View Full Version : 2nd Gen Neon
- shift selector problem
- Part harvest
- Transmission Issue
- CarPart4u Test Fitment: Cars Needed!
- Which one should I try to get?
- Photoshop please
- 2000 plymouth neon code 0171
- Does anyone know what line that is?
- neon tires????????
- Project SRT wheels pt. 2 **Pics**
- Need some input on upgrading my 2000 neon
- Clutch Suggestions
- my neons progress
- eBay Turbo
- seat belt part
- WANTED - K&N Typhoon CAI
- Transmission Problem
- hood i'm thinking about
- Difference in 2.0 SOHC motors
- Squeaky Noise
- 17 inch wheels
- clutch questions
- Broken Cam
- SRT hood on my '01?
- My headlight Mod *How-To*
- 02 bumper someone please!!!!!
- Advice please
- Izero's Front Bumper Flares - Interest Thread
- Where can I buy a battery cable??
- Water pump locked up! Chaos!
- HELP! srt-4 grab handles
- Free money
- End of the month is approaching
- A New Neon Project
- Need help installing glow gauge inverter.
- Gates timing belts
- need some friendly car care tips.
- Total loss of power-No codes
- Trouble Starting
- Crap Load of 04 Neon and 04 SRT4 Parts!!!
- 2001 dodge neon rt
- It takes preatty long to heat up the engine
- 2001 Neon RT Fiberglass subwoofer enclosure
- knocking under load
- Check Engine Light- P0420
- Service Manual
- Need some help please!
- need radiator help plz.
- 05 dodge neon engine question???????
- 2004 SXT almost stalled, then almost rammed a car...
- high idle when rolling over 5 mph.
- Camshaft position & HO2S Circuit Low Voltage codes?
- Had transmission serviced today...Question about external cooler
- I'm back.... and have a question..
- i need help please neon grille
- i need help
- Several problems with my 2002 neon...
- heater core
- Have You Voted For TOTY?
- 2000 Neon Check Engine Light
- Manual Swap
- thanks
- Clutch decision
- new guy needs help
- ? about exhaust setup
- 2001 Cooling system repair issue
- granatelli wires
- Carmax Diagnosis Question
- tranny question
- Question about oil and OF
- COTM / TOTM voting open
- Time to vote for car and truck of the month and year!
- Fuel Injector Cleaning...Now Hard Starts??
- P0068 - MAP, TPS Sensor, Vacuum leak
- Car and truck of the year voting NOW
- 2000 Neon Steering Knuckle
- 2000 dodge neon question
- Let's talk transmissions...
- Pulley question/recommendations
- best plug/wire combo with boost
- Opinions about future projects or cars
- ROTM Nominations / ROTY Voting Open
- valve cover
- car wont start or turn over
- Help!!! 2005 Dodge Neon
- gauges
- sway bar strut bracket,
- neon + pothole = KABOOM
- skim
- humming noise from front end
- 03 ATX into a 2000? *Blew my tranny* :(
- Rotor Recommendations?
- new can guys-please vote
- Silly question...
- Headers with CARB label?
- coil pack & wireset.
- Support the Can
- Oil on plug #2
- Blinker/Flasher issues
- Why is my HEAT only lukewarm?
- Did I install my thermostat correctly?
- question on a 2002 Neon SXT
- '00 Transmission issue
- Hypertech, jet chips?
- spark plugs.
- Car of the Month
- poppin like orville redenbacher?
- Car runs cold?
- Big question. Starting to get annoyed.
- Removing front plate
- Selling turbo build parts (turbo, IC, megasquirt, taillights...)
- Just bought a "new to me" 2001 Neon. Questions?
- Seats
- 2000 Neon Water pump replacement
- Rotor and brake pad recommendations
- Motor Mount Change
- ABS Picture
- Used Car Question
- Blue Smoke
- HID Kits!!!
- Merry christmas!!!!!
- Question on a timing belt replacement
- another neon show
- Anyone else have any idea whats wrong?
- Ticking sound at idle..
- 2005 Dodge Neon SXT Rear Suspension Part ID
- injectors and RRFPR
- crank but wont turn over?
- raising the car back up
- squealin' neon
- R/T Exhaust
- sooo... i been thinkin....
- Road Trip Issue...
- Dodge commercial
- 2000 Neon - Stutters when idling
- The Official Myspace Thread
- 2001 es/se difference??
- mopar lip kit
- ideas on a stalling problem?
- I AM PARTING OUT MY CAR..2003 SXT (neon)
- Heater/ac/defroster not blowing
- Turbo Neon
- Ignition Trouble???? Please Help!!!
- 2005 Neon turning left harder than turning right?
- what size are the stock rear speakers??
- How fast is your car???
- A must see neon show
- Speedometer and Tachometer went backwards
- a few 2001 neon questions
- Should i get a new car?????? advice please
- need help
- Whistling Belt??
- Shift Knob
- Double Tap Feedback On Brake Pedal
- looking for parts 00 an up
- Clockspring Problems
- 2000 Neon sticks in park - cruise
- looking for a lip kit for 03 sxt
- Need parts from a 2003 neon sxt
- Headlight Wiring Capability/Capacity
- serpentine belt pulley
- Where did all the coolant go story
- 2003 dodge neon r/t performance part help
- Broken reservoir top
- it is mine!!! all mine!!!!
- "Door" Indicator problem
- Code P0750 Shift solenoid
- help
- My winter wheels are here!
- What other cars do you drive?
- Car shuts off during idle
- any 2nd gen tennessee owners here?
- Speedometer Problem
- Oil Pressure Warning Light
- Exhaust.
- Wiring scematics, removal and installation, specs, and Locationing.
- New user please help asap!!!
- What battery do you guys recommend?
- 4-1 race header
- Should I trade my 2004 for a 2005?
- what type of engine coolant.
- Control Arm replacement - I need help!
- Lets have a poll...does your neon tick?
- No heat from heater!
- Short Throw Shifter
- Test Pipe Resonator
- Does this mean I completed a drive cycle?
- the new plans i have
- 2005 dodge neon 02 sensor
- CD changer help
- Throttle position sensor issues?
- Well Time to sell my baby....
- spark plugs
- '03 Neon Fuse Interior Fuse Panel Diagram
- Sweet smell inside cabin, but no steam on windshield?
- tires
- Body Side mouldings
- inside lights out...
- Heart tail lights for sale
- lower control arm makin funny noise since wreck
- 01 NEON RT (questions)
- Rack and Pinion
- Cruise Control help
- Evap Emmission Control errors on a 2003
- Thinking about getting Suspension Techniques Swaybar Set from MP.
- Cruise Control Problems
- 04 Oil Pressure Hookup
- Alarm Lights
- problems with 2005 dodge neon SXT
- Exhaust question
- Help
- SRT Bottom Door Trim
- vibrates and scary noises coming from the front
- 01 mopar lip kit (pics)
- tailights
- 2005 Neon Trans Cooler Lines Leak
- No Heat!!!
- Anyone in southern Cali
- turbo on SE
- 05 STX Knocks, Thumps, and Squeaks
- 05 STX Thumps, Knocks, Squeaks?????
- Replacing a blower motor ASAP
- 2000 Neon Auto trans problem.
- AC / Heater Question
- 1st gen owner looking at a 2nd gen
- 2.0l Motor mounts
- Shopping cart / Subie Neon?
- Junkyard Fun
- New job!!!!!!!!
- Popping Noises
- Please help,kirk header problems
- Srt4 rims on neon 2001
- stuff for sale
- injector help
- hey peoples whats up(N3zeroN
- Change to High Mileage Oil, do it or not?
- 2003 srt 4 struts ...for sale
- Any suggestions for P0441 code?
- whats better.. cold air intake or short rams?
- Suspension
- High-Output Alternator
- Eyelids, Will they fit?
- 2004 Dodge Neon SXT Question
- Anyone ever had this problem?
- Need to replace idler pulley
- Struts.
- What to Clean Seats With?
