View Full Version : 2nd Gen Neon
- website
- Throttle body and tps
- HELP! Getting a P0340 code (CPS), timing belt??
- Anyone else have this problem?
- Auto door locks not working
- tans problem
- Neon all-in-one chip keyed fob *l@@k*
- Air/Fuel Ratio Guage???
- Studder or hesitation from a stop
- totaled red srt-4 $1000
- 02 Sxt neon Fuel light ?
- help plz
- Side skirts
- 1st gen mirrors on 2nd gen.
- different but need help
- Problem with neon 2002
- AC
- Boost gauge in SXT
- Engine Load
- Possi Power Steering Circuit Failure
- 2000 dodge neon turbo help?
- Stock radio needed.
- how to fit bigger rims on car
- K&N air filter
- windshield washer fluid pump failure
- 2003 SXT issue
- crankshaft position sensor
- help with accordian air tube
- Removing Rear Hub
- Dying in wet weather...?
- Oil in intake manifold and spark plug Wells
- Help??
- fog light
- weird problem
- Speedo/gov problem
- New here
- Completely O/T...about the new smilies.
- 02 Sxt 2.0 head Replacement? SOO CONFUSED
- Previous owner/Car Lot
- thinking about geting an srt4
- 2005 Neon SXT, wire comes loose, triggers code, owner perplexed.
- Manual transmission swap
- Chrome Handles!
- SRT Exhaust
- hydraulic clutch in a 2000 possible?
- How can you test the CV joints to tell if they are good.
- How much are the AC condensers supposed to leak on these bad boys?
- Would P195/60R/15 tires fit on my 2004 SXT?
- i wonder what people think when they see me weaving in a neon lmao..
- Sunroof cables?? HELP!!!
- An invite to 3rd Gen. TOTM!!
- Cruise control vacuum routing diagram
- Help with My Neon RACE CAR No Start 00 to a 01 RT
- P0441 EVAP code. 03 Neon. Help Please!
- speedometer problems
- Now it's louder..hehe
- tire help
- Turn Signal Buzzing
- Help with My Neon No Start
- Neon Sxt is Dying on Me!!! NEED HELP
- engine psi
- Door panels
- Question about rack and pinion (maybe)
- Need your help...
- Crankshaft harmonic balancer pulley
- 2002 Neon. Serpentine belt tensioner pulley
- Timing Belt change procedure... 2002 Neon
- Engine splash shield
- knocking/clunk when braking
- Present Day Neon
- Help My engine and tranny wont turn.
- interior fuse box diagram
- where can i find buttons and knobs at?
- Rear break cylinder question!
- Taught it was this,then i taught it was that.(grinding whirring noise)
- Trunk Lock
- Does anyone know..
- odd electrical issue, e-brake warning light...
- Best Halo lights for an 04 Neon??
- Have you guys changed your timing belt/water pump?
- 2000 neon jumps at take off from red light
- '04 SXT will not crank
- 2000 Neon NO SPARK
- 04 sxt Overheating
- 3 speed automatic?
- Motor mounts
- Buying advice
- Neon performance potential
- RTV curing time before trans fluid fill???
- Help asap
- Strange A/C issue
- HOW-TO!!! How to change your struts
- no interior lights.....
- flipping Radio & Climate Controls
- Halo headlights w/ LEDS install questions
- Transmission Flush, car 115,200 miles
- 05 neon. low rpm
- Keyless Entry Going Haywire
- A little help locating the tech/DIY articles, please?
- 2003 neon vibration- need help please
- mopar or mopad?
- peice of crap
- Noisy and no heat.....
- Magnetic oil drain plug?
- 2001 Neon alarm going off after sitting.
- cams
- My Ride : )
- High (Accelerating) idle
- 2005 dodge neon front noise???
- Ba- bye
- 2004 SXT noise at startup and idle
- Rear Sway and Cat-back Exhaust
- '02 Neon front wheel bearings
- Sad Realization
- Looking @ an '04 SXT - Chattering Noise + Other Questions
- Look at my car :)
- Dodge neon transition form hubcaps to alloy wheels
- 05' Neon - Code P0301 - No Compression - Still confused!
- 05 Sx 2.0 firing misses??
- 2005 Dodge Neon (SXT)+tokico illumina struts
- some help with remote
- 2.0L to a 2.0L HO
- new to the forum
- Replacement complete headlight assemblies info needed.
- radiator replacment help.
- Need HELP BAD
- tcm help
- 2000 Neon Parts car
- Washer fluid reservoir replacement
- getting f-1 fenders, maybe.
- Wheel sizes..
- Magnum Head for Neon?
- Max wheel size for 01 plymouth neon?
- vacuum gauge problem
- 2004 sxt help
- 2004 sxt help
- new drop springs now bumpy ride
- Trans fluid, filter, band adjustment ?
- driver tail light not working, with a catch
- Check Engine Light
- fuel pump spring
- Mini digital Tach Installation
- 2003 Neon with Auto trans problem
- 2004 SXT trunk problem??
- First Wash and Wax for 2010
- car wont start
- What do you think of my neon?
- Changing my plugs, socket wont fit!
- 02 neon coolant leak?? help!! :)
- Maintenance for longevity
- Dodge Neon Basic Maintenance Parts- Part Number List
- SRT 4 Rear Section?
- Wanted srt4 Exhaust.
- 03 Tranny not shifting.....sometimes
- After replacing a dead battery my radio does not work.
- will an 05 srt4 hood fit?
- Woot, I have begun the transofrmation.
- Brakes sticking!
- Shifter/lights wire assembly help love of god help
- 2002 dodge neon 2.0l tcm problem???
- only one spark **** PLEASE HELP ME*****
- one sizes fits most?
- serious vibration
- Help finding fuse controlling gauge lights and rear taillights!!!
- Transmission Maybe???
- swap newer style nose
- New exhaust manifold, fuel options?
- NGK spark plug!!! Vs?
- '03 SXT ATX Torque Converter lock-unlock...
- 03 dodge noen 6 cd player
- Fuse warning
- Just a few questions
- BRAKE light coming on and off on the cluster
- What does it mean when...
- Maintence..
- FS: Car Cover (Covercraft Technalon Evolution)
- Im new but need help from someone that knows a lil bit about springs and shocks
- Looking to get a neon...some questions
- 01 Front bumper removal. Please help.
- cluster swap
- a little help
- srt 4 swap
- Headlight Housing Replacement?
- Can replacing an automatic transmission be that difficult?
- 2001 Dodge Neon Power Steering Belt Doesn't Stay On
- new motor clicking
- 03 neon Tranny not engaging on first startup
- question?
- 02 neon wont start
- remove emblems and trim
- 2003 Dodge Neon sxt po1687, po1681, and po462
- help with P0508
- 2005 Neon and MSD Issues
- Suspension Clunk and Parking brake adjustment cable?
- Dashboard buzz/vibration & suspension clunk
- Motor Swap ?????'s
- strange sound..?
- Electrical Problem 2000 Neon
- Throttle Body for 2000 Dodge Neon
- error p0344
- CD Changer
- First Major Problem (maybe)
- WTH hell is the PCM/ECU fuse?
- help '03 neon sxt
- Clunk/Jump When Slowing to 1,000RPM
- 2003 Blinker Shorting?
- need help asap (parking lights not working)
- Instrument Cluster Question!
- Overheating overflow boiling help!
- New Owner mod help
- Catback Ex from E-bay
- How to attach remote starter to solenoid
- camshaft questions.
- valve body/Shift Linkage Shaft issue..
- Check Engine Light comes on and cruise control quits working???
- Spoilers?
- 05 neon with 0340 engine code
- Buying an 02' Neon
- Help!....i need some advice
- 03 neon r/t please help
- 2003 Dodge SX
- Loose shifting
- My car with pics
- Clutch Replacement Advice
- clutch fluid reservoir
- Where is the crankshaft sensor
- 2001 dodge neon deck?
- 02 Sxt neon (chip keys & fobs)
- 2nd Battery... dead.
- Tune up suggestions....
- 2004 srt neon
- Exhaust question
- Ac lines frozen. Help?
- '04 hits 2000rpm and starts sputtering - engine light on
- 05 Neon Fuel prime problem
- Suggest Some Neon Mods!
- coyle and spark plug set up
- info anyone??
- Bad Battery Wires and lots of Vibration. HELP....
- px3 performance chip
- under drive pulleys makes ur car stall?
- Part needed
- Deal couldn't fix my Air/Fuel fault (engine light)!
- Tranny Issues
- belt tensioner
- 2003 Neon bucking/jerking after getting gas and more..
- put on an after market header and down pipe
- Transmission swap question
- '04 Neon Problems
- Timing belt to Timing chain?
