
- Oil change update
- Wiring problem..
- Best RPM to shift at???
- 2005 neon no start..not common
- Updated my ride!
- How to adjust hood latch?
- AC stopped working...help diagnose?
- 03 neon auto tranny woe's!!!
- Help Installing an Aftermarket Tach!!!
- Car pulls to the right under light acceleration automatic
- 03 neon sheetmetal
- Anyone parting out a Neon?
- Rough Idling & Engine Almost Dying
- POWER to A/C Compressor Clutch
- Timing Belt
- Manifolds?
- Well my sxt might be a toast!
- Aligiment after replacing struts?
- Pictures !!
- 2003 Neon speedometer and tach problems
- Won't Start - NEED HELP! - 2000
- Compressor Connections 03 neon
- Racing chips?
- 03 SXT hood fitment years??
- 2005 Neon sxt EXHAUST???
- Misfire!
- 2002 SXT auto tranny has no go...codes are...
- motor mount support bolt broke off in block
- MPG update
- engine lacking power on takeoff
- I'm trying to help someone jilted on Craigslist
- Gas smell -- help me identify this part
- For SALE!!
- Help overheating
- 2001 neon starts and shuts off
- K&N 69 Series "Typhoon" Intake
- Power Steering Hose Leak
- oil pressure!!!
- Hit a damn deer.
- srt engine swap/ turbo
- Oil change
- RPM Issue
- alternator
- Neon vs. Grand Marquis
- 04' Neon Missing When A/C is running
- Niece's car - P0443 and P0499
- Neon '04 "Jumping" Problem
- I really like my Neon!
- Bad fuel pump or just the regulator?
- ALL you A/C Experts
- Mystery Issue - 2004 Neon
- 00 Neon backfiring at 60mph
- 2003 Dodge neon check engine light
- Draining Coolant?? 2000 Neon
- Tranny issue
- Suspension...
- will this fit
- where to find?
- Headlight Assembly
- Random Starting issues
- R/T manifold
- Another Electrical issue
- Unexplained Vibrating.....
- Oil Problem!!!
- New Clunk noise coming from left rear.
- 2000 neon key Ignition
- ambient air temp or intake air temp
- 2003 Neon Transmission swap Auto
- a/c lines
- who's dumber?...
- T3/T4 Turbo kit for neon??
- Megasquirt installation on 04 Neon 2.0
- Wtf now??
- timing belt
- Personal Invitation for 2nd gen TOTM voting!
- 2005 2.0L SE - P0499 error code questions
- Car alarm how to disable !
- Code 171
- AC problem, need HELP!
- Bumper cover
- need help with obd2 code..
- Finally found my clunk noise
- '03 neon making me SHATTERED..plz help!
- New battery
- Need a 2nd key.
- Any interest in mopar lip kit?
