PDA
View Full Version : 2nd Gen Neon
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
  1. 02 SXT Performance
  2. Just bought a 2000 neno
  3. o2 sensor question??? 2001 RT Neon
  4. Error Code P0340 Help
  5. 2003 SXT leaks and gas meter reading
  6. booger bushings
  7. Transmission Problem?
  8. How to replace Alternator
  9. srt4 exhaust
  10. Looking to turbo my 2004 Dodge Neon SXT! Help!
  11. Altenator
  12. ignition cylinder change
  13. how to reset engine light?
  14. Engine Swap
  15. 2004 Neon Trans issue
  16. Horrid creaking sound on left turns...
  17. tune up
  18. So I've been curious.
  19. 2004 Neon front suspension clunk
  20. Bought new magnaflow exhaust
  21. New girl from Baltimore
  22. 2001 Neon Bumper fitting
  23. Neon backfires and has no power
  24. Lost in Transmission: Speed sensor pinion gear
  25. Red Oil Light flashes on my 2004 Neon SXT
  26. neutral safety switch
  27. Temperature gauge Problem
  28. Rattling E-brake driving me nuts!
  29. Motor Mount is breaking
  30. Cold air intake filter fell off!
  31. 05 Neon wont idle??
  32. Please HELP... P0601 PCM code questions
  33. How do I disable DRL on 2005 Dodge Neon?
  34. Over Cooling
  35. 2003 sxt 2.0 overheating/no heat
  36. SRT4 head on 2.0 block?
  37. cold starting problem
  38. Exhaust leak
  39. Srt 4 rims ??
  40. New with a problem
  41. srt 4 eye lids
  42. Cataltyc Converter question
  43. Eneed bumper..
  44. Srt 4 Map sensor
  45. cold knock revisited
  46. Heater core leak
  47. Tallest Tires That Fit ?
  48. sparkplug with oil
  49. 2005 Neon Auto Shutdown Relay
  50. 2000 Neon Engine Stuttering
  51. header and undercrank pulley for the neon
  52. cam position sensor (code P0340) questions...
  53. 2000 dodge neon brakes
  54. Brake and Antilock Stay on After Gauge Swap
  55. 2002 Neon Engine "Chirp" at Idle
  56. fog lights!
  57. code P 0137 no idea.
  58. what do you guys think?
  59. need help
  60. Rear Wheel Spindle Nut
  61. Fog lights and dome light
  62. havent been on in awhile
  63. Neon 04 sxt auto - transmission/coolant flush
  64. Need a stock 2nd Gen exhaust
  65. Brakes are making a funny noise...please help!!!
  66. Popping/clicking clutch pedal
  67. electrical/fuel pump problem/fuses
  68. vapor canister and purge solenoid
  69. 2003 Dodge Neon SXT 2.0
  70. When i am going down a hill on incline , my brakes make a funny noise???
  71. Swap in 2004 motor in 2001 car
  72. RPMs...
  73. halo headlights
  74. Upgrade Suggestions?
  75. What is this thing on right side of engine where oil is leaking?
  76. Dodge 2003 SXT Bad Mileage per Gallon(MPG)
  77. 2003 Neon Sunvisor Support/Latch Wanted
  78. shifting
  79. Anyone know how to smoke tail lights like this
  80. Need to know of Delphi fuel pump is good quality
  81. NVLD pump
  82. Is it worth it?
  83. 2002 Neon motor mounts + other ?'s
  84. Discount Dodge parts in Pittsburgh
  85. Power steering pressure switch?
  86. first gen for sale
  87. 2003 Neon problems
  88. 03 Neon Crankshaft seal
  89. Camshaft sensor problem
  90. fuel pump or fuel pressure regulator?
  91. Needing parts for my 2003 SE
  92. Parting out my neon
  93. speedometer?
  94. False claim on a catback auction?
  95. 2003 neon sxt evap control problem
  96. a/c issues
  97. engine light and oil light
  98. 2002 Neon Motor Mount Issue
  99. painted 1 gen sport rims
  100. quick question
  101. Hey GUYs Newb here 2001 Neon engine swap
  102. electrical problem
  103. 14" steel wheel valvestem location
  104. Rear drum to disc swap
  105. Foglight fuse keeps blowing!!
  106. 2000 Dodge Neon Glass
  107. Engine light came on and the motor sputtered a little bit when accelerate
  108. Strange fuel issue
  109. 04 Neon SE Magnum R/T intake swap??
  110. Battery power issues?
  111. 2001 Neon: R/T without the magnum engine?
  112. neon noobs axle issue
  113. P0122 (TPS) Issue
  114. 2002 dodge neon complete motor, tranny, harness,cutom turbo
  115. air intake
  116. code 0123 help!!
  117. A quick Shoutout
  118. Alarm/remote start/ keyless entry?
  119. help with motor swap
  120. 2002 Neon squeaking noise from rear left upper strut
  121. Tokico Struts + Rear Sway Bar
  122. Looking for 16" Stock R/T Wheels
  123. Alternator Belt
  124. Coverin a scratch?
  125. lookin for side skirts
  126. Smoke came from steering(lights/signal lever)
  127. Car Hopping
  128. Bright headlight I just replaced
  129. Rear bumper cover help
  130. 2004 Electrical Problem
  131. Fuel Filter replacement
  132. 03 and up headlights on 01?
  133. Trouble with my SX 2.0
  134. Throttle is "hanging"
  135. HELP NEEDED!!! Hella Horn Install
  136. Starting problem?
  137. 01 Dodge neon Throttle/Gas pedal sticking?
  138. 2002 sxt very bad engine or trans vibration
  139. 2001ES computer and Coil pack
  140. headlights 2001 Neon
  141. Parting out 2003 Neon...
  142. Oil in the intake manafold??
  143. sidewall damage.
  144. not very knowledgable
  145. Parting out 2005 Dodge Neon
  146. So I've changed my mind...
  147. 2005 stock SRT-4 exhaust for sale
  148. 2004 Neon Stock speakers
  149. Dodge Neon 03 fuel gauge problem
  150. 2004 neon rear shocks
  151. 2002 Neon Hard down shift
  152. electrical problem - PLEASE help
  153. 2nd gen export tails 4 sale
  154. wires causing interference?
  155. Dodge Neon EURO lights for sale on ebay
  156. HELP!! 05 Neon SXT Trans Leaking and overheating.
  157. darthroush
  158. cylinder head
  159. Which is one is BETTER
  160. P0341 plz help guyz im stumped...
  161. Slipping transmission and leaking coolant
  162. Help with code P2096....
  163. Transmission Noise/Half shaft replacement
  164. need help with head gasket replacement
  165. removing the rear seat back
  166. Blend Door
  167. Picked up another neon...
  168. What can i do with 2001 Neon ES??
  169. 2003 Dodge Neon SXT Total Electrical Failure
  170. Manual transmission swap
  171. Mud Flaps
  172. Hey Everybody
  173. cooling system ?.. thermostat and fans...
  174. Low Fuel Psi Problem
  175. Can somebody please quickly tell me where this grounding strap goes?
  176. need a 5 speed transmision
  177. Timing belt questions for a low mileage 2000 neon
  178. lowering the neon
  179. anyone seen this???(240 mpg)
  180. What other gauges?
  181. Been a long time
  182. Been a long time
  183. ac not blowing as hard
  184. help need tranny for 02
  185. 2001 Timing belt/Water Pump
  186. crank no start p0016
  187. Check engine light!!!
  188. 05 Neon Shifting
  189. detailed stereo installation?
  190. This car is really ticking me off,please help me!
  191. Oil Light ?
  192. water pump leaking... need advise!!!
  193. what all will this engine fit?
  194. 03 Neon SXT basic maintenance/mods
  195. 2.4DOHC swap into my 05 sxt auto...what do i need to make it happen?
  196. 02 transmission problems
  197. Got fuel related problems.
  198. new 2003 neon owner and problems
  199. Neon won't shift?!?!?!?!
  200. New neon owner
  201. brake time!
  202. Side Skirts
  203. removing boots on neon 05
  204. Emergency Brake Frozen
  205. SXT '05 Black Neon Front Bumper...
  206. 2000 Neon Transmission
  207. 03 Neon 2.0L Water Pump Brand Recommendation
  208. Bad vibrations
  209. 01 neon wont start.....HELP!!!!!!!
  210. 2000 Neon keeps tripping fuses
  211. Lower Class Club
  212. ATX trans will not downshift on it's own.
  213. bmw m3 vs, just a neon???
  214. 2002 Neon Rear Brake check
  215. Axle whench size
  216. Brand New Prothane Motor Mount Inserts For Sale! [Street Version]
  217. Parts Interchange info for 2001 Neon PLease
  218. side skirts..
  219. Need help with 2001 ES
  220. 2000 neon fuel pump
  221. OEM Neon Wheels
  222. what the neon looks like
  223. theft alarm light stay on ?......
  224. pcv valve 2000 neon
  225. srt4 instrument cluster
  226. park light bulbs?
  227. How do you take the bumpers off?
  228. Desperate please help with skim module
  229. 2003 SX 2.0 Help and Please tell me I just didn't make a huge mistake
  230. Buying SRT Spoiler! $125!
  231. wistleing every time i step on the gas..
  232. Fah-Ken Kawps
  233. transmission problems
  234. DPredator
  235. ac compressor oil
  236. transmission rebuild kit
  237. 2005 Dodge neon sxt will not start. Lights and everything work good, but when the key
  238. CAI Exploded
  239. Low Brake Pressure
  240. Hardware help!
  241. Easiest/Best way to remove door latch
  242. Let it be quiet again!
  243. 2000 sohc head, anyone have one for sale?
  244. Does my neon have a transmission drain plug?
  245. 2000 dodge neon wont shut off
  246. Vote my dog cute!
  247. Minor problem (please help) 2000 es.
  248. Code 0440
  249. Bigger fuel rail and injectors needed for my 60MM TB?
  250. quick question: how to install cd player
